This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
HTTP debugging
Things don’t always work as expected. For those cases, enabling the –http-debug option will log HTTP requests and responses to help you debugging the script.
--http-debuglogs the HTTP requests and responses, skipping the body.--http-debug="full"logs the HTTP requests and responses, including the full body.
Example
Given the following script:
import http from "k6/http";
export default function () {
http.get("https://google.com/");
}If we run it using k6 run --http-debug script.js we get output that looks like this:
/\ / \ | |_/ / / /
/ \ | |‾\ \ | (_) |
/ __________ \ |__| \__\ \___/ .io
execution: local
output: -
script: script.js
duration: -, iterations: 1
vus: 1, max: 1
Request: [----------------------------------------------------------] starting
GET / HTTP/1.1
Host: google.com
User-Agent: k6/0.20.0 (https://k6.io/);
Accept-Encoding: gzip
RedirectResponse:
HTTP/2.0 302 Found
Content-Length: 267
Alt-Svc: hq=":443"; ma=2592000; quic=51303432; quic=51303431; quic=51303339; quic=51303335,quic=":443"; ma=2592000; v="42,41,39,35"
Cache-Control: private
Content-Type: text/html; charset=UTF-8
Date: Thu, 22 Mar 2018 13:39:44 GMT
Location: https://www.google.se/?gfe_rd=cr&dcr=0&ei=ILKzWqiODOaxX_LBi5AG
Referrer-Policy: no-referrer
RedirectRequest:
GET /?gfe_rd=cr&dcr=0&ei=ILKzWqiODOaxX_LBi5AG HTTP/1.1
Host: www.google.se
User-Agent: k6/0.19.0 (https://k6.io/);
Referer: https://google.com/
Response:
HTTP/2.0 200 OK
Connection: close
Accept-Ranges: none
Cache-Control: private, max-age=0
Content-Type: text/html; charset=ISO-8859-1
Expires: -1
P3p: CP="This is not a P3P policy! See g.co/p3phelp for more info."
Server: gws
Set-Cookie: 1P_JAR=2018-03-22-13; expires=Sat, 21-Apr-2018 13:39:44 GMT; path=/; domain=.google.se
Set-Cookie: NID=126=asTcm5s3-jMa1-pquG09m9lpUrowy-OtzZ9cUomBuKeJePbvwJAZe5wCtiyLITj9_RrlWLf6DTQ8ufpdB39MCRV-zUpfXAUw8XUVMWtgdU1gbtnQ9rssin56333g9Hyo; expires=Fri, 21-Sep-2018 13:39:44 GMT; path=/; domain=.google.se; HttpOnly
Vary: Accept-Encoding
X-Frame-Options: SAMEORIGIN
X-Xss-Protection: 1; mode=block
