This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Migrate a Playwright script to k6
Playwright is an end-to-end testing framework for modern web apps. You can use it for web testing across browsers, mobile web testing, API testing, and general-purpose browser automation.
You can convert your Playwright scripts to k6 browser scripts and use them in the following ways:
- Run performance tests and frontend testing simultaneously in k6 OSS or Grafana Cloud k6 to see how your application behaves in real-world scenarios.
- Use Synthetic Monitoring to ensure your application is monitored and working correctly on a consistent schedule.
In this guide, you’ll learn the key differences between Playwright and k6, and how to migrate your scripts.
Before you begin
To run a k6 test, you’ll need:
- A machine with k6 installed.
Example migration
The following example shows a Playwright script and the common steps to migrate it to a k6 script:
import { test, expect } from '@playwright/test';
test('has title', async ({ page }) => {
await page.goto('https://playwright.dev/');
// Expect a title "to contain" a substring.
await expect(page).toHaveTitle(/Playwright/);
});Create a new file named pw-migrated.js and copy the following initial k6 script setup:
import { expect } from 'https://jslib.k6.io/k6-testing/0.6.1/index.js';
import { browser } from 'k6/browser';
export const options = {
scenarios: {
ui: {
executor: 'shared-iterations',
options: {
browser: {
type: 'chromium',
export default async function () {
// Paste your test code here
}k6 browser is an official module to run browser tests with k6. Any Playwright script that you migrate must include the import { browser } from 'k6/browser'; line at the top.
k6 browser doesn’t implement a test framework. Instead, the logic of test is handled inside the export default async function ().
Next, copy the contents from the test() function from the Playwright script into the k6 default async function ().
scenarios: {
ui: {
options: {
browser: {
type: 'chromium',
}k6 doesn’t implement fixtures like Playwright does. Instead, use the browser class to retrieve a page within its own context. After that, you can use the usual page methods such as goto or click:
scenarios: {
ui: {
options: {
browser: {
type: 'chromium',
const page = await browser.newPage(); // Create a new page in its own incognito context
}Save your script, and then run it in your terminal:
k6 run pw-migrated.jsYou should see an output similar to the following:
/\ Grafana /‾‾/
/\ / \ |\ __ / /
/ __________ \ |_|\_\ \_____/
execution: local
script: pw-migrated.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* ui: 1 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
█ TOTAL RESULTS
EXECUTION
iteration_duration..........: avg=1.81s min=1.81s med=1.81s max=1.81s p(90)=1.81s p(95)=1.81s
iterations..................: 1 0.463436/s
vus.........................: 1 min=1 max=1
vus_max.....................: 1 min=1 max=1
NETWORK
data_received...............: 0 B 0 B/s
data_sent...................: 0 B 0 B/s
BROWSER
browser_data_received.......: 1.8 MB 829 kB/s
browser_data_sent...........: 7.7 kB 3.6 kB/s
browser_http_req_duration...: avg=120.89ms min=1.95ms med=98.73ms max=1.14s p(90)=139.67ms p(95)=263.7ms
browser_http_req_failed.....: 0.00% 0 out of 23
WEB_VITALS
browser_web_vital_fcp.......: avg=1.24s min=1.24s med=1.24s max=1.24s p(90)=1.24s p(95)=1.24s
browser_web_vital_ttfb......: avg=1.14s min=1.14s med=1.14s max=1.14s p(90)=1.14s p(95)=1.14s
running (00m02.2s), 0/1 VUs, 1 complete and 0 interrupted iterations
ui ✓ [======================================] 1 VUs 00m02.2s/10m0s 1/1 shared itersMigrate multiple tests
The following example shows a Playwright test file that contains two tests. To migrate multiple tests, use the k6 scenarios feature to create equivalent test logic:
test('admin', async ({ page }) => {
await page.goto('https://quickpizza.grafana.com/admin', {
waitUntil: 'networkidle',
await page.getByLabel('username').fill('admin');
await page.getByLabel('password').fill('admin');
await page.getByRole('button', { name: 'Sign in' }).click()
await page.getByRole('button', { name: 'Logout' }).waitFor()
const label = page.locator('h2')
const textContent = await label.textContent()
expect(textContent).toEqual('Latest pizza recommendations');
test('user', async ({ page }) => {
await page.goto('https://quickpizza.grafana.com/login', {
await page.getByLabel('username').fill('default');
await page.getByLabel('password').fill('12345678');
await page.getByText('Sign in').click();
expect(textContent).toEqual('Your Pizza Ratings:');
});To convert this Playwright script to k6, create a new file named pw-multiple-migrated.js.
First, create two scenarios and point them to two exported functions using the exec field in each scenario:
scenarios: {
user: {
exec: 'userLogin',
options: {
browser: {
type: 'chromium',
admin: {
exec: 'adminLogin',
options: {
browser: {
type: 'chromium',
export async function adminLogin() {
// Paste admin test code here
export async function userLogin() {
// Paste user test code here
}Next, copy the test code into the respective exported functions. Since k6 doesn’t have fixtures, use the imported browser object to create a newPage:
scenarios: {
user: {
exec: 'userLogin',
options: {
browser: {
type: 'chromium',
admin: {
exec: 'adminLogin',
options: {
browser: {
type: 'chromium',
}Run the test script:
k6 run pw-multiple-migrated.jsThe command runs the two scenarios concurrently and produces output similar to the following:
/\ Grafana /‾‾/
/\ / \ |\ __ / /
execution: local
script: pw-multiple-migrated.js
output: -
scenarios: (100.00%) 2 scenarios, 2 max VUs, 10m30s max duration (incl. graceful stop):
* admin: 1 iterations shared among 1 VUs (maxDuration: 10m0s, exec: adminLogin, gracefulStop: 30s)
* user: 1 iterations shared among 1 VUs (maxDuration: 10m0s, exec: userLogin, gracefulStop: 30s)
█ TOTAL RESULTS
EXECUTION
iteration_duration..........: avg=5.01s min=4.7s med=5.01s max=5.33s p(90)=5.26s p(95)=5.3s
iterations..................: 2 0.333461/s
vus.........................: 2 min=2 max=2
vus_max.....................: 2 min=2 max=2
NETWORK
BROWSER
browser_data_received.......: 601 kB 100 kB/s
browser_data_sent...........: 14 kB 2.3 kB/s
browser_http_req_duration...: avg=489.58ms min=114.61ms med=514.78ms max=3.25s p(90)=524.5ms p(95)=534.85ms
browser_http_req_failed.....: 0.00% 0 out of 46
WEB_VITALS
browser_web_vital_cls.......: avg=0.009527 min=0 med=0.009527 max=0.019055 p(90)=0.017149 p(95)=0.018102
browser_web_vital_fcp.......: avg=3.09s min=2.76s med=3.09s max=3.43s p(90)=3.36s p(95)=3.39s
browser_web_vital_fid.......: avg=200µs min=199.99µs med=200µs max=200µs p(90)=200µs p(95)=200µs
browser_web_vital_inp.......: avg=16ms min=16ms med=16ms max=16ms p(90)=16ms p(95)=16ms
browser_web_vital_lcp.......: avg=3.09s min=2.76s med=3.09s max=3.43s p(90)=3.36s p(95)=3.39s
browser_web_vital_ttfb......: avg=2.84s min=2.43s med=2.84s max=3.25s p(90)=3.17s p(95)=3.21s
running (00m06.0s), 0/2 VUs, 2 complete and 0 interrupted iterations
admin ✓ [======================================] 1 VUs 00m05.3s/10m0s 1/1 shared iters
user ✓ [======================================] 1 VUs 00m06.0s/10m0s 1/1 shared itersKey differences
Test isolation patterns
In k6, scenarios let you configure and model diverse workloads and organize your tests. Playwright has a dedicated testing framework. This difference stems from k6 being a performance testing tool.
Note
There are plans to create a testing framework in k6. For more details or to contribute, refer to this GitHub issue.
Metrics
k6 collects and reports on several built-in metrics, such as request and response times, data size, and more. It also includes support for Web Vital metrics, such as FCP, INP, and TTFB.
Refer to Built-in metrics for more details.
k6 concepts
To effectively use k6 for browser testing, it’s important to understand a few core concepts from its load testing foundation:
- Virtual User: A Virtual User (VU) is an independent thread of execution that runs concurrently with other VUs. Scripts are often designed so that one VU represents the activity of one real user.
- Iteration: The number of times a single VU runs the test script.
- Thresholds and checks: Thresholds are pass/fail criteria that you configure for your test metrics. For example, you can configure a threshold to fail if more than 1% of requests return an error. Checks validate a boolean condition in your test. For example, you can check whether the response status code equals 200. The main difference is that unmet thresholds cause a test to finish with a failed status, while checks don’t. k6 also provides a k6-testing library that behaves similarly to assertions in Playwright. For more details, refer to the k6-testing documentation.
Browser context restrictions
Unlike Playwright, k6 can only work with a single browser context at a time. The following script fails when you run it with k6:
const bc1 = await browser.newContext();
// This next call results in an error: "existing browser context must be closed before creating a new one"
const bc2 = await browser.newContext();To fix this, close the existing browser context before creating a new one.
Hybrid tests
Hybrid tests are performance tests that run browser-level and protocol-level requests simultaneously. They’re a great alternative to resource-intensive browser-based load testing, while still measuring application performance under load by making requests to both the frontend and backend.
Refer to Hybrid performance with k6 browser for more details.
Run k6 tests in Grafana Cloud
In addition to running k6 scripts locally by installing k6 on your machine, you can use Grafana Cloud for a seamless experience. Using Grafana Cloud means you don’t have to worry about whether your machine has the right resources to run a performance test. You also get pre-made Grafana dashboards to analyze test results and can collaborate with other team members to debug performance issues.
Refer to Run a test using Grafana Cloud k6 for more details.
References
- k6 browser APIs
- k6-testing library for Playwright-inspired assertions
- Understand k6 CLI output results
- Test lifecycle
- k6 browser recommended practices
