Enterprise Open source RSS
Manage users in an organization
Organization administrators can invite users to join their organization. Organization users have access to organization resources based on their role, which is Admin, Editor, or Viewer. Permissions associated with each role determine the tasks a user can perform in the system.
For more information about organization user permissions, refer to Organization users and permissions.
View a list of organization users
You can see a list of users with accounts in your Grafana organization. If necessary, you can use the search field to filter the list.
Before you begin
  • Ensure you have organization administrator privileges
To view a list of organization users:
  1. Sign in to Grafana as an organization administrator.
  2. Hover your cursor over the Configuration (gear) icon in the side menu and click Users.
Org Admin user list
Note: If you have server administrator permissions, you can also view a global list of users in the Server Admin section of Grafana.
Change a user’s organization permissions
Update user permissions when you want to enhance or restrict a user’s access to organization resources. For more information about organization permissions, refer to Organization roles.
Before you begin
To change the organization role of a user:
  3. Find the user account for which you want to change the role.
    If necessary, use the search field to filter the list.
  4. Locate the user on the list and in the Role column, click the user role.
  5. Select the role that you want to assign.
  6. Click Update.
Note: If you have server administrator permissions, you can also change a user’s organization permissions in the Server Admin section.
Invite a user to join an organization
When you invite users to join an organization, you assign the Admin, Editor, or Viewer role which controls user access to the dashboards and data sources owned by the organization. Users receive an email that prompts them to accept the invitation.
  • If you know that the user already has access Grafana and you know their user name, then you issue an invitation by entering their user name.
  • If the user is new to Grafana, then use their email address to issue an invitation. The system automatically creates the user account on first sign in.
Note: If you have server administrator permissions, you can also manually add a user to an organization.
Before you begin
  • Ensure you have organization administrator privileges.
  • If the user already has access to Grafana, obtain their user name.
  • Determine the permissions you want to assign to the user. For more information about organization permissions, refer to Organization roles.
To invite or add an existing user account to your organization:
  2. To switch to the organization to which you want to invite a user, hover your mouse over your profile and click Switch organization and select an organization.
    Note: It might be that you are currently in the proper organization and don’t need to switch organizations.
  3. Hover your cursor over the Configuration (gear) icon in the side menu and click Users.
  4. Click Invite.
  5. Enter the following information:
    FieldDescription
    Email or usernameEither the email or username that the user will use to sign in to Grafana.
    NameThe user’s name.
    RoleClick the organization role to assign this user. For more information about organization roles, refer to Organization roles..
    Send invite emailSwitch to on if your organization has configured. The system sends an email to the user inviting them to sign in to Grafana and join the organization. Switch to off if you are not using email. The user can sign in to Grafana with the email or username you entered.
  6. Click Submit.
If the invitee is not already a user, the system adds them.
Invite User.
Manage a pending invitation
Periodically review invitations you have sent so that you can see a list of users that have not yet accepted the invitation or cancel a pending invitation.
Note: The Pending Invites button is only visible if there are unanswered invitations.
Before you begin
To manage a pending invitation:
  3. Click Pending Invites.
    The Pending Invites button appears only when there are unaccepted invitations.
To cancel an invitation, click the red X next to the invitation.
To copy an invitation link and send it directly to a user, click Copy Invite. You can then paste the invite link into a message.
Pending Invites list
Remove a user from an organization
You can remove a user from an organization when they no longer require access to the dashboard or data sources owned by the organization. No longer requiring access to an organization might occur when the user has left your company or has internally moved to another organization.
This action does not remove the user account from the Grafana server.
Before you begin
To remove a user from an organization:
  3. Find the user account that you want to remove from the organization.
    Use the search field to filter the list, if necessary.
  4. Click the red X to remove the user from the organization.
Note: If you have server administrator permissions, you can also remove a user from an organization on the Users page of the Server Admin section.
