Menu
Scroll for more
Enterprise
Reference: Calculations
Refer to the following list of calculations you can perform in Grafana. You can find these calculations in the Transform tab and in the bar gauge, gauge, and stat visualizations.
| Calculation | Description |
| All nulls | True when all values are null |
| All zeros | True when all values are 0 |
| Change count | Number of times the field’s value changes |
| Count | Number of values in a field |
| Delta | Cumulative change in value, only counts increments |
| Difference | Difference between first and last value of a field |
| Difference percent | Percentage change between first and last value of a field |
| Distinct count | Number of unique values in a field |
| First (not null) | First, not null value in a field |
| Max | Maximum value of a field |
| Mean | Mean value of all values in a field |
| Min | Minimum value of a field |
| Min (above zero) | Minimum, positive value of a field |
| Range | Difference between maximum and minimum values of a field |
| Step | Minimal interval between values of a field |
| Total | Sum of all values in a field |
Was this page helpful?
Video
In this webinar, we’ll demo how to get started using the LGTM Stack: Loki for logs, Grafana for visualization, Tempo for traces, and Mimir for metrics.
Video
Getting started with Grafana dashboard design
In this webinar, you'll learn how to design stylish and easily accessible Grafana dashboards that tell a story.
Video
Building advanced Grafana dashboards
In this webinar, we’ll demo how to build and format Grafana dashboards.
