Enterprise Open source
Upgrade to Grafana v12.1
We recommend that you upgrade Grafana often to stay current with the latest fixes and enhancements. Because Grafana upgrades are backward compatible, the upgrade process is straightforward, and dashboards and graphs will not change.
In addition to common tasks you should complete for all versions of Grafana, there might be additional upgrade tasks to complete for a version.
Note
There might be breaking changes in some releases. We outline all these changes in the What’s New document.
For versions of Grafana prior to v9.2, we published additional information in the Release Notes.
When available, we list all changes with links to pull requests or issues in the Changelog.
Note
When possible, we recommend that you test the Grafana upgrade process in a test or development environment.
Back up Grafana
This topic explains how to back up a local Grafana deployment, including configuration, plugin data, and the Grafana database.
Back up the Grafana configuration file
Copy Grafana configuration files that you might have modified in your Grafana deployment to a backup directory.
The Grafana configuration files are located in the following directories:
  • Default configuration: $WORKING_DIR/defaults.ini (Don’t change this file)
  • Custom configuration: $WORKING_DIR/custom.ini
For more information on where to find configuration files, refer to Configuration file location.
Note
If you installed Grafana using the deb or rpm packages, then your configuration file is located at /etc/grafana/grafana.ini. This path is specified in the Grafana init.d script using --config file parameter.
Back up plugin data
Installing plugins in Grafana creates a folder for each plugin with its associated files and data. Copy all files and folders recursively from this location to your backup repository.
The Grafana plugin files are located in the following directories:
  • Default location for plugins in a binary or source installation: $WORKING_DIR/data/plugins
  • Default location for plugins in a deb or rpm package: /var/lib/grafana/plugins. This path is specified in the Grafana init.d script using --config file parameter.
Back up the Grafana database
We recommend that you back up your Grafana database so that you can roll back to a previous version, if required.
SQLite
The default Grafana database is SQLite, which stores its data in a single file on disk. To back up this file, copy it to your backup repository.
Note
To ensure data integrity, shut down your Grafana service before backing up the SQLite database.
The SQLite database file is located in one of the following directories:
  • Default location for SQLite data in a binary or source installation: $WORKING_DIR/data/grafana.db
  • Default location for SQLite data in a deb or rpm package: /var/lib/grafana/grafana.db. This path is specified in the Grafana init.d script using --config file parameter.
MySQL
To back up or restore a MySQL Grafana database, run the following commands:
Bash
backup:
> mysqldump -u root -p[root_password] [grafana] > grafana_backup.sql
restore:
> mysql -u root -p grafana < grafana_backup.sql
Postgres
To back up or restore a Postgres Grafana database, run the following commands:
Bash
backup:
> pg_dump grafana > grafana_backup
restore:
> psql grafana < grafana_backup
Upgrade Grafana
The following sections provide instructions for how to upgrade Grafana based on your installation method. For more information on where to find configuration files, refer to Configuration file location.
Debian
To upgrade Grafana installed from a Debian package (.deb), complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/grafana.ini.
    This enables you to upgrade Grafana without the risk of losing your configuration changes.
  2. Download the latest version of Grafana.
  3. Run the following dpkg -i command.
    Bash
    wget <debian package url>
    sudo apt-get install -y adduser
    sudo dpkg -i grafana_<version>_amd64.deb
APT repository
To upgrade Grafana installed from the Grafana Labs APT repository, complete the following steps:
  2. Run the following commands:
    Bash
    sudo apt-get update
    sudo apt-get upgrade
Grafana automatically updates when you run apt-get upgrade.
Binary .tar file
To upgrade Grafana installed from the binary .tar.gz package, complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to the custom configuration file, custom.ini or grafana.ini.
  2. Download the binary .tar.gz package.
  3. Extract the downloaded package and overwrite the existing files.
RPM or YUM
To upgrade Grafana installed using RPM or YUM complete the following steps:
  2. Perform one of the following steps based on your installation.
Docker
To upgrade Grafana running in a Docker container, complete the following steps:
  1. Use Grafana environment variables to save your custom configurations; this is the recommended method. Alternatively, you can view your configuration files manually by accessing the deployed container.
  2. Run a commands similar to the following commands.
    Note
    This is an example. The parameters you enter depend on how you configured your Grafana container.
    Bash
    docker pull grafana/grafana
    docker stop my-grafana-container
    docker rm my-grafana-container
    docker run -d --name=my-grafana-container --restart=always -v /var/lib/grafana:/var/lib/grafana grafana/grafana
Windows
To upgrade Grafana installed on Windows, complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/conf/custom.ini.
  2. Download the Windows binary package.
  3. Extract the contents of the package to the location in which you installed Grafana.
    You can overwrite existing files and folders, when prompted.
Mac
To upgrade Grafana installed on Mac, complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to the custom configuration file, custom.ini.
  2. Download the Mac binary package.
Update Grafana plugins
After you upgrade Grafana, we recommend that you update all plugins because a new version of Grafana can make older plugins stop working properly.
Run the following command to update plugins:
Bash
grafana cli plugins update-all
Technical notes
Annotation table migration
Plan for increased disk usage when upgrading from Grafana v11.x
Upgrading from Grafana v11.x to Grafana v12.x triggers a full-table rewrite of the annotation table. The migration populates the new dashboard_uid column, which causes the database to rewrite the entire table and rebuild its indexes.
Environments with large annotation datasets can experience significant temporary disk usage increase, which may lead to:
  • Rapid disk consumption on the database data volume
  • Database migration failures (for example, “could not extend file: No space left on device”)
  • Grafana startup failures
  • Extended downtime during the upgrade process
How do I know if I’m affected?
You’re affected if you’re upgrading from Grafana v11.x to v12.x and you have a large annotation table in your database.
To check your annotation table size, connect to your database and check the table size.
For PostgreSQL, run the following query:
SQL
SELECT
    pg_size_pretty(pg_relation_size('annotation'))       AS table_size,
    pg_size_pretty(pg_indexes_size('annotation'))        AS indexes_size,
    pg_size_pretty(pg_total_relation_size('annotation')) AS total_size;
For MySQL, run the following query:
SQL
SELECT
    ROUND(data_length / 1024 / 1024, 2) AS table_size_mb,
    ROUND(index_length / 1024 / 1024, 2) AS indexes_size_mb,
    ROUND((data_length + index_length) / 1024 / 1024, 2) AS total_size_mb
FROM information_schema.tables
WHERE table_schema = DATABASE()
    AND table_name = 'annotation';
For SQLite, check the database file size directly, as SQLite stores all tables in a single file. You can run the following command from your terminal:
Bash
ls -lh <PATH/TO/GRAFANA.DB>
If your total size is several gigabytes or more, you should plan accordingly before upgrading.
What should I do before upgrading?
Before you upgrade, take the following steps:
  1. Verify available disk space: Ensure you have at least 2-3 times the current annotation table size available as free disk space on your database data volume.
  2. Review your annotation data: Consider whether you need to retain all historical annotations.
  3. Clean up old annotations (optional): If you have annotations you don’t need, remove them before upgrading.
  4. Back up your database: Always back up your Grafana database before performing an upgrade. For more information, refer to Back up Grafana.
What should I do after upgrading?
After successfully upgrading to Grafana v12.x, you can reclaim disk space by performing database maintenance operations during a maintenance window.
For PostgreSQL, run a VACUUM FULL operation on the annotation table:
SQL
VACUUM FULL annotation;
For MySQL, run an OPTIMIZE TABLE operation on the annotation table:
SQL
OPTIMIZE TABLE annotation;
For SQLite, run a VACUUM operation on the database:
SQL
VACUUM;
These operations require a lock on the table and may take significant time depending on the table size. Plan to run these during a low-traffic period.
