Explore your infrastructure with Kubernetes Monitoring
Kubernetes Monitoring offers visualization and analysis tools for you to:
  • Evaluate the health, efficiency, and cost of Kubernetes infrastructure components.
  • Analyze historical data as well as forecasts.
  • View predictions created with machine learning.
  • Manage alerts.
  1. Navigate to your Grafana Cloud portal.
  2. In the menu, select the stack you want to work with.
  3. Click the Grafana logo icon.
  4. In the main menu, expand Infrastructure.
    Main menu with Infrastructure selected
  5. Click Kubernetes.
    Kubernetes menu item showing on the main menu
Search for a Kubernetes object
Use search to find any Kubernetes Cluster, Node, namespace, workload, Pod, or container.
Home page search field and search results page
If the main menu is docked, you can also navigate to Search from the menu.
Explore using the Kubernetes structure
Kubernetes Monitoring pages mirror the hierarchy of Kubernetes objects, so you can begin at any level above containers. Main pages include lists of Clusters, namespaces, workloads, and Nodes.
For example, the Cluster main page shows the list of your Clusters. When you click on a Cluster in the list, it opens the Cluster detail page. That page shows the details for the Cluster along with a list of Nodes within that Cluster.
You can continue to drill into a Node and see the list of Pods for that Node, all the way to the container level.
Navigating from main Cluster list page to container detail page
Navigating from lists to detail pages
There are also main pages for Cluster configuration as well as managing alerts, cost, and efficiency. For additional navigation tips, refer to Navigation tips for Kubernetes Monitoring.
Start with high-level snapshot
The Kubernetes Overview page gives you a high-level view of your Clusters, usage, and alerts. This page brings to the forefront key data about your infrastructure.
Refine counts of Kubernetes objects
Adjust the time range and filter by Cluster and namespace to narrow and include historical data for:
  • Clusters, Nodes, namespaces, workloads, Pods, and containers
  • Deployed container images
Filtering by Cluster for object count
Find usage spikes
Use the time range selector to focus on a time period while looking for patterns or spikes in CPU and memory usage in your Clusters. When spikes occur:
  1. Zoom in on the graph to narrow the time selection.
    Zooming in on graph to change time range
  2. Hover over and click the peak of the spike to see the percentage of use compared to capacity. In the following example, the spike shows 46.5% of CPU usage compared to capacity.
    Hovering over spike to show Cluster link
  3. Click the View link to view the Cluster. The Cluster detail page shows the time range you set when zooming in on the graph.
    Cluster detail page
    Cluster detail page
    You can continue by sorting the list of Nodes in this Cluster by highest CPU usage to investigate the issue causing the spike.
Review and drill into alerts
  1. Sort the Firing Since column of alerts to focus on either the most current or the oldest alerts that are firing.
  2. Click the container or Pod name related to the alert to jump directly to the detail page.
    Clicking the name of the container
    Container detail page
Manage alerts
View and respond to all Kubernetes-related alerts from the Alerts page and the Kubernetes Overview page.
You can also:
Analyze costs
On the Cost page, use the Overview and Savings tabs to gain an understanding what Kubernetes is costing and how you can save. You can see the cost of each item in a list view as well as on the detail pages.
Understand efficiency and resource use
Optimize resource usage and efficiency by:
  • Correlating between average and maximum resource usage to understand performance and troubleshoot stability issues.
  • Observe resource usage for each Kubernetes object.
  • Discover any stranded resources in your fleet.
List of namespaces showing a comparison of average and maximum resource usage data
Throughout Kubernetes Monitoring, resource usage statistics are available for Kubernetes objects.
Learn what’s predicted
CPU and memory prediction can help you ensure resources are available during spikes in usage, as well as help you decrease the amount of unused resources due to over provisioning. To use prediction tools, first enable the Machine Learning plugin.
The following buttons are available in various views. Click them to show a prediction for Clusters, namespaces, workloads, Nodes, Pods, and containers:
  • Predict Mem Usage: Shows a predictive graph for memory usage one week in the future. Calculations are based on metrics from the previous week.
  • Predict CPU: Shows a predictive graph for CPU usage one week in the future. Calculations are based on metrics from the previous week.
    Predict CPU button
    Predict CPU button
    Predictions for Pod CPU Usage
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on this Node details page.
Detect outlier Pod CPU usage
Identify any Pods that have CPU usage different from other Pods. To do so, on a workload detail page, click Detect Outlier CPU Usage amongst Pods.
Detecting outlier CPU usage for a Pod
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on this namespace details page.
Uncover energy usage
On any detail page, click the Energy tab to view the energy usage of:
  • Workloads and namespaces
  • Clusters
  • Nodes
  • Pods
  • Containers
Energy usage for workloads in a namespace for 24 hours
When you configure Kubernetes Monitoring to gather energy metrics, Kepler exposes and gathers metrics, and Alloy collects these metrics.
Energy metrics are separated into these categories:
Use Explore for troubleshooting
Click any Explore button to view the raw data and troubleshoot issues. A new tab opens to show the detailed query data.
Raw query data
Raw query data
Select a time range to see your historical data for any time frame you choose. As you navigate from page to page, the time range remains the same for period you set until you change it again.
As an example, the Pod optimization section of the Pod detail page shows a time range over several hours. You can use this to understand the historical pattern of CPU usage and memory usage.
Graphs showing Pod bursting over CPU request and bursting above memory requests
Pod optimization view on Pod detail page
Zoom into an area of any graph on the detail pages to narrow the time range selector even further. The time range remains selected until you click Back to default.
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on this namespace details page set for the last 12 hours.
Find deleted Kubernetes objects
You can find deleted Clusters, namespaces, workloads, Nodes, Pods, and containers to understand what occurred in the past. To do so, set the time range selector to a past time period.
The following example shows a time range of the previous 30 days, and then filtering for Nodes with the condition of “No data”.
Time range set to 30 days and selecting the no data filter in the condition drop-down
On the Node detail page, you can learn when the Node expired.
Node details page showing Node expiration
Note
Grafana Cloud has a default 30-day limit for queries. If your Kubernetes object was deleted 30 days beyond the current date, use the time range selector to choose a specific 30-day time frame in the past.
Discover bare and unmanaged Pods
You can find unmanaged (or static) and bare Pods that have been directly created.
Navigate to the Workloads main page, and filter by the Pod type. For example, to locate unmanaged static Pods, filter for StaticPod.
Filtering for static Pod type
View network bandwidth and saturation
Use the network panels to understand when bandwidth limits are causing network saturation, which can lead to dropped packets. On any detail page for Cluster, namespace, workload, Node, or Pod, click the Network tab to view:
  • Network Bandwidth Rx/Tx: Shows the rate of received and transmitted bytes
  • Network Saturation Rx/Tx dropped packets: Shows rate of received and transmitted packets dropped
  • Network Bandwidth and Network Saturation by Node, workload, or Pod: Shows the bandwidth and saturation by object
    Network bandwidth and saturation panels for a Cluster
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on the Network tab of this namespace details page.
View logs and events
From any detail page, click the Logs & Events tab to view the logs and events for that Kubernetes object.
Viewing logs for a namespace
Resolve issues with built-in tools
Navigate easily from Kubernetes Monitoring to other capabilities in Grafana Cloud to analyze, troubleshoot, and solve issues.
Start an automated diagnostic
From a Pod, Cluster, namespace, or workload detail page, you can begin an automated investigation by clicking Run Sift investigation. Sift performs a set of automated system checks, and surfaces potential issues in your Kubernetes environment. It then works to identify the root cause of an incident.
Opening a Sift investigation for a namespace
Access root cause analysis tool
Note
To access root cause analysis tools, enable Asserts on your stack.
You can take troubleshooting deeper by understanding relationships between components and what is occurring between them.
Within Kubernetes Monitoring, access Asserts Workbench to perform root cause analysis. From any list of Clusters, Nodes, workloads, namespaces, or Pods you choose, select the box to the left of the list item, and click the Compare in Asserts Workbench button. The RCA Workbench opens in a new tab.
Selecting Clusters to compare for root cause analysis
Within any details page where the Assertions button appears, click it to continue your investigation into issues.
Jumping to Asserts Workbench to troubleshoot
Go directly to the connections view in Asserts to view connections between entities.
Jumping to view connections in Asserts
Jump to the application layer
On the detail page for a Pod or workload, click View application layer, then Go to Application Observability to navigate directly to more data, such as the service health.
Navigating directly to the Application Observability app
To return to Kubernetes Monitoring, click the browser back button.
View queries to troubleshoot with Explore
To further query data, use any of the Explore buttons available throughout the interface (such as Explore namespaces or Explore alerts). You see a view that provides additional query tools for troubleshooting.
Raw query with options to add, view query history, and inspect query
Raw metrics
If you choose to enable traces when you configure Kubernetes Monitoring, you can easily click to see them.
  1. Click the main menu icon.
  2. Click Explore.
  3. Choose the Tempo data source.
  4. With the TraceQL tab selected, enter your search query.
  5. Click Run query.
    A table of traces appears.
  6. Click a trace to see the detail.
Explore detail page showing table of traces, TraceQL query, and trace graph
View traces
Manage configuration
If you have the admin role, you can manage the configuration of Kubernetes Monitoring by working with:
  • Data source choices
  • Alerts
  • Integration installations
  • Optional custom log queries
  • Configuration instructions for Grafana Kubernetes Monitoring Helm chart to deploy, configure, and keep it up to date
Access more information
Click the documentation links on a page to find more information about what you’re viewing.
Here are some tips and shortcuts for getting around in Kubernetes Monitoring.
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on the Kubernetes Monitoring Overview.
Jump between main pages
From any main page, click the icon beside the page title to see the menu of all main pages. Then click the page you want to open.
Clicking next to the page title to reveal navigation menu
Dock the main menu
To keep the main navigation open:
  1. Click the Grafana logo menu icon.
  2. Click the dock menu icon to keep the main menu open.
Hovering over the dock menu icon
Filter, sort, and set the time range
Use filters and sorting, along with the time range selector, to target the data you want.
Filtering for a namespace
Jump to main lists
From the counts on the Kubernetes Overview home page, click All to see that component’s list of items in your Kubernetes fleet.
Clicking the **All** link from the **Kubernetes Overview** page to see a list of all Clusters
Clicking the All link from the Kubernetes Overview page to see a list of all Clusters
Control app refresh
You can control the automatic refresh interval of the GUI as well as disable the auto refresh.
Menu for controlling automatic refresh and refresh interval
Use color cues
Throughout the views in Kubernetes Monitoring, you see color used as an additional means of indicating status or condition. For example, sometimes text is a different color for Pod status:
List of workloads with the status of running showing in green
Color coding
TextColorComments
FailedRedFailed Pod
RunningGreenHealthy Pod
RunningRedPod is failing to start
SucceededGreenJob Pod successfully run
UnknownWhitePod status is unknown
WaitingYellowPod is waiting because of startup, such as Pod initializing or container creating
WaitingRedPod is waiting because of a problem, such as crash loop back off or image pull back off
For more information on Pod status, refer to the Kubernetes documentation on Pod lifecycle.
The following table describes the color indicators for resource capacity and the state of resource usage:
Usage ColorsUsageComments
Green60-90% of maximumThis is the ideal state of resource usage.
YellowBelow 60%Low usage percentages indicate that the item might be over provisioned.
Red90%+Your resource usage is close to or above its configured capacity.
