Troubleshoot Kubernetes Monitoring
This section includes common errors encountered while installing and configuring Kubernetes Monitoring components, and tools you can use to troubleshoot.
User loses access
If you have granted a user the None basic role plus plugins.app:access, that user has no access to Kubernetes. For what those two terms mean and why the combination blocks access, refer to Restore access for a user who can’t see Kubernetes.
Kubernetes Monitoring has two user roles to manage access:
plugins:grafana-k8s-app:adminplugins:grafana-k8s-app:reader
If a user is having trouble with access, make sure you have granted one of them one of these roles. To assign these roles, refer to Assign RBAC roles.
Troubleshoot with tools
You can use the following tools to help you troubleshoot issues with installation and configuration.
Alloy tool
Grafana Alloy has a web user interface that shows every configuration
component the Alloy instance is using and the component status.
By default, the web UI runs on each Alloy Pod on port 12345.
Because that UI usually isn’t reachable from outside the Cluster, you can access it by forwarding the port from a collector Pod. Use a Pod name from the output of kubectl get pods, because Service names vary with your release name and your collector names:
kubectl port-forward <POD_NAME> 12345:12345 -n <RELEASE_NAMESPACE>
Then open a browser to http://localhost:12345 to view the GUI.
Access the Alloy web tool when:
Grafana Alloy isn’t collecting or exporting metrics/logs/traces properly. For example, you’re missing metrics in Grafana Cloud or Prometheus and need to confirm if Alloy is scraping the right targets.
A component is failing or in an error state. The UI shows each configuration component and its status (running, failed, initializing, and so on).
You’re validating configuration changes. After updating your alloy.yaml, you can confirm that the configuration loaded correctly and that all pipelines and receivers are active.
You suspect a dependency or connectivity issue. For example, when Alloy can’t reach Grafana Cloud endpoints, a local data source, or another collector, you can inspect component logs or connection statuses.
You’re debugging startup or runtime issues. Useful if Alloy pods are up but not behaving as expected (for example, metrics pipeline broken, missing exporters).
Debug Metrics tool
For any panel, click the menu icon and select Debug metrics for this panel.
Debug Metrics lists all metrics used for the panel along with any errors found.
Metrics status tool
To view the status of metrics being collected, in Kubernetes Monitoring:
- Click Configuration on the menu.
- Click the Metrics status tab.
- Filter for the Cluster or Clusters you want to see the status of.
Status icons
Each panel of the Metrics status shows an icon that indicates the status of the incoming data, based on the selected data source, Cluster, and time range:
- Check mark in a circle (green): Data for this source is being collected. The version of the source or online status also displays (if available).
- Caution with exclamation mark (yellow): Duplicate data is being collected for the metric source.
- X in a circle (red): There is no data available for this item within the time range specified, and it appears to be offline.
Check initial configuration
When you initially configure, if any box shows a red X in a circle, it can be any of the following:
- The feature was not selected during Cluster configuration.
- The system is not running correctly.
- Alloy was not able to gather data correctly.
- No data was gathered during the time range specified.
View the query with Explore
If something in the metrics status looks incorrect, click the icon next to the panel title. This opens the query in Explore where you can examine the query for any issues, such as an incorrect label.
Look at a historical time range
Use the time range selector to understand what was occurring in the past. In the following example, Cluster events were being collected but are not currently.
View documentation for each status
For more information about each status, click the Docs link in each panel.
Check the app version
The Configuration page shows the frontend and backend versions of the Kubernetes Monitoring app. Check these versions to confirm an upgrade was applied, and include both when you report an issue.
Investigate deployment changes
If you’ve enabled the Kubernetes manifests feature (kubernetesManifests), the k8s-manifest-tail component collects changes to resources on your Cluster. With this, you can use these techniques to relate deployment changes to behavior you observe in Kubernetes Monitoring.
Enabling the feature alone isn’t enough. It also needs a logs destination, the k8s-manifest-tail service deployed through telemetryServices, and a list of the object types you want that service to capture. The minimum values are:
kubernetesManifests:
enabled: true
telemetryServices:
k8s-manifest-tail:
deploy: true
config:
objects:
- apiVersion: apps/v1
kind: Deployment
kind: StatefulSet
kind: DaemonSetIf any of the three is missing, the chart fails validation and names what to add, so you find out at install time rather than from missing data. This feature is experimental.
Investigate issues with Kubernetes manifests
The following tools help you determine whether configuration changes are causing issues in your Cluster.
View and compare the current manifest
To view the complete YAML definition of the resource as it currently exists:
Go to any Pod or workload detail view and click View Manifest. The Manifest for Workload window opens to display the current manifest.
To view the difference between the current manifest and any previous manifests, click Diff with previous. Select any two versions to compare them side by side.
To ask Grafana Assistant about the current manifest, click Ask assistant about this manifest.
Analyze deployment changes
At a glance, you can find creations, updates, and deletions of deployments by viewing the deployment detail page of this component.
k8s-manifest-tail with highlights of deployments on the graphsUse Search to find the component
k8s-manifest-tailand select it. The Overview tab of the Deployment detail page for thek8s-manifest-taildisplays.Adjust the time range selector to the time frame of one or more deployments.
In the Workload Optimization section, switch on highlights on the graph that you want to see regarding deployment modifications, creations, and deletions. Here you can visually correlate a metric anomaly with a configuration change that happened at the same time, such as a replica count update that preceded a CPU spike.
Hover over a highlight annotated on the graph to see additional details.
To investigate further, use the Changes tab on the Deployment detail page for the k8s-manifest-tail. Three panels show deployment creation, updates, and deletions. These three panels work best when read together.
k8s-manifest-tailand select it.At the Deployment detail page for this component, click the Changes tab. Here’s what different events look like:
- A clean upgrade: One entry in the Updates panel, one entry in the Deletions panel, and one entry in the Creations panel, all close together in time
- A crash loop: Many entries in the Creations panel and Deletions panel, and no entries in the Updates panel
- An unexpected change looks like more than one entry in the Updates panel that appear at a time when nothing was planned
For specifically targeted issues, refer to the following subsections.
View potential deployment restarts
If you suspect a deployment is unstable or keeps crashing:
Look for any entries in the Creations panel. Every time a new instance of the deployment starts (after a crash, an upgrade, or a manual restart), an entry appears here.
A healthy deployment will have very few entries, or a small set around the time of a planned upgrade. If you see many entries scattered over time with no planned changes, the deployment has likely been repeatedly crashing and restarting.
Click the entry to view the metadata. This gives you information on what happened to what object, on what namespace and Cluster, with which collector, and when.
Investigate changes related to recent deployments
If you’re concerned about a deployment causing issues:
k8s-manifest-tailand select it. This component collects changes to resources on your Cluster.At the Deployment detail page for this component, click the Changes tab.
Look for any entries in the Updates panel. Every time the deployment’s configuration changes (a new version, adjusted settings, a modified resource limit) an entry appears here.
This is your audit trail. If something broke after a specific date, look here first to see if a configuration change happened around that time.
Confirm deployment removal or replacement
If you’re trying to confirm whether a deployment was cleanly upgraded, or whether it was unexpectedly removed:
Look for any entries in the Deletions panel. Whenever an instance is shut down or removed, an entry appears here. Deletions on their own aren’t necessarily a problem. During a normal upgrade, you’d expect to see a deletion paired with a creation shortly before or after. What’s worth investigating is deletions that have no matching creation, or a large number of deletions in a short period with no planned activity.
Resolve installation and upgrade failures
These issues occur when installing or upgrading Kubernetes Monitoring fails, or when collectors don’t deploy or run correctly.
If you have configured Kubernetes Monitoring with the Grafana Kubernetes Monitoring Helm chart, here are some general troubleshooting techniques:
- Within Kubernetes Monitoring, view the metrics status.
- Check what your values produce with
helm template <RELEASE_NAME> grafana/k8s-monitoring --values values.yaml, which renders the chart locally and writes the objects to standard output. - Check the
extraConfigsection of the Helm chart to ensure this section is not used for modifications. This section is only for additional configuration not already in the chart, and not for modifications to the chart.
Helm upgrade doesn’t apply changes to an existing collector
A helm upgrade of the Kubernetes Monitoring chart can complete successfully while leaving an existing collector
unchanged. This happens when the upgrade tries to modify a field that Kubernetes treats as immutable. Because the Alloy
Operator manages each collector through an internal Helm release, the operator’s reconciliation fails and rolls back
silently.
Symptoms
helm upgradeof thek8s-monitoringchart completes successfully.The Alloy custom resource shows the new configuration.
The underlying Alloy workload object is unchanged.
The Alloy Operator logs contain repeating errors:
"Release failed" ... "error":"upgrade failed; rollback required"Listing the operator’s internal Helm release history shows a
failedrevision followed by adeployedrollback:kubectl get secrets -l owner=helm,name=<collector-release-name> -o custom-columns=VERSION:.metadata.labels.version,STATUS:.metadata.labels.status
Cause
Several fields deployed by Alloy cannot be changed after creation. When the Alloy Operator reconciles an updated Alloy custom resource
that changes one of these fields, it runs an internal helm upgrade that tries to patch the existing workload.
Kubernetes rejects the patch, the internal release fails, and the operator rolls back.
An example is adding volumeClaimTemplates to a StatefulSet collector that was originally deployed without persistent
storage. The upgrade appears to succeed, but no PersistentVolumeClaim is ever created.
Workaround
Delete the affected Alloy custom resource before upgrading the chart. The operator uninstalls the managed workload cleanly as part
of deleting the custom resource, and the subsequent helm upgrade recreates both the custom resource and the workload with the new
configuration.
Identify the Alloy custom resource for the collector you are updating:
kubectl get alloy --all-namespacesDelete the custom resource and wait for it to be fully removed. This also deletes the underlying StatefulSet and Pods:
kubectl delete alloy <collector-name> --namespace <release-namespace> --wait=trueRun
helm upgradewith the new values.
The collector is recreated with the new configuration.
Update error
If you attempted to upgrade Kubernetes Monitoring with the Update button on the Cluster configuration tab under Configuration and received an error message, delete and recreate only the collector that failed to update. This preserves your alerting and recording rules.
List the collectors in your cluster:
kubectl get alloy --all-namespacesDelete the collector that failed to update and wait for it to be fully removed:
kubectl delete alloy <COLLECTOR_NAME> --namespace <RELEASE_NAMESPACE> --wait=trueRun
helm upgradewith your values. The collector is recreated with the new configuration.
For more details, refer to Helm upgrade doesn’t apply changes to an existing collector.
If you are unable to resolve the error, follow these steps to uninstall and reinstall the alert and recording rules.
Warning
When you perform an uninstall, this deletes the
integrations-kubernetesalert and recording rule namespace, including all alert and recording rules in that namespace. Re-installation creates new rules that are Grafana-managed alerts instead of data source-managed alerts. The two use separate contact points and notification policies, so if your rules were data source-managed, the routing you configured in the hosted Alertmanager no longer applies and you have to reconfigure it in the built-in Alertmanager of Grafana. For more information, refer to Alerting rule types.
Before you uninstall:
- Go to Alerts & IRM > Alerting > Alert rules and search for
namespace:integrations-kubernetes. - Export any custom alert rules you added to the
integrations-kubernetesnamespace. Use More > Duplicate to copy them to a different namespace, or export them using the export instructions. - Note any modified recording rules so you can recreate them after reinstalling.
To uninstall and reinstall:
- Click Uninstall.
- Click Install to reinstall.
- Complete the instructions in Configure with Grafana Kubernetes Monitoring Helm chart.
After reinstalling:
- Verify that alerting and recording rules are installed on the Metrics status tab.
- If your rules changed from data source-managed to Grafana-managed, reconfigure your notification routing in the built-in Alertmanager of Grafana. Refer to Configure contact points and Configure notification policies.
- Move any exported custom alert rules back into a namespace other than
integrations-kubernetesto prevent them from being deleted by future upgrades.
Helm install or upgrade stalls
A helm upgrade --install can stall indefinitely with no output because a previous install left the release in an uninstalling state. Helm won’t proceed while the release is stuck in this state. You could see one of these:
helm upgrade --install --atomic --timeout 300sstalls with no output.- Running
helm list -n <RELEASE_NAMESPACE>showsSTATUS: uninstalling.
This is due to a Helm hook job (a cleanup or finalizer job) from a previous failed install that never completed and left the release permanently stuck. To fix:
Confirm the release is stalled. If
STATUSshowsuninstalling, continue with the following steps:helm list -n <RELEASE_NAMESPACE> --allFind and delete the stuck hook jobs. Look for jobs with names containing
hook,cleanup, or matching your release name:kubectl get jobs -n <RELEASE_NAMESPACE> kubectl delete job <JOB_NAME> -n <RELEASE_NAMESPACE>Delete any stuck Pods from that job:
kubectl get pods -n <RELEASE_NAMESPACE> | grep -E "Error|Terminating|OOMKilled" kubectl delete pod <POD_NAME> -n <RELEASE_NAMESPACE> --force --grace-period=0Remove the stuck Helm release record. The
--no-hooksflag skips the finalizer jobs that caused the stall:helm delete <RELEASE_NAME> -n <RELEASE_NAMESPACE> --no-hooksVerify the release is gone, then reinstall. The first command should show nothing:
helm list -n <RELEASE_NAMESPACE> --all helm upgrade --install --atomic --timeout 300s <RELEASE_NAME> grafana/k8s-monitoring \ -n <RELEASE_NAMESPACE> -f values.yamlIf
helm delete --no-hooksalso stalls, you can remove the release record directly by deleting its Secret, then retry the previous step:kubectl delete secret -n <RELEASE_NAMESPACE> \ $(kubectl get secrets -n <RELEASE_NAMESPACE> \ -l owner=helm,name=<RELEASE_NAME> -o name)
No data in Grafana Cloud after installation
After you install the chart, the installation completes without an obvious error, but no metrics or logs appear in Grafana Cloud and your dashboards stay empty. If you check the collector Pods, they might not start, restart repeatedly, or run but send no data.
This usually means the collector (Alloy) can’t authenticate to Grafana Cloud, so it fails silently and sends no telemetry. The cause is typically a credential misconfiguration.
Cause
These misconfigurations can cause this:
- A credential field points at the wrong thing. For example,
auth.passwordKeyis set to the Secret’s name instead of the key within the Secret that holds the token, orauth.passwordis set to the Secret’s name instead of the token value. Alloy then has no valid credential and fails. - Confusion over cloud-specific credential variables. For example,
GCLOUD_RW_API_KEYrefers to your Grafana Cloud read/write API key (access policy token), not a Google Cloud key. Users that are running on AWS, Azure, or another provider may see this variable and not know what to substitute.
Solution
Point each credential field at the right value. Set
secret.nameto the name of your Secret, and setauth.usernameKeyandauth.passwordKeyto the keys inside that Secret, not the Secret’s name.Confirm the secret exists and contains the expected keys:
kubectl get secret <SECRET_NAME> -n <RELEASE_NAMESPACE> -o yamlSubstitute the correct Grafana Cloud credential.
GCLOUD_RW_API_KEYis your Grafana Cloud access policy token, regardless of which cloud provider hosts your Cluster. Use the token created during configuration. Refer to Grafana Cloud Access Policies.Because these failures are silent, find the collector Pods and check their status and logs to confirm the credential is the problem. The collectors run in the namespace where you installed the chart (
<RELEASE_NAMESPACE>).Note
Don’t rely on a Pod being named
alloy. You choose the collector names in the chart’scollectorsconfiguration, so the names vary between installations.From the Grafana UI: In the main menu, expand Observability, then click Kubernetes. Use Search and filter by Pods, or open your install namespace and review its Pods. Look for these signals:
- A Pod that won’t start: the status text appears in red. A red Running status means the Pod is failing to start, and a red Waiting status means it’s stuck on a problem such as
CrashLoopBackOfforImagePullBackOff. A green Running status is healthy. For the full color key, refer to Use color cues. - A Pod that restarts repeatedly: on the Pod or workload detail page, the restart count keeps climbing and the reason shows as
CrashLoopBackOff.
For more on navigating to these views, refer to Explore your infrastructure with Kubernetes Monitoring.
From the command line: List the Pods in the install namespace, then view the logs for any that are failing:
kubectl get pods -n <RELEASE_NAMESPACE> kubectl logs <POD_NAME> -n <RELEASE_NAMESPACE>To list the Pods for one collector, filter by its name label. The chart sets
app.kubernetes.io/nameto the collector’s key in yourcollectorsconfiguration, so the value is the name you chose, such asalloy-metricsoralloy-logs:kubectl get pods -n <RELEASE_NAMESPACE> -l app.kubernetes.io/name=<COLLECTOR_NAME>To see every collector, list all Pods in the namespace. Collector Pod names begin with your release name, followed by the collector name.
You can also inspect component status in the Alloy tool.
Couldn’t load repositories file
If you receive the following message when running the Helm chart installation generated by Grafana Cloud Error: Couldn't load repositories file (/root/.helm/repository/repositories.yaml). then run helm init. This is a common error for new installations of Kubernetes and K3s.
Invalid argument 300s
If you receive the following message when running the chart installation generated by Grafana Cloud Error: invalid argument 300s for --timeout flag: strconv.ParseInt: parsing 300s: invalid syntax, then you’re using an older version of Helm. Update to the latest version.
Kubernetes Cluster unreachable
For K3s deployments, if you receive the following message when running the Helm chart installation generated by Grafana Cloud Error: Kubernetes cluster unreachable: Get http://localhost:8080/version: dial tcp 127.0.0.1:8080: connect: connection refused, then execute the following command before you run Helm: export KUBECONFIG=/etc/rancher/k3s/k3s.yaml.
OpenShift security error
With the OpenShift default Security Context Constraints (SCC) of restricted (refer to the SCC documentation for more information), collector Pods can fail to start. The Pod events show errors similar to the following:
unable to validate against any security context constraint: [... spec.volumes[1]: Invalid value: "hostPath": hostPath volumes are not allowed to be used, spec.containers[0].securityContext.privileged: Invalid value: true: Privileged containers are not allowed ...]These errors occur because some collectors need permissions the restricted SCC doesn’t allow. For example, a collector that reads Pod log files mounts host directories with HostPath volumes.
This fix uses Helm chart v4 values. For earlier chart versions, refer to Version migration.
To resolve these errors, set the platform in your values file:
global:
platform: openshiftWith this setting, the chart creates a Security Context Constraints object tailored to each collector, along with a ClusterRole and ClusterRoleBinding that let the collector’s service account use it. You don’t need to patch any ClusterRole manually.
For a complete values file, including the seLinuxOptions setting the log collector requires to read Pod log files, refer to the OpenShift example in the Helm chart repository.
Kepler Pods crashing on AWS Graviton Nodes
Kepler cannot run on AWS Graviton Nodes; on these Nodes, the Kepler Pods enter a CrashLoopBackOff state.
In v4, the chart deploys Kepler through the telemetryServices.kepler key, and settings under that key pass through to the Kepler Helm chart. To keep Kepler off Graviton Nodes, add a Node selector:
telemetryServices:
kepler:
deploy: true
nodeSelector:
kubernetes.io/arch: amd64Specific Cluster platform providers
Certain Kubernetes Cluster platforms require some specific configurations for the Kubernetes Monitoring Helm chart. If your Cluster is running on one of these platforms, refer to the example for the changes required to run the Helm chart:
Resolve missing or incorrect data
These issues occur when Kubernetes Monitoring is deployed and running, but you don’t see the metrics, logs, traces, or profiles you expect, or the data looks wrong.
Duplicate metrics
Certain metric data sources (such as Node Exporter or kube-state-metrics) may already exist on the Cluster. In Helm chart v4, the chart deploys one of these services only when its telemetryServices.<SERVICE_NAME>.deploy value is true. Every deploy value defaults to false, but the values file generated during Cluster configuration can set them to true. If a service was already present on your Cluster, this deploys a second instance, and both get scraped. For earlier chart versions, which could deploy these services implicitly, refer to Version migration.
- Visit the Metrics status tab to view any duplicates.
- Remove the duplicates by setting
telemetryServices.<SERVICE_NAME>.deploytofalseand pointing the feature that scrapes the service at the existing instance. For example, for an existing Node Exporter, sethostMetrics.linuxHosts.namespaceandhostMetrics.linuxHosts.labelMatchersto match the existing Pods. Refer to Port conflicts and Node Exporter for a complete example.
Duplicate alerts and alert errors
You may temporarily see duplicate alerts for the same condition on the Alerts tab of the Kubernetes Overview page or in alert counts throughout Kubernetes Monitoring. If you are missing alert notifications, refer to Update error.
Cause
During the migration from Prometheus Alertmanager to Grafana-managed alerts, both alerting systems may fire alerts simultaneously for the same conditions, resulting in duplicates. Kubernetes Monitoring queries both alert sources (ALERTS and GRAFANA_ALERTS metrics) to ensure all alerts are detected during this transition period.
Solution
This is expected behavior during the migration period and requires no action. Duplicate alerts will automatically resolve after your Grafana Cloud stack completes the migration to Grafana-managed alerts.
If duplicate alerts persist after the migration is complete, contact Grafana Support.
CPU usage negative and missing data
If you have not installed Kubernetes Monitoring with the Helm chart and instead used the OTel collector deployed as a DaemonSet, you could have issues with CPU usage data. The OTel collector should be deployed as a Deployment. By using a DaemonSet, multiple samples may be written out of order to the same time series. This can cause Kubernetes Monitoring to show:
- Negative rates for CPU usage
- Gaps in usage showing on Optimization panels
- Unevenly spaced data points indicative of multiple sample ingestion, which may also be interpreted as counter resets
CPU usage panels missing data
If there is no CPU usage data, the data scraping intervals of the collector and the data source may not match. The default scraping interval for Grafana Alloy is 60 seconds. If the scraping interval for your data source is not 60 seconds, this mismatch may interfere with the calculation for CPU rate of usage.
To resolve, synchronize the scraping interval for the collector and data source.
- If you configured the data source (meaning it wasn’t automatically provisioned by Grafana Cloud), change the scrape interval for the data source to match the collector.
- If the data source was provisioned for you by Grafana Cloud, contact support to request the scrape interval for the data source be changed to match the collector.
Data missing in a panel
If a panel in Kubernetes Monitoring seems to be missing data or shows a “No data” message, you can use either the Debug Metrics feature or open the query for the panel in Explore to determine which query is failing.
This can occur when new features are released. For example, if you see no data in the network bandwidth and saturation panels, it is likely you need to upgrade to the newest version of the Helm chart.
Data missing for a provider
If your cloud service provider name is not showing up in the Cluster list page, it’s likely due to a provider_id missing from some types of Clusters. This occurs in the case of an internal provider or bare metal Clusters. To ensure your provider shows up, create a processing rule for the kube-state-metrics metrics.
clusterMetrics:
kube-state-metrics:
extraMetricProcessingRules: |-
rule {
source_labels = ["__name__", "provider_id", "node"]
separator = "@"
regex = "kube_node_info@@(.*)"
replacement = "<CLUSTER_PROVIDER_ID>://${1}"
action = "replace"
target_label = "provider_id"
}Replace <CLUSTER_PROVIDER_ID> with the provider ID you would like to appear in the Kubernetes Monitoring Cluster list page.
Efficiency usage data missing
If CPU and memory usage within any table shows no data, it could be due to missing Node Exporter metrics. Navigate to the Metrics status tab to determine what is not being reported.
Cost data missing or incorrect
If your Cost Monitoring pages look empty or the costs seem wrong, first check whether OpenCost is sending data:
- In Kubernetes Monitoring, click Configuration on the menu.
- Find the Cost metrics (OpenCost) panel and check its status icon:
- Check mark in a circle (green): OpenCost is sending data. If costs still look wrong, the issue may be with cloud provider pricing configuration.
- Caution with exclamation mark (yellow): Data is arriving, but something needs attention, such as duplicate metrics.
- X in a circle (red): No cost data is coming through.
If you see a red X or yellow caution, click the icon next to the panel title to open the query in Explore for more detail.
If you see a green check mark but costs still look wrong, OpenCost might not have access to your cloud provider’s pricing API. In this case, OpenCost falls back to default pricing estimates, which might not reflect your actual costs. Check the OpenCost Pod logs for pricing-related warnings to confirm.
Job data missing
If you are missing jobs data, make sure you are collecting the following metrics:
kube_cronjob_infokube_cronjob_next_schedule_timekube_cronjob_spec_suspendkube_cronjob_status_last_schedule_timekube_cronjob_status_last_successful_timekube_job_infokube_job_ownerkube_job_spec_completionskube_job_status_completion_timekube_job_status_failedkube_job_status_start_timekube_job_status_succeededkube_namespace_status_phasekube_node_infokube_pod_completion_timekube_pod_container_status_last_terminated_timestampkube_pod_ownerkube_pod_restart_policy
Metrics missing
If metrics are missing even though the Metrics status tab is showing that the configuration is set up as you intended, check for an incorrectly configured label for the Node Exporter instance.
Make sure the Node Exporter instance label is set to the Node name. The labels for kube-state-metrics node and Node Exporter instance must contain the same values.
Methodology for missing metrics
It’s helpful to keep in mind the different phases of metrics gathering when debugging.
Discovery
Find the metric source. In this phase, find out whether the tool to gather metrics is working. For example, is Node Exporter running? Can Alloy find Node Exporter? Perhaps there’s configuration that is incorrect because Alloy is looking in a namespace or for a specific label.
Scraping
Ask whether the metrics were gathered correctly. As an example, most metric sources use HTTP, but the metric source you are trying to find uses HTTPS. Identify whether the configuration is set for scraping HTTPS.
Processing
Ask whether metrics were correctly processed. With Kubernetes Monitoring, metrics are filtered to a small subset of the useful metrics.
Delivery
In this phase, metrics are sent to Grafana Cloud. If there is an issue, there are likely no metrics being delivered. This can occur if your account limits for metrics is reached. Check the Usage Insights - 5 - Metrics Ingestion dashboard.
Displaying
In this phase, a metric is not showing up in the Kubernetes Monitoring GUI. If you’ve determined the metrics are being delivered but some are not displaying, there may be a missing or incorrect label for the metric. Check the Metrics status tab.
Pod logs missing
If you are not seeing Pod logs and your platform is AWS EKS Fargate, these logs cannot be gathered using a hostpath volume mount. Instead, you can use API-based log gathering. For greater detail, refer to EKS Fargate.
Network metrics missing
If you have deployed on the AWS EKS Fargate platform, AWS prevents a level of access that Node Exporter requires to gather metrics for the network panels. EKS Fargate provides on-demand compute for Kubernetes objects instead of the traditional means where these objects run on Nodes.
Node Exporter opens host port 9100 on the Kubernetes Node. If there already is a Node Exporter being used, the two exporters experience conflict with their respective default ports. To avoid this conflict, you have two options.
Both options use Helm chart v4 values. For earlier chart versions, refer to Version migration.
You can change the Node Exporter port number, so the Node Exporter deployed by the Kubernetes Monitoring Helm chart does
not conflict with the existing Node Exporter. Settings under telemetryServices.node-exporter pass through to the Node
Exporter Helm chart, and service.port sets the port the exporter listens on. Add the following to your values.yaml
file:
telemetryServices:
node-exporter:
deploy: true
service:
port: 9101 # Choose an unused portAlternatively, you can skip deploying another Node Exporter and scrape the existing one. Set
telemetryServices.node-exporter.deploy to false, then tell the hostMetrics feature where to find the existing
instance:
telemetryServices:
node-exporter:
deploy: false
hostMetrics:
enabled: true
linuxHosts:
enabled: true
namespace: <NAMESPACE_OF_EXISTING_NODE_EXPORTER>
labelMatchers: # Customize to match the existing Node Exporter Pod labels
app.kubernetes.io/name: node-exporterProfiling data missing or showing unexpected results
If Pyroscope is configured and collecting profiles but you see either of the following, the cause is likely a label name mismatch:
- The Profiles section on a workload or Pod detail page shows “No profiling data available.”
- The Profiles column in workload tables is disabled with “No profiling data found.”
A label mismatch can also cause a flame graph to display data from the wrong service without any error. This happens because Kubernetes Monitoring falls back to searching all services in Pyroscope when the scoped query fails. And it may incorrectly match a different service that shares part of the workload name. If a flame graph looks unexpected for a workload (for example, it shows function names you don’t recognize or resource usage that doesn’t match what your metrics report), a label mismatch is a likely cause.
Why this happens
Kubernetes Monitoring queries Pyroscope using the labels service_name, pod, namespace, and cluster by default. If your Pyroscope setup uses different label names (for example, k8s.namespace.name instead of namespace, or k8s.pod.name instead of pod), the scoped queries return no results. The integration then falls back to broader, unscoped queries, which can either find no match or match the wrong service.
How to fix it
Configure the label mapping so Kubernetes Monitoring uses the correct Pyroscope label names:
- Open the Profiles Drilldown app.
- Navigate to the settings page.
- In the Kubernetes Label Mapping section, select your Pyroscope data source.
- Update the label names to match the labels used in your Pyroscope data. For example, change
namespacetok8s.namespace.name. - Click Save.
After saving, return to Kubernetes Monitoring and refresh the workload or Pod detail page. The flame graph and Profiles links should now display the correct data.
Workload data missing
If you are seeing Pod resource usage but not workloads usage data, the recording rules and alert rules are likely not installed.
When these rules aren’t installed, Kubernetes Monitoring displays a banner across all pages. Click Install Now in the banner to go directly to the configuration step that installs them.
You can also install the rules following these steps:
- Navigate to the Configuration page.
- In the Workload Recording Rule panel, click Install to install alert rules and recording rules.
Authentication error: invalid scope requested
To deliver telemetry data to Grafana Cloud, you use an Access Policy Token with the appropriate scopes.
Scopes define an action that can be done to a specific data type.
For example metrics:write permits writing metrics.
If sending data to Grafana Cloud, the Helm chart uses the <data>:write scopes for delivering data.
If your token does not have the correct scope, you see errors in the Grafana Alloy logs.
For example, when trying to deliver profiles to Pyroscope without the profiles:write scope:
msg="final error sending to profiles to endpoint" component=pyroscope.write.profiles_service endpoint=https://tempo-prod-1-prod-eu-west-2.grafana.net:443 err="unauthenticated: authentication error: invalid scope requested"The following table shows the scopes required for various actions done by this chart:
ResourceExhausted error when sending traces
You might encounter the following if you have traces enabled and you see log entries in your alloy instance that looks like this:
Permanent error: rpc error: code = ResourceExhausted desc = grpc: received message after decompression larger than max (5268750 vs. 4194304)" dropped_items=11226
ts=2024-09-19T19:52:35.16668052Z level=info msg="rejoining peers" service=cluster peers_count=1 peers=6436336134343433.grafana-k8s-monitoring-alloy-cluster.default.svc.cluster.local.:12345This error is likely due to the span size being too large. To fix this, adjust the batch size.
applicationObservability:
processors:
batch:
maxSize: 2000Set both values: maxSize must be greater than or equal to size, and size defaults to 8192. Start with 2000 and adjust as needed.
Traces missing with Istio service mesh
If traces are not appearing in Grafana Cloud Traces when Istio service mesh is deployed in your Cluster, this is likely due to the protocol detection requirements of Istio. Istio identifies a Kubernetes Service port as gRPC when the port sets appProtocol: grpc, or when the port name is grpc or starts with grpc- (for example, grpc-otlp). If both are set, appProtocol takes precedence. Without one of these, Istio cannot identify the port as using the gRPC protocol, and cannot properly route trace data from your applications to the collector.
In Helm chart v4, when you enable the OTLP gRPC receiver with applicationObservability.receivers.otlp.grpc.enabled, the chart adds a Service port named otlp-grpc with appProtocol: grpc to the collector that hosts the receivers. This satisfies the protocol detection requirements of Istio. For earlier chart versions, refer to Version migration.
If you define your own receiver ports with collectors.<COLLECTOR_NAME>.alloy.extraPorts, the chart doesn’t add its own entry for the same port number, and your definition controls the Service port. Make sure each gRPC port either sets appProtocol: grpc or uses a compliant name:
collectors:
<COLLECTOR_NAME>:
alloy:
extraPorts:
- name: grpc-otlp # Must be "grpc" or "grpc-<suffix>" unless appProtocol is set
port: 4317
targetPort: 4317
protocol: TCP
appProtocol: grpcThis Istio protocol detection requirement applies to the Kubernetes Service that exposes the OTLP gRPC port for Grafana Alloy or any other OpenTelemetry Collector running under Istio service mesh. For more information about Istio protocol selection, refer to the Istio protocol selection documentation.
