WSO2 Enterprise Integrator integration for Grafana Cloud
WSO2 Enterprise Integrator 7.1.0 is a powerful configuration-driven approach to integration, which allows developers to build integration solutions graphically.
This is a hybrid platform that enables API-centric integration and supports various integration architecture styles: microservices architecture, cloud-native architecture, or a centralized ESB architecture. This integration platform offers a graphical/configuration-driven approach to developing integrations for any of the architectural styles.
This integration includes 5 pre-built dashboards to help monitor and visualize WSO2 Enterprise Integrator metrics.
Before you begin
In order for this integration to work, you have to enable the Prometheus endpoint on your WSO2 Enterprise Integrator nodes. Please refer to the official documentation.
Install WSO2 Enterprise Integrator integration for Grafana Cloud
- Find WSO2 Enterprise Integrator and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send WSO2 Enterprise Integrator metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards to your Grafana Cloud instance, and you can start monitoring your WSO2 Enterprise Integrator setup.
Advanced mode
To instruct Grafana Alloy to scrape your WSO2 Enterprise Integrator instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_wso2_enterprise_integrator" {
targets = [{
__address__ = "wso2-ei-node:9201",
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "wso2_cluster"
replacement = "<your-cluster-name>"
prometheus.scrape "metrics_integrations_integrations_wso2_enterprise_integrator" {
targets = discovery.relabel.metrics_integrations_integrations_wso2_enterprise_integrator.output
job_name = "integrations/wso2-enterprise-integrator"
metrics_path = "/metric-service/metrics"
To monitor your WSO2 Enterprise Integrator instance, you must use a discovery.relabel component to discover your WSO2 Enterprise Integrator Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your WSO2 Enterprise Integrator Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this WSO2 Enterprise Integrator instance.wso2_cluster
: Thewso2_cluster
label to group your WSO2 Enterprise Integrator instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple WSO2 Enterprise Integrator servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the WSO2 Enterprise Integrator integration
After enabling the metrics generation, instruct Grafana Agent to scrape your WSO2 nodes.
WSO2 exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/wso2-enterprise-integrator
metrics_path: '/metric-service/metrics'
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- replacement: '<your-cluster-name>'
target_label: wso2_cluster
static_configs:
- targets: ['wso2-ei-node:9201']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the WSO2 Enterprise Integrator integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The WSO2 Enterprise Integrator integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- WSO2 API Metrics
- WSO2 Inbound Endpoint Metrics
- WSO2 Integration Cluster Metrics
- WSO2 Integration Node Metrics
- WSO2 Proxy Service Metrics
Cluster Overview
Node Overview
Apis Overview
Metrics
The most important metrics provided by the WSO2 Enterprise Integrator integration, which are used on the pre-built dashboards, are as follows:
- jvm_memory_bytes_max
- jvm_memory_bytes_used
- jvm_threads_state
- process_cpu_seconds_total
- process_max_fds
- process_open_fds
- up
- wso2_integration_api_latency_seconds
- wso2_integration_api_request_count_error_total
- wso2_integration_api_request_count_total
- wso2_integration_inbound_endpoint_latency_seconds
- wso2_integration_inbound_endpoint_request_count_error_total
- wso2_integration_inbound_endpoint_request_count_total
- wso2_integration_proxy_inbound_endpoint_count_total
- wso2_integration_proxy_latency_seconds
- wso2_integration_proxy_request_count_error_total
- wso2_integration_proxy_request_count_total
- wso2_integration_server_up
- wso2_integration_service_up
Changelog
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.6 - September 2023
# 0.0.5 - February 2023
* Bugfix - remove unused link
# 0.0.4 - January 2023
* Add job variable filter to all dashboards.
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
* Update mixin to latest version:
- Update queries to use $__rate_interval
# 0.0.1 - September 2021
* Initial release
Cost
By connecting your WSO2 Enterprise Integrator instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
