Vault integration
Vault integration for Grafana Cloud
HashiCorp Vault secures, stores, and controls access to tokens, passwords, certificates, API keys, and other secrets in modern computing. This integration allows you to monitor metrics from Vault.
This integration includes 1 pre-built dashboard to help monitor and visualize Vault metrics.
Before you begin
To enable the Prometheus metrics endpoint, you need to activate it in your Vault node.
To do so, add the following snippet to your node configuration file.
json
telemetry {
  disable_hostname = true
  prometheus_retention_time = "12h"
It is also necessary to issue an auth token for Prometheus to scrape the metrics endpoint, which is protected. For further guidance, refer to the official Vault documentation provided in this section.
Install Vault integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Vault and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Vault metrics to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Vault setup.
Simple mode
These snippets are configured to scrape a single Vault instance running locally with default ports.
Metrics snippets
alloy
discovery.relabel "metrics_integrations_integrations_vault" {
	targets = [{
		__address__ = "localhost:8200",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_vault" {
	targets    = discovery.relabel.metrics_integrations_integrations_vault.output
	job_name   = "integrations/vault"
	params     = {
		format = ["prometheus"],
	metrics_path = "/v1/sys/metrics"
	authorization {
		type             = "Bearer"
		credentials_file = "/etc/prometheus/prometheus-token"
Advanced mode
To instruct Grafana Alloy to scrape your Vault instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
alloy
	targets = [{
	rule {
	params     = {
	authorization {
		type             = "Bearer"
To monitor your Vault instance, you must use a discovery.relabel component to discover your Vault Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
  • __address__: The address to your Vault Prometheus metrics endpoint.
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Vault instance.
If you have multiple Vault servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Dashboards
The Vault integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Hashicorp Vault
Vault overview
Vault overview
Metrics
The most important metrics provided by the Vault integration, which are used on the pre-built dashboard, are as follows:
  • up
  • vault_audit_log_request_count
  • vault_audit_log_request_failure
  • vault_audit_log_response_count
  • vault_audit_log_response_failure
  • vault_consul_delete_count
  • vault_consul_get_count
  • vault_consul_list_count
  • vault_consul_put_count
  • vault_core_active
  • vault_core_handle_request_count
  • vault_core_unsealed
  • vault_expire_num_leases
  • vault_identity_num_entities
  • vault_policy_get_policy_count
  • vault_policy_set_policy_count
  • vault_runtime_alloc_bytes
  • vault_runtime_heap_objects
  • vault_runtime_malloc_count
  • vault_runtime_num_goroutines
  • vault_secret_kv_count
  • vault_token_count
  • vault_token_count_by_auth
  • vault_token_count_by_policy
  • vault_token_count_by_ttl
  • vault_token_create_count
  • vault_token_creation
  • vault_token_lookup_count
  • vault_token_store_count
Changelog
md
# 0.0.4 - September 2023
# 0.0.3 - December 2022
* Change panels to timeseries
* Change old bar charts to new bar gauges
* Add job, instance selectors
* Fix secrets table, add gauge to the table
# 0.0.2 - October 2022
* Updating mixin with the latest piechart panel
# 0.0.1 - October 2021
* Initial release
Cost
By connecting your Vault instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
