Varnish Cache integration for Grafana Cloud
Varnish Cache is an open source web application accelerator, also called a caching HTTP reverse proxy. This integration for Grafana Cloud allows users to collect metrics and logs for their Varnish system.
Varnish Cache integration for Grafana cloud provides a streamlined way for users to easily monitor their Varnish system with little overhead while getting the crucial information they need.
This integration supports Varnish Cache 6.0 LTS.
This integration includes 6 useful alerts and 1 pre-built dashboard to help monitor and visualize Varnish Cache metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the Varnish Cache exporter for Prometheus to export metrics from Varnish.
Set up Varnish Cache exporter
Install the version of the exporter that corresponds to your operating system. The latest releases and installs can be found on
exporter installation.
To start the exporter first unzip the file that you downloaded above and traverse to the directory where the executable is. The executable will be named similar to prometheus_varnish_exporter
. An example of the exporter being run is shown below:
sudo ./prometheus_varnish_exporter
The above will run a
varnishstat -j
behind the scenes and open a port 9131
that can be accessed through localhost:9131
. The exported Prometheus metrics can be seen at localhost:9131/metrics
The exporter exposes port 9131
by default but you can change this using the -web.listen-address
flag when running the exporter. The use of this flag would look like this:
sudo ./prometheus_varnish_exporter -web.listen-address localhost:9595
If you have multiple Varnish instances, you must specify which you are targeting with the exporter. This can be done by running the exporter with the flag -n
and the name of your varnish instance. Example shown below:
sudo ./prometheus_varnish_exporter -n <instance_name>
This also means you would need one exporter for each instance of Varnish Cache, each with a unique port.
For more options and help with the exporter, you can run the below command:
sudo ./prometheus_varnish_exporter -h
Once deployed, Grafana Alloy should be able to reach the Varnish Cache exporter’s exposed endpoint in order to scrape metrics.
Set up Varnish Cache logging
This integration leverages the varnishncsa
utility provided by Varnish in order to produce formatted logs. Any format of log collection with varnishncsa
will be picked up by the integration.
In order to setup varnishncsa
, the utility must be enabled by running:
sudo systemctl enable varnishncsa
sudo systemctl start varnishncsa
By default this integration provides two commands that enable frontend and backend logging capabilities. Since Varnish does not naturally record logs into a file, a log path must be specified for varnishncsa
to write to.
For darwin and linux systems respectively, the paths need to be /opt/varnish/log
and /var/log/varnish
Note: replace <instance_name>
and <log_path>
with the respective names of the instance and log path. If there is only one instance, then the -n <instance_name>
flag can be removed. The below commands must be re-run for each instance that log collection is required for.
sudo varnishncsa -n <instance_name> -F '{"Timestamp": "%t", "Varnish-Side": "%{Varnish:side}x", "Age": %{age}o, "Handling": "%{Varnish:handling}x", "Request": "%r", "Status": "%s", "Response-Reason": "%{VSL:RespReason}x", "Fetch-Error": "%{VSL:FetchError}x", "X-Forwarded-For": "%{x-forwarded-for}i", "Remote-User": "%u", "Bytes": "%b", "Time-To-Serve": %D, "User-Agent": "%{User-agent}i", "Referer": "%{Referer}i", "X-Varnish": "%{x-varnish}o", "X-Magento-Tags": "%{x-magento-tags}o"}}' -D -w <log_path>/varnishncsa-frontend.log
sudo varnishncsa -n <instance_name> -b -F '{"Timestamp": "%t", "Varnish-Side": "%{Varnish:side}x", "Handling": "%{Varnish:handling}x", "Request": "%r", "Status": "%s", "Response-Reason": "%{VSL:RespReason}x", "Fetch-Error": "%{VSL:FetchError}x", "Bytes": "%b", "Time-To-Serve": %D}' -D -w <log_path>/varnishncsa-backend.log
For multiple instances, configure the files where logs are written to follow the following naming convention:
varnishncsa-frontend-<instance_name>.log
varnishncsa-backend-<instance_name>.log
Install Varnish Cache integration for Grafana Cloud
- Find Varnish Cache and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Varnish Cache metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Varnish Cache setup.
Advanced mode
To instruct Grafana Alloy to scrape your Varnish Cache instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_varnish_cache" {
targets = [{
__address__ = "<exporter_host>:<exporter_port>",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_varnish_cache" {
targets = discovery.relabel.metrics_integrations_integrations_varnish_cache.output
job_name = "integrations/varnish-cache"
To monitor your Varnish Cache instance, you must use a discovery.relabel component to discover your Varnish Cache Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Varnish Cache Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Varnish Cache instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple Varnish Cache servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
local.file_match "logs_integrations_integrations_varnish_cache" {
path_targets = [{
__address__ = "localhost",
__path__ = "<log_path>/varnishncsa*.log",
instance = constants.hostname,
job = "integrations/varnish-cache",
loki.source.file "logs_integrations_integrations_varnish_cache" {
targets = local.file_match.logs_integrations_integrations_varnish_cache.targets
forward_to = [loki.write.grafana_cloud_loki.receiver]
To monitor your Varnish Cache instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Varnish Cache instance address__path__
: The path to the log file.instance
sets theinstance
loki.source.file sends logs to Loki.
Kubernetes log collection
These instructions assume the use of the official Varnish helm chart.
In the sample application, we generated YAML from the official helm chart and customized it in the following ways:
- Add an initContainer that mounts the volume for logs and creates the log files to be written to.
- Add two
varnishncsa
sidecars, one for frontend logs, the other for backend logs. - Add one Alloy sidecar with appropriate volumeMounts to the log files and the custom Alloy configuration
The Varnish cache container, the initContainer, and the
varnishncsa
sidecars must be run as thevarnishlog
user. In the following YAML examples, you’ll noticerunAsUser
is set to thevarnishlog
user ID, which may be different in your environment.
Log file initContainer
This example is for one instance, where only one log file exists per log type.
Here’s an example snippet for creating an initContainer that mounts the log file location and creates the necessary log files:
initContainers:
- name: init-script
image: alpine:latest
securityContext:
runAsNonRoot: true
runAsUser: 103
command: ['sh', '-c', 'touch /var/log/varnish/varnishncsa-frontend.log /var/log/varnish/varnishncsa-backend.log && chmod 666 /var/log/varnish/*.log']
volumeMounts:
- name: varnish-log
mountPath: /var/log/varnish
Varnish log sidecars
The varnishncsa
sidecars for logging need to be deployed with the appropriate arguments and volume mounts. Refer to the this example deployment for details on the varnishncsa
arguments.
Here is an example snippet for the frontend logs sidecar:
- name: varnish-cache-ncsa-frontend
securityContext:
runAsNonRoot: true
runAsUser: 103
image: {{ .Values.varnishImage }}
imagePullPolicy: IfNotPresent
command: ["/bin/sh", "-c"]
args: ["varnishncsa -n /var/lib/varnish -F '{\"Timestamp\": \"%t\", \"Varnish-Side\": \"%{Varnish:side}x\", \"Age\": %{age}o, \"Handling\": \"%{Varnish:handling}x\", \"Request\": \"%r\", \"Status\": \"%s\", \"Response-Reason\": \"%{VSL:RespReason}x\", \"Fetch-Error\": \"%{VSL:FetchError}x\", \"X-Forwarded-For\": \"%{x-forwarded-for}i\", \"Remote-User\": \"%u\", \"Bytes\": \"%b\", \"Time-To-Serve\": %D, \"User-Agent\": \"%{User-agent}i\", \"Referer\": \"%{Referer}i\", \"X-Varnish\": \"%{x-varnish}o\", \"X-Magento-Tags\": \"%{x-magento-tags}o\"}' -w /var/log/varnish/varnishncsa-frontend.log"]
volumeMounts:
- name: custom-varnish-vsm
mountPath: /var/lib/varnish
readOnly: true
- name: varnish-secret
mountPath: /etc/varnish/secret
subPath: secret
- name: varnish-log
Alloy sidecar
The Alloy sidecar is configured to collect logs from each file. Here’s an example snippet:
linux
path_targets = [{
__address__
sets theinstance
- Add two
varnishncsa
varnishncsa
initContainers:
- name: init-script
securityContext:
runAsNonRoot: true
runAsUser: 103
volumeMounts:
- name: varnish-log
The varnishncsa
arguments.
securityContext:
runAsNonRoot: true
runAsUser: 103
volumeMounts:
readOnly: true
subPath: secret
- name: varnish-log
Alloy sidecar
varnishstat -j
Once deployed, the Grafana Agent should be able to reach the Varnish Cache exporter’s exposed endpoint in order to scrape metrics.
to write to.
and <log_path>
Post-install configuration for the Varnish Cache integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your Varnish Cache metrics.
The exporter exposes a default Prometheus endpoint route in the /metrics
format endpoint. To scrape it, add the snippet in the next step to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
andinstance
label values must match for the Varnish Cache integration andlogs
scrape config in your agent configuration file.job
label must be set tointegrations/varnish-cache
(already configured in the snippets)instance
label must be set to a value that uniquely identifies your Varnish Cache instance. Please replace the defaultvarnish_host
value according to your environment - it should be set manually. Note that if you uselocalhost
for multiple instances, the dashboards will not be able to filter correctly by instance.
- job_name: integrations/varnish-cache
metrics_path: /metrics
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets:
- '<exporter_host>:<exporter_port>'
static_configs:
- targets: [localhost]
labels:
job: integrations/varnish-cache
instance: '<your-instance-name>'
__path__: '<log_path>/varnishncsa*.log'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Varnish Cache integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
- targets:
global:
scrape_interval: 60s
Dashboards
The Varnish Cache integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Varnish overview
Varnish Cache overview (overview)
Varnish Cache overview (logs)
Alerts
The Varnish Cache integration includes the following useful alerts:
Metrics
The most important metrics provided by the Varnish Cache integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- up
- varnish_backend_beresp_bodybytes
- varnish_backend_beresp_hdrbytes
- varnish_main_backend_busy
- varnish_main_backend_conn
- varnish_main_backend_recycle
- varnish_main_backend_req
- varnish_main_backend_reuse
- varnish_main_backend_unhealthy
- varnish_main_cache_hit
- varnish_main_cache_hitpass
- varnish_main_cache_miss
- varnish_main_client_req
- varnish_main_n_expired
- varnish_main_n_lru_nuked
- varnish_main_pools
- varnish_main_s_resp_bodybytes
- varnish_main_s_resp_hdrbytes
- varnish_main_sessions
- varnish_main_sessions_total
- varnish_main_thread_queue_len
- varnish_main_threads
- varnish_main_threads_created
- varnish_main_threads_failed
- varnish_main_threads_limited
- varnish_sma_g_bytes
- varnish_sma_g_space
Changelog
# 1.0.0 - August 2024
* Add Kubernetes as a supported platform using Grafana Alloy
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial release
Cost
By connecting your Varnish Cache instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
