Ubiquiti EdgeRouter integration for Grafana Cloud
Ubiquiti EdgeRouter dashboard lets you see vital metrics on throughput, errors, and traffic distribution.
This integration includes 1 pre-built dashboard to help monitor and visualize Ubiquiti EdgeRouter metrics.
Before you begin
You must enable the SNMP service on your router before Grafana Alloy can scrape metrics from it.
You can find details on how to enable SNMP on your router in the official Ubiquiti support docs.
Install Ubiquiti EdgeRouter integration for Grafana Cloud
- Find Ubiquiti EdgeRouter and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Ubiquiti EdgeRouter metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Ubiquiti EdgeRouter setup.
Advanced mode
To instruct Grafana Alloy to scrape your Ubiquiti EdgeRouter instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.snmp component to generate metrics from a Ubiquiti EdgeRouter instance.
This integration requires a specific module that defines only the SNMP OIDs used by this dashboard.
If you are familiar with the SNMP exporter, and are generating your own configuration for it, you can find the definition for the required ubnt_router
module here.
Otherwise, you can use the pre-generated config which includes only this module here.
In either case, you need to add the path to your fully rendered snmp.yml
with the ubnt_router
module or the pre-generated config to the prometheus.exporter.snmp
component. Note the config_file
parameter in the provided example snippet.
For the full array of configuration options, refer to the prometheus.exporter.snmp component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Ubiquiti EdgeRouter instance to be monitored you must create add a target
component, making sure to change <router_1_address>
to the hostname or IP address of the target router.
You must enable the SNMP service on your router before Grafana Agent can scrape metrics from it.
Post-install configuration for the Ubiquiti EdgeRouter integration
This integration is configured to work with the snmp_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the provided snippet to your agent configuration file.
module here.
module or the pre-generated config to the SNMP configuration of your agent. Note the config_file:
Be sure to replace <router_1_address>
with the hostname or IP of your router.
For a full description of configuration options see how to configure the snmp
block in the agent documentation.
Below integrations
snmp:
enabled: true
config_file: '</path/to/snmp.yml>'
snmp_targets:
- name: router_1
address: '<router_1_address>'
module: ubnt_router
walk_params: ubnt_router
walk_params:
ubnt_router:
version: 2
auth:
community: public
relabel_configs:
- replacement: integrations/ubiquiti-edgerouter
target_label: job
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Ubiquiti EdgeRouter integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
snmp:
enabled: true
snmp_targets:
- name: router_1
module: ubnt_router
walk_params:
ubnt_router:
version: 2
auth:
community: public
relabel_configs:
target_label: job
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The Ubiquiti EdgeRouter integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Ubiquiti EdgeRouter Overview
System Identification, Uptime & System, CPU
Memory, Interface
IP
Metrics
The most important metrics provided by the Ubiquiti EdgeRouter integration, which are used on the pre-built dashboard, are as follows:
- hrProcessorLoad
- hrStorageSize
- hrStorageUsed
- hrSystemNumUsers
- hrSystemProcesses
- hrSystemUptime
- icmpMsgStatsInPkts
- icmpMsgStatsOutPkts
- icmpStatsInErrors
- icmpStatsInMsgs
- icmpStatsOutErrors
- icmpStatsOutMsgs
- ifHCInBroadcastPkts
- ifHCInMulticastPkts
- ifHCInOctets
- ifHCInUcastPkts
- ifHCOutBroadcastPkts
- ifHCOutMulticastPkts
- ifHCOutOctets
- ifHCOutUcastPkts
- ifInDiscards
- ifInErrors
- ifInUnknownProtos
- ifNiceName
- ifOutDiscards
- ifOutErrors
- inetCidrRouteNumber
- ipForwardNumber
- ipRoutingDiscards
- ipSystemStatsHCInBcastPkts
- ipSystemStatsHCInDelivers
- ipSystemStatsHCInForwDatagrams
- ipSystemStatsHCInMcastPkts
- ipSystemStatsHCInReceives
- ipSystemStatsHCOutBcastPkts
- ipSystemStatsHCOutForwDatagrams
- ipSystemStatsHCOutMcastPkts
- ipSystemStatsHCOutRequests
- ipSystemStatsHCOutTransmits
- ipSystemStatsInAddrErrors
- ipSystemStatsInDiscards
- ipSystemStatsInHdrErrors
- ipSystemStatsInNoRoutes
- ipSystemStatsInTruncatedPkts
- ipSystemStatsInUnknownProtos
- ipSystemStatsOutDiscards
- ipSystemStatsOutFragCreates
- ipSystemStatsOutFragFails
- ipSystemStatsOutFragOKs
- ipSystemStatsOutFragReqds
- ipSystemStatsOutNoRoutes
- ipSystemStatsReasmFails
- ipSystemStatsReasmOKs
- ipSystemStatsReasmReqds
- laLoadInt
- memAvailReal
- memBuffer
- memCached
- memShared
- memTotalFree
- snmpInGetNexts
- snmpInGetRequests
- snmpInGetResponses
- snmpInPkts
- snmpInTotalReqVars
- snmpOutGetNexts
- snmpOutGetRequests
- snmpOutGetResponses
- snmpOutPkts
- ssCpuRawIdle
- ssCpuRawInterrupt
- ssCpuRawKernel
- ssCpuRawNice
- ssCpuRawSoftIRQ
- ssCpuRawSystem
- ssCpuRawUser
- ssCpuRawWait
- ssIORawReceived
- ssIORawSent
- ssRawContexts
- ssRawInterrupts
- sysContact
- sysDescr
- sysLocation
- sysName
- tcpActiveOpens
- tcpAttemptFails
- tcpCurrEstab
- tcpEstabResets
- tcpInErrs
- tcpInSegs
- tcpOutRsts
- tcpOutSegs
- tcpPassiveOpens
- tcpRetransSegs
- udpInDatagrams
- udpInErrors
- udpNoPorts
- udpOutDatagrams
- up
Changelog
# 0.0.3 - September 2023
# 0.0.2 - May 2023
* Updated prometheus job name to differ from SNMP Integration. No need to update if you are using the old job name.
# 0.0.1 - October 2022
* Initial Release
Cost
By connecting your Ubiquiti EdgeRouter instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
