Traefik integration for Grafana Cloud
Traefik is a dynamic load balancer designed for ease of configuration, especially in dynamic environments. It supports automatic discovery of services, metrics, tracing, and has Let’s Encrypt support out of the box. Traefik provides a “ready to go” system for serving production traffic with these additions.
This integration includes 1 pre-built dashboard to help monitor and visualize Traefik metrics.
Before you begin
You need to enable the Prometheus metrics endpoint in your Traefik node. Please follow the official documentation.
Install Traefik integration for Grafana Cloud
- Find Traefik and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Traefik metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Traefik setup.
Simple mode
These snippets are configured to scrape a single Traefik instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_traefik" {
targets = [{
__address__ = "localhost:8080",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_traefik" {
targets = discovery.relabel.metrics_integrations_integrations_traefik.output
job_name = "integrations/traefik"
Advanced mode
To instruct Grafana Alloy to scrape your Traefik instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Traefik instance, you must use a discovery.relabel component to discover your Traefik Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Traefik Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Traefik instance.
If you have multiple Traefik servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the Traefik integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Traefik nodes.
Traefik exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/traefik
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8080']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Traefik integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Traefik integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Traefik
Service Stats Overview
Service Stats Filter
Metrics
The most important metrics provided by the Traefik integration, which are used on the pre-built dashboard, are as follows:
- traefik_entrypoint_requests_total
- traefik_service_request_duration_seconds_sum
- traefik_service_requests_total
- up
Changelog
Cost
By connecting your Traefik instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
