Squid integration for Grafana Cloud
Squid is a popular open-source proxy server that is used to improve web performance and provide content caching for web clients. The Squid integration uses Grafana Alloy to collect metrics for monitoring a Squid instance, including aspects such as cache hits & miss service time, cache hit ratios, client and server requests, server object swaps, and DNS lookup service time. The integration also supports Squid logs being scraped by Alloy using Promtail. An accompanying dashboard is provided to visualize these metrics and logs.
This integration supports Squid 5+.
This integration includes 5 useful alerts and 1 pre-built dashboard to help monitor and visualize Squid metrics and logs.
Before you begin
This integration monitors a Squid proxy server instance.
In order to scrape these metrics, you must have a running and reachable Squid instance.
Install Squid integration for Grafana Cloud
- Find Squid and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Squid metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Squid setup.
Simple mode
These snippets are configured to scrape a single Squid instance running locally with default ports.
Logs snippets
darwin
local.file_match "logs_integrations_integrations_squid" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "/var/log/squid/cache.log",
		instance    = constants.hostname,
		job         = "integrations/squid",
		__path__    = "/var/log/squid/access.log",
loki.source.file "logs_integrations_integrations_squid" {
	targets    = local.file_match.logs_integrations_integrations_squid.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
}linux
	path_targets = [{
}windows
	path_targets = [{
}Advanced mode
To instruct Grafana Alloy to scrape your Squid instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
prometheus.exporter.squid "integrations_squid" {
	address = "<squid_hostname>:<squid_port>"
discovery.relabel "integrations_squid" {
	targets = prometheus.exporter.squid.integrations_squid.targets
	rule {
		target_label = "instance"
prometheus.scrape "integrations_squid" {
	targets    = discovery.relabel.integrations_squid.output
	job_name   = "integrations/squid"
}This integrations uses the prometheus.exporter.squid component to generate metrics from a Squid instance.
For the full array of configuration options, refer to the prometheus.exporter.squid component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Squid instance to be monitored you must create a pair of these components.
Configure the following properties within each discovery.relabel component:
- instancelabel:- constants.hostnamesets the- instancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Squid instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel under targets within the prometheus.scrape component.
Advanced logs snippets
darwin
	path_targets = [{
}To monitor your Squid instance logs, you will use a combination of the following components:
- local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment: - __address__: The Squid instance address
- __path__: The path to the log file.
- loki.source.file sends logs to Loki.
linux
	path_targets = [{
windows
	path_targets = [{
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
Metrics
To monitor your Squid instance metrics in k8s, you will need the following info to correctly configure the scrape snippets:
- squid-service: the name of the squid service
- squid-namespace: the namespace where the Squid pod(s) live
- squid-port: the configured port of your Squid deployment
Logs
To monitor your Squid instance logs in k8s, you will use a combination of the following components:
Please note: There are two loki.process components. One for the cache logs and another for access logs.
- discovery.relabel is used to filter logs from the various components. Change the following properties according to your environment:- squid-namespace: The namespace where the Squid pod(s) live.
- squid-pod-name: Regex to match the name of the Squid pod(s).
- squid-cluster-name: The name of your Squid cluster.
- instancelabel: This value needs to match the- addressvalue provided to the metrics exporter component.
Update the provided logs snippet for the Kubernetes Monitoring Helm chart with the variables above configured as appropriate.
Configuration snippets for Kubernetes Helm chart
To scrape your Squid instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <> in the provided snippets with your desired configuration values.
Metrics snippets
alloy-metrics:
    extraConfig: |-
        prometheus.exporter.squid "squid_exporter" {
            address = "<squid-service>.<squid-namespace>.svc.cluster.local:<squid-port>"
        prometheus.scrape "integrations_squid_default" {
            targets      = prometheus.exporter.squid.squid_exporter.targets
            forward_to   = [prometheus.remote_write.grafana_cloud_metrics.receiver]
        }Logs snippets
alloy-logs:
    extraConfig: |-
        loki.process "squid_cache_logs_process" {
            forward_to = [loki.relabel.squid_cache_logs_label.receiver]
            stage.drop {
                expression = \`^\\d+\\.\\d+\`
            stage.multiline {
                firstline = \`^\\d{4}/\\d{2}/\\d{2} \\d{2}:\\d{2}:\\d{2}\`
            stage.regex {
                expression = \`^\\d{4}/\\d{2}/\\d{2} \\d{2}:\\d{2}:\\d{2}\`
        loki.process "squid_access_logs_process" {
            forward_to = [loki.relabel.squid_access_logs_label.receiver]
            stage.drop {
                expression = \`^\\s+listening port: \\d+\`
            stage.drop {
            stage.regex {
        loki.relabel "squid_cache_logs_label" {
            forward_to = [loki.write.logs_service.receiver]
            rule {
                replacement = "cache"
                target_label = "log_type"
        loki.relabel "squid_access_logs_label" {
            rule {
                replacement = "access"
        discovery.relabel "squid_logs" {
            targets = discovery.relabel.pod_logs.output
            rule {
                replacement  = "<your-squid-cluster>"
                target_label = "squid_cluster"
            rule {
                replacement   = "integrations/squid"
                target_label  = "job"
            rule {
                replacement   = "<squid-exporter-address-value>"
        loki.source.kubernetes "squid_logs" {
            targets      = discovery.relabel.squid_logs.output
            forward_to   = [loki.process.squid_access_logs_process.receiver,loki.process.squid_cache_logs_process.receiver]
        }Grafana Agent static configuration (deprecated)
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Squid metrics and logs to your Grafana Cloud instance.
Post-install configuration for the Squid integration
This integration supports metrics and logs from a Squid instance. It is configured to work with the Squid Exporter which has beeen integrated into the Grafana Agent.
Enable the integration by adding the snippets below to your agent configuration file.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job and instance label values must match for metrics and logs scrape config in your agent configuration file.
job label must be set to integrations/squid (already configured in the snippets).
instance label must be set to a value that uniquely identifies your Squid server. Please replace the default hostname value according to your environment - it must be set manually.
address label must be set to the corresponding <squid_hostname>:<squid_port>of your squid instance. Default Squid port is 3128.
username and password are optional parameters for the squid integration to be used for Squid Authentication.
integrations:
  squid:
   enabled: true
   address: <squid_hostname>:<squid_port>
logs:
  configs:
      scrape_configs:
        - job_name: integrations/squid
          static_configs:
            - targets:
                - localhost
              labels:
                job: integrations/squid
                instance: <your-instance>
                __path__: /var/log/squid/cache.log
            - targets:
                - localhost
              labels:
                __path__: /var/log/squid/access.logConfiguration snippets for Grafana Agent
Below integrations, insert the following lines and change the URLs according to your environment:
  squid:
    enabled: true
    address: '<squid_hostname>:<squid_port>'
    relabel_configs:
    - replacement: '<your-instance-name>'
      target_label: instanceBelow logs.configs.scrape_configs, insert the following lines according to your environment.
      static_configs:
        - targets:
            - localhost
          labels:
            instance: '<your-instance-name>'
        - targets:
              - localhost
          labels:
            __path__: /var/log/squid/access.logFull example configuration for Grafana Agent
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Squid integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
  prometheus_remote_write:
  - basic_auth:
      password: <your_prom_pass>
      username: <your_prom_user>
    url: <your_prom_url>
  agent:
    enabled: true
    relabel_configs:
    - action: replace
      source_labels:
      - agent_hostname
    - action: replace
      target_label: job
    metric_relabel_configs:
    - action: keep
      source_labels:
      - __name__
  squid:
    enabled: true
    relabel_configs:
logs:
  configs:
  - clients:
    - basic_auth:
        password: <your_loki_pass>
        username: <your_loki_user>
      url: <your_loki_url>
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
      static_configs:
        - targets:
            - localhost
          labels:
        - targets:
              - localhost
          labels:
metrics:
  configs:
  - name: integrations
    remote_write:
    - basic_auth:
    scrape_configs:
  global:
    scrape_interval: 60s
  wal_directory: /tmp/grafana-agent-walDashboards
The Squid integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Squid overview
Squid overview dashboard (client)
Squid overview dashboard (server)
Alerts
The Squid integration includes the following useful alerts:
| Alert | Description |
| SquidHighPercentageOfHTTPServerRequestErrors | Critical: There are a high number of HTTP server errors. |
| SquidHighPercentageOfFTPServerRequestErrors | Critical: There are a high number of FTP server request errors. |
| SquidHighPercentageOfOtherServerRequestErrors | Critical: There are a high number of other server request errors. |
| SquidHighPercentageOfClientRequestErrors | Critical: There are a high number of HTTP client request errors. |
| SquidLowCacheHitRatio | Warning: The cache hit ratio has fallen below the configured threshold (%). |
Metrics
The most important metrics provided by the Squid integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- squid_Cache_Hits_50
- squid_Cache_Hits_75
- squid_Cache_Hits_95
- squid_Cache_Misses_50
- squid_Cache_Misses_75
- squid_Cache_Misses_95
- squid_DNS_Lookups_50
- squid_DNS_Lookups_75
- squid_DNS_Lookups_95
- squid_HTTP_Requests_All_50
- squid_HTTP_Requests_All_75
- squid_HTTP_Requests_All_95
- squid_client_http_errors_total
- squid_client_http_hit_kbytes_out_bytes_total
- squid_client_http_hits_total
- squid_client_http_kbytes_in_kbytes_total
- squid_client_http_kbytes_out_kbytes_total
- squid_client_http_requests_total
- squid_server_ftp_errors_total
- squid_server_ftp_kbytes_in_kbytes_total
- squid_server_ftp_kbytes_out_kbytes_total
- squid_server_ftp_requests_total
- squid_server_http_errors_total
- squid_server_http_kbytes_in_kbytes_total
- squid_server_http_kbytes_out_kbytes_total
- squid_server_http_requests_total
- squid_server_other_errors_total
- squid_server_other_kbytes_in_kbytes_total
- squid_server_other_kbytes_out_kbytes_total
- squid_server_other_requests_total
- squid_swap_ins_total
- squid_swap_outs_total
- up
Changelog
# 1.0.0 - July 2024
* Support for the Kubernetes plugin
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial ReleaseCost
By connecting your Squid instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
