Squid integration for Grafana Cloud
Squid is a popular open-source proxy server that is used to improve web performance and provide content caching for web clients. The Squid integration uses Grafana Alloy to collect metrics for monitoring a Squid instance, including aspects such as cache hits & miss service time, cache hit ratios, client and server requests, server object swaps, and DNS lookup service time. The integration also supports Squid logs being scraped by Alloy using Promtail. An accompanying dashboard is provided to visualize these metrics and logs.
This integration supports Squid 5+.
This integration includes 5 useful alerts and 1 pre-built dashboard to help monitor and visualize Squid metrics and logs.
Before you begin
This integration monitors a Squid proxy server instance.
In order to scrape these metrics, you must have a running and reachable Squid instance.
Install Squid integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Squid and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Squid metrics and logs to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Squid setup.
Simple mode
These snippets are configured to scrape a single Squid instance running locally with default ports.
Logs snippets
darwin
Alloy
local.file_match "logs_integrations_integrations_squid" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "/var/log/squid/cache.log",
		instance    = constants.hostname,
		job         = "integrations/squid",
		__path__    = "/var/log/squid/access.log",
loki.source.file "logs_integrations_integrations_squid" {
	targets    = local.file_match.logs_integrations_integrations_squid.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
linux
Alloy
	path_targets = [{
windows
Alloy
	path_targets = [{
Advanced mode
To instruct Grafana Alloy to scrape your Squid instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Alloy
prometheus.exporter.squid "integrations_squid" {
	address = "<squid_hostname>:<squid_port>"
discovery.relabel "integrations_squid" {
	targets = prometheus.exporter.squid.integrations_squid.targets
	rule {
		target_label = "instance"
prometheus.scrape "integrations_squid" {
	targets    = discovery.relabel.integrations_squid.output
	job_name   = "integrations/squid"
This integrations uses the prometheus.exporter.squid component to generate metrics from a Squid instance.
For the full array of configuration options, refer to the prometheus.exporter.squid component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Squid instance to be monitored you must create a pair of these components.
Configure the following properties within each discovery.relabel component:
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Squid instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel under targets within the prometheus.scrape component.
Advanced logs snippets
darwin
Alloy
	path_targets = [{
To monitor your Squid instance logs, you will use a combination of the following components:
  • local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
    • __address__: The Squid instance address
    • __path__: The path to the log file.
  • loki.source.file sends logs to Loki.
linux
Alloy
	path_targets = [{
windows
Alloy
	path_targets = [{
Kubernetes instructions
Dashboards
The Squid integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Squid overview
Squid overview dashboard (client)
Squid overview dashboard (server)
Alerts
The Squid integration includes the following useful alerts:
AlertDescription
SquidHighPercentageOfHTTPServerRequestErrorsCritical: There are a high number of HTTP server errors.
SquidHighPercentageOfFTPServerRequestErrorsCritical: There are a high number of FTP server request errors.
SquidHighPercentageOfOtherServerRequestErrorsCritical: There are a high number of other server request errors.
SquidHighPercentageOfClientRequestErrorsCritical: There are a high number of HTTP client request errors.
SquidLowCacheHitRatioWarning: The cache hit ratio has fallen below the configured threshold (%).
Metrics
The most important metrics provided by the Squid integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
  • squid_Cache_Hits_50
  • squid_Cache_Hits_75
  • squid_Cache_Hits_95
  • squid_Cache_Misses_50
  • squid_Cache_Misses_75
  • squid_Cache_Misses_95
  • squid_DNS_Lookups_50
  • squid_DNS_Lookups_75
  • squid_DNS_Lookups_95
  • squid_HTTP_Requests_All_50
  • squid_HTTP_Requests_All_75
  • squid_HTTP_Requests_All_95
  • squid_client_http_errors_total
  • squid_client_http_hit_kbytes_out_bytes_total
  • squid_client_http_hits_total
  • squid_client_http_kbytes_in_kbytes_total
  • squid_client_http_kbytes_out_kbytes_total
  • squid_client_http_requests_total
  • squid_server_ftp_errors_total
  • squid_server_ftp_kbytes_in_kbytes_total
  • squid_server_ftp_kbytes_out_kbytes_total
  • squid_server_ftp_requests_total
  • squid_server_http_errors_total
  • squid_server_http_kbytes_in_kbytes_total
  • squid_server_http_kbytes_out_kbytes_total
  • squid_server_http_requests_total
  • squid_server_other_errors_total
  • squid_server_other_kbytes_in_kbytes_total
  • squid_server_other_kbytes_out_kbytes_total
  • squid_server_other_requests_total
  • squid_swap_ins_total
  • squid_swap_outs_total
  • up
Changelog
md
# 1.0.0 - July 2024
* Support for the Kubernetes plugin
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial Release
Cost
By connecting your Squid instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
