Spring Boot integration for Grafana Cloud
Spring Boot is Spring’s convention-over-configuration solution for creating stand-alone, production-grade Spring-based Applications. This integration enables the agent to send metrics to Grafana Cloud along with a useful default dashboard for visualization.
The provided dashboard is a modified version of the Spring Boot Statistics community dashboard.
This integration includes 1 pre-built dashboard to help monitor and visualize Spring Boot metrics.
Before you begin
The Spring Boot application must have the actuator enabled.
Please see the demo application for details.
We have added a custom label to the dashboard to help you observe multiple applications. To use it, make sure to add a line of code like the following in your @SpringBootApplication
class to include an application
label to your metrics. Please change MYAPPNAME
value accordingly. This is also present in the demo application.
@Bean
MeterRegistryCustomizer<MeterRegistry> metricsCommonTags() {
return registry -> registry.config().commonTags("application", "MYAPPNAME");
Install Spring Boot integration for Grafana Cloud
- Find Spring Boot and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Spring Boot metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Spring Boot setup.
Simple mode
These snippets are configured to scrape a single Spring Boot instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_spring_boot" {
targets = [{
__address__ = "localhost:1235",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_spring_boot" {
targets = discovery.relabel.metrics_integrations_integrations_spring_boot.output
job_name = "integrations/spring-boot"
metrics_path = "/actuator/prometheus"
Advanced mode
To instruct Grafana Alloy to scrape your Spring Boot instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Spring Boot instance, you must use a discovery.relabel component to discover your Spring Boot Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Spring Boot Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Spring Boot instance.
If you have multiple Spring Boot servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
@Bean
Post-install configuration for the Spring Boot integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Spring Boot application.
Actuator exposes a /actuator/prometheus
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/spring-boot
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:1235']
metrics_path: /actuator/prometheus
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Spring Boot integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Spring Boot integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Spring Boot Statistics
Metrics
The most important metrics provided by the Spring Boot integration, which are used on the pre-built dashboard, are as follows:
- hikaricp_connections
- hikaricp_connections_acquire_seconds_count
- hikaricp_connections_acquire_seconds_sum
- hikaricp_connections_active
- hikaricp_connections_creation_seconds_count
- hikaricp_connections_creation_seconds_sum
- hikaricp_connections_idle
- hikaricp_connections_pending
- hikaricp_connections_timeout_total
- hikaricp_connections_usage_seconds_count
- hikaricp_connections_usage_seconds_sum
- http_server_requests_seconds_count
- http_server_requests_seconds_sum
- jvm_buffer_memory_used_bytes
- jvm_buffer_total_capacity_bytes
- jvm_classes_loaded_classes
- jvm_classes_unloaded_classes_total
- jvm_gc_memory_allocated_bytes_total
- jvm_gc_memory_promoted_bytes_total
- jvm_gc_pause_seconds_count
- jvm_gc_pause_seconds_sum
- jvm_memory_committed_bytes
- jvm_memory_max_bytes
- jvm_memory_used_bytes
- jvm_threads_daemon_threads
- jvm_threads_live_threads
- jvm_threads_peak_threads
- logback_events_total
- process_cpu_usage
- process_files_max_files
- process_files_open_files
- process_start_time_seconds
- process_uptime_seconds
- system_cpu_count
- system_cpu_usage
- system_load_average_1m
- tomcat_global_error_total
- tomcat_global_received_bytes_total
- tomcat_global_sent_bytes_total
- tomcat_sessions_active_current_sessions
- tomcat_threads_busy
- tomcat_threads_config_max_threads
- tomcat_threads_current_threads
- up
Changelog
Cost
By connecting your Spring Boot instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
