Apache Spark integration for Grafana Cloud
Apache Spark™ is a multi-language engine for executing data engineering, data science, and machine learning on single-node machines or clusters.
This integration includes 1 pre-built dashboard to help monitor and visualize Apache Spark metrics.
Before you begin
This integration monitors a Spark cluster based on the built-in prometheus plugin, available from version 3.0 upwards, which should be enabled following the official documentation. This tutorial by dzlab might be helpful as well.
Install Apache Spark integration for Grafana Cloud
- Find Apache Spark and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Apache Spark metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Apache Spark setup.
Advanced mode
To instruct Grafana Alloy to scrape your Apache Spark instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
To monitor your Apache Spark instance, you must use a discovery.relabel component to discover your Apache Spark Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Apache Spark Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Spark instance.spark_cluster
: Thespark_cluster
label to group your Apache Spark instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Apache Spark servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the Apache Spark integration
After enabling the metrics generation, you should instruct Grafana Agent to scrape your Spark nodes.
Master nodes exposes a /metrics/master/prometheus
endpoint, while Worker and Driver nodes expose a /metrics/prometheus/
endpoint. To scrape these, add the snippets above to your agent configuration file.
You must configure two custom labels for this integration:
instance_type
, which identifies the node type, and must be one ofmaster
,worker
,application
ordriver
spark_cluster
, which must be given a value that identifies the spark cluster. If you are monitoring different clusters, give each a unique name, identifying all composing instances with the same value.
Make sure to change targets
in the snippet according to your environment.
- job_name: 'integrations/spark-master'
metrics_path: '/metrics/master/prometheus'
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- replacement: master
target_label: instance_type
- replacement: '<your-cluster-name>'
target_label: spark_cluster
static_configs:
- targets: ['spark-master:8080']
- job_name: 'integrations/spark-worker'
metrics_path: '/metrics/prometheus'
relabel_configs:
- replacement: worker
static_configs:
- targets: ['spark-worker:8081']
- job_name: 'integrations/spark-driver'
metrics_path: '/metrics/prometheus/'
relabel_configs:
- replacement: driver
static_configs:
- targets: ['spark-driver:4040']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Apache Spark integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
relabel_configs:
static_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Apache Spark integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache Spark Metrics
Apache Spark Dashboard
Metrics
The most important metrics provided by the Apache Spark integration, which are used on the pre-built dashboard, are as follows:
- metrics_master_workers_Number
- metrics_spark_app_driver_BlockManager_disk_diskSpaceUsed_MB_Number
- metrics_spark_app_driver_BlockManager_memory_maxMem_MB_Number
- metrics_spark_app_driver_BlockManager_memory_maxOffHeapMem_MB_Number
- metrics_spark_app_driver_BlockManager_memory_maxOnHeapMem_MB_Number
- metrics_spark_app_driver_DAGScheduler_job_activeJobs_Number
- metrics_spark_app_driver_DAGScheduler_job_allJobs_Number
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_Max
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_Mean
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_Min
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_StdDev
- metrics_spark_app_driver_DAGScheduler_stage_failedStages_Number
- metrics_spark_app_driver_DAGScheduler_stage_runningStages_Number
- metrics_spark_app_driver_DAGScheduler_stage_waitingStages_Number
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Count
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Max
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Mean
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Min
- metrics_worker_coresFree_Number
- metrics_worker_coresUsed_Number
- metrics_worker_memFree_MB_Number
- metrics_worker_memUsed_MB_Number
- up
Changelog
Cost
By connecting your Apache Spark instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
