Apache Spark integration for Grafana Cloud
Apache Spark™ is a multi-language engine for executing data engineering, data science, and machine learning on single-node machines or clusters.
This integration includes 1 pre-built dashboard to help monitor and visualize Apache Spark metrics.
Before you begin
This integration monitors a Spark cluster based on the built-in prometheus plugin, available from version 3.0 upwards, which should be enabled following the official documentation. This tutorial by dzlab might be helpful as well.
Install Apache Spark integration for Grafana Cloud
- Find Apache Spark and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Apache Spark metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Apache Spark setup.
Advanced mode
To instruct Grafana Alloy to scrape your Apache Spark instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_spark_master" {
targets = [{
__address__ = "spark-master:8080",
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "instance_type"
replacement = "master"
rule {
target_label = "spark_cluster"
replacement = "<your-cluster-name>"
discovery.relabel "metrics_integrations_integrations_spark_worker" {
targets = [{
__address__ = "spark-worker:8081",
rule {
rule {
replacement = "worker"
rule {
discovery.relabel "metrics_integrations_integrations_spark_driver" {
targets = [{
__address__ = "spark-driver:4040",
rule {
rule {
replacement = "driver"
rule {
prometheus.scrape "metrics_integrations_integrations_spark_master" {
targets = discovery.relabel.metrics_integrations_integrations_spark_master.output
job_name = "integrations/spark-master"
metrics_path = "/metrics/master/prometheus"
prometheus.scrape "metrics_integrations_integrations_spark_worker" {
targets = discovery.relabel.metrics_integrations_integrations_spark_worker.output
job_name = "integrations/spark-worker"
metrics_path = "/metrics/prometheus"
prometheus.scrape "metrics_integrations_integrations_spark_driver" {
targets = discovery.relabel.metrics_integrations_integrations_spark_driver.output
job_name = "integrations/spark-driver"
metrics_path = "/metrics/prometheus/"
}To monitor your Apache Spark instance, you must use a discovery.relabel component to discover your Apache Spark Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
__address__: The address to your Apache Spark Prometheus metrics endpoint.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Spark instance.spark_cluster: Thespark_clusterlabel to group your Apache Spark instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Apache Spark servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Dashboards
The Apache Spark integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache Spark Metrics
Apache Spark Dashboard
Metrics
The most important metrics provided by the Apache Spark integration, which are used on the pre-built dashboard, are as follows:
- metrics_master_workers_Number
- metrics_spark_app_driver_BlockManager_disk_diskSpaceUsed_MB_Number
- metrics_spark_app_driver_BlockManager_memory_maxMem_MB_Number
- metrics_spark_app_driver_BlockManager_memory_maxOffHeapMem_MB_Number
- metrics_spark_app_driver_BlockManager_memory_maxOnHeapMem_MB_Number
- metrics_spark_app_driver_DAGScheduler_job_activeJobs_Number
- metrics_spark_app_driver_DAGScheduler_job_allJobs_Number
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_Max
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_Mean
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_Min
- metrics_spark_app_driver_DAGScheduler_messageProcessingTime_StdDev
- metrics_spark_app_driver_DAGScheduler_stage_failedStages_Number
- metrics_spark_app_driver_DAGScheduler_stage_runningStages_Number
- metrics_spark_app_driver_DAGScheduler_stage_waitingStages_Number
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Count
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Max
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Mean
- metrics_spark_app_driver_LiveListenerBus_listenerProcessingTime_org_apache_spark_HeartbeatReceiver_Min
- metrics_worker_coresFree_Number
- metrics_worker_coresUsed_Number
- metrics_worker_memFree_MB_Number
- metrics_worker_memUsed_MB_Number
- up
Changelog
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.5 - November 2023
* Replaced Angular dashboard panels with React panels
# 0.0.4 - September 2023
# 0.0.3 - March 2023
* Updated to the latest mixin version
# 0.0.2 - May 2022
* Updated to the last mixin version:
- fix panels that did not have the /integrations prefix on the queries.
# 0.0.1 - December 2021
* Initial releaseCost
By connecting your Apache Spark instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
