SNMP integration for Grafana Cloud
The SNMP integration lets you monitor any generic SNMP (Simple Network Management Protocol) device.
This integration includes 3 useful alerts and 1 pre-built dashboard to help monitor and visualize SNMP metrics.
Before you begin
The device you are monitoring must support reporting device data through SNMP protocol.
The instructions for enabling SNMP vary for each device. The SNMP daemon can also be installed on any linux device. Once SNMP is enabled for the device, install Grafana Alloy where it can access the SNMP device on SNMP ports UDP/TCP 161 and 162 using the instructions given below.
Install SNMP integration for Grafana Cloud
- Find SNMP and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send SNMP metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your SNMP setup.
Advanced mode
To instruct Grafana Alloy to scrape your snmp target, go through the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, manually copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
Add a pair of prometheus.exporter.snmp
and discovery.relabel
to your Grafana Alloy configuration to monitor snmp device.
For ease of use, the provided snippets sets the instance
label to the hostname using the constants.hostname
Agent Flow constant variable.
If you want to monitor more than one snmp device running within the same host, set a different value for each one of them to avoid instance
label conflicts.
You will also need add an snmp target in the snmp_targets
properties within prometheus.exporter.snmp
for each target.
There is an array of options available within this component, like setting using custom snmp modules, using built in modules, setting custom walk and auth parameters.
Refer to prometheus.exporter.snmp in Grafana Alloy reference documentation for a complete description of the configuration options.
The instructions for enabling SNMP vary for each device. The SNMP daemon can also be installed on any linux device. Once SNMP is enabled for the device, install the Grafana agent where it can access the SNMP device on SNMP ports UDP/TCP 161 and 162 using the instructions given below.
Post-install configuration for the SNMP integration
This integration is configured to work with the snmp_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the provided snippets to your agent configuration file.
Replace the <host_address_*>
tags with the addresses of the relevant SNMP devices. Also configure the walk params according to your configuration.
For a full description of configuration options see how to configure the snmp
block in the agent documentation.
Below integrations
snmp:
enabled: true
relabel_configs:
- action: replace
source_labels: [job]
regex: (^.*snmp)\/(.*)
target_label: job_snmp
replacement: $1
- action: replace
target_label: snmp_target
replacement: $2
snmp_targets:
- name: network_switch_1
address: '<host_address_1>'
module: if_mib
auth: public_v2
- name: network_switch_2
address: '<host_address_2>'
module: if_mib
auth: public_v2
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the SNMP integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
snmp:
enabled: true
relabel_configs:
- action: replace
replacement: $1
- action: replace
replacement: $2
snmp_targets:
module: if_mib
auth: public_v2
module: if_mib
auth: public_v2
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The SNMP integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- SNMP Overview
SNMP Overview
Alerts
The SNMP integration includes the following useful alerts:
Metrics
The most important metrics provided by the SNMP integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- ifHCInOctets
- ifHCOutOctets
- ifHighSpeed
- ifInErrors
- ifMtu
- ifOperStatus
- ifOutErrors
- ifPhysAddress
- ifType_info
- snmp_scrape_duration_seconds
- sysUpTime
- up
Changelog
Cost
By connecting your SNMP instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
