Ruby Rack integration for Grafana Cloud
The Rack webserver interface for Ruby allows easily building web applications. This integration enables the agent to send metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize Ruby Rack metrics.
Before you begin
This integration monitors a Rack web application (e.g. any Sinatra or Rails application) using the Collector
middleware included in the Ruby Prometheus client library.
To get started, add the Prometheus client library to your Gemfile:
gem 'prometheus-client'
Then change the config.ru
file of your Rack application to use the Prometheus Collector
and Exporter
middlewares before running your app:
require 'prometheus/middleware/collector'
require 'prometheus/middleware/exporter'
use Prometheus::Middleware::Collector
use Prometheus::Middleware::Exporter
run Sinatra::Application
You can refer to this example Sinatra app for a complete setup of the Prometheus client library.
Install Ruby Rack integration for Grafana Cloud
- Find Ruby Rack and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Ruby Rack metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Ruby Rack setup.
Simple mode
These snippets are configured to scrape a single Ruby Rack instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_ruby_rack" {
targets = [{
__address__ = "localhost:9292",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_ruby_rack" {
targets = discovery.relabel.metrics_integrations_integrations_ruby_rack.output
job_name = "integrations/ruby-rack"
Advanced mode
To instruct Grafana Alloy to scrape your Ruby Rack instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Ruby Rack instance, you must use a discovery.relabel component to discover your Ruby Rack Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Ruby Rack Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Ruby Rack instance.
If you have multiple Ruby Rack servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
and Exporter
Post-install configuration for the Ruby Rack integration
After enabling the metrics generation, you should instruct Grafana Agent to scrape your Ruby application.
The Ruby Prometheus client lib exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/ruby-rack
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:9292']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Ruby Rack integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Ruby Rack integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Ruby Rack application overview
Ruby Rack Overview
Metrics
The most important metrics provided by the Ruby Rack integration, which are used on the pre-built dashboard, are as follows:
- http_server_request_duration_seconds_bucket
- http_server_request_duration_seconds_count
- http_server_request_duration_seconds_sum
- http_server_requests_total
- up
Changelog
Cost
By connecting your Ruby Rack instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
