Redis integration for Grafana Cloud
Redis is an in-memory data structure store frequently used as a key-value data store, cache, and message broker.
This integration includes 6 useful alerts and 1 pre-built dashboard to help monitor and visualize Redis metrics.
Before you begin
A user must be created in Redis for Grafana Alloy in order to connect to the cluster. We strongly recommend that you configure a separate user for the Agent, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
Install Redis integration for Grafana Cloud
- Find Redis and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Redis metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Redis setup.
Simple mode
These snippets are configured to scrape a single Redis instance running locally with default ports.
Integrations snippets
Advanced mode
To instruct Grafana Alloy to scrape your Redis instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.redis component to generate metrics from a Redis instance.
Make sure to change the redis_addr
to the addresses of the Redis server you want to monitor in the agent config.
For the full array of configuration options, refer to the prometheus.exporter.redis component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Redis instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Redis instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
A user must be created in Redis for Grafana Agent in order to connect to the cluster. We strongly recommend that you configure a separate user for the Agent, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
Post-install configuration for the Redis integration
This integration is configured to work with the redis_exporter
, which is embedded in Grafana Agent.
Enable the integration by manually adding the provided snippet to your agent configuration file.
For a full description of configuration options see how to configure the redis_exporter_config
block in the agent documentation.
Below integrations
redis_exporter:
enabled: true
redis_addr: localhost:6379 # replace with your connection string
instance: '<your-instance-name>'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Redis integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
redis_exporter:
enabled: true
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The Redis integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Redis Dashboard for Prometheus Redis Exporter 1.x
Overview
Alerts
The Redis integration includes the following useful alerts:
Metrics
The most important metrics provided by the Redis integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- redis_blocked_clients
- redis_cluster_slots_fail
- redis_cluster_slots_pfail
- redis_cluster_state
- redis_commands_duration_seconds_total
- redis_commands_total
- redis_connected_clients
- redis_connected_slaves
- redis_db_keys
- redis_db_keys_expiring
- redis_evicted_keys_total
- redis_keyspace_hits_total
- redis_keyspace_misses_total
- redis_master_last_io_seconds_ago
- redis_memory_fragmentation_ratio
- redis_memory_max_bytes
- redis_memory_used_bytes
- redis_memory_used_rss_bytes
- redis_total_system_memory_bytes
- redis_up
- up
Changelog
Cost
By connecting your Redis instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
