rclone integration
rclone integration for Grafana Cloud
Rclone is a command line program to manage files on Cloud storage. It is a feature rich alternative to Cloud vendors’ web storage interfaces. Over 40 Cloud storage products support rclone including S3 object stores, business and consumer file storage services, and standard transfer protocols.
This integration includes 1 pre-built dashboard to help monitor and visualize rclone metrics.
Before you begin
In order for rclone to emit metrics you must run it with the --rc-enable-metrics. This requires either --rc-no-auth to disable authentication, or an --rc-user and --rc-pass to enable basic authentication for the endpoint.
For example, to run rclone with the remote control endpoint, enabling metrics, and with basic authentication:
rclone rcd --rc-user <user> --rc-pass <rclone123> --rc-web-gui --rc-web-gui-no-open-browser --rc-enable-metrics --rc-no-auth --rc-addr :5572
Install rclone integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find rclone and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send rclone metrics to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your rclone setup.
Simple mode
These snippets are configured to scrape a single rclone instance running locally with default ports.
Metrics snippets
alloy
discovery.relabel "metrics_integrations_integrations_rclone" {
	targets = [{
		__address__ = "localhost:5572",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_rclone" {
	targets    = discovery.relabel.metrics_integrations_integrations_rclone.output
	job_name   = "integrations/rclone"
Advanced mode
To instruct Grafana Alloy to scrape your rclone instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
alloy
	targets = [{
	rule {
To monitor your rclone instance, you must use a discovery.relabel component to discover your rclone Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
  • __address__: The address to your rclone Prometheus metrics endpoint.
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this rclone instance.
If you have multiple rclone servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Dashboards
The rclone integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • rclone
Overview
Overview
Metrics
The most important metrics provided by the rclone integration, which are used on the pre-built dashboard, are as follows:
  • rclone_bytes_transferred_total
  • rclone_checked_files_total
  • rclone_dirs_deleted_total
  • rclone_errors_total
  • rclone_files_deleted_total
  • rclone_files_renamed_total
  • rclone_files_transferred_total
  • rclone_speed
  • up
Changelog
md
# 0.0.3 - September 2023
# 0.0.2 - January 2023
* Add dashboard screenshots
# 0.0.1 - January 2022
* Initial release
Cost
By connecting your rclone instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
