rclone integration for Grafana Cloud
Rclone is a command line program to manage files on Cloud storage. It is a feature rich alternative to Cloud vendors’ web storage interfaces. Over 40 Cloud storage products support rclone including S3 object stores, business and consumer file storage services, and standard transfer protocols.
This integration includes 1 pre-built dashboard to help monitor and visualize rclone metrics.
Before you begin
In order for rclone to emit metrics you must run it with the --rc-enable-metrics
. This requires either --rc-no-auth
to disable authentication, or an --rc-user
and --rc-pass
to enable basic authentication for the endpoint.
For example, to run rclone with the remote control endpoint, enabling metrics, and with basic authentication:
rclone rcd --rc-user <user> --rc-pass <rclone123> --rc-web-gui --rc-web-gui-no-open-browser --rc-enable-metrics --rc-no-auth --rc-addr :5572
Install rclone integration for Grafana Cloud
- Find rclone and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send rclone metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your rclone setup.
Simple mode
These snippets are configured to scrape a single rclone instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_rclone" {
targets = [{
__address__ = "localhost:5572",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_rclone" {
targets = discovery.relabel.metrics_integrations_integrations_rclone.output
job_name = "integrations/rclone"
Advanced mode
To instruct Grafana Alloy to scrape your rclone instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your rclone instance, you must use a discovery.relabel component to discover your rclone Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your rclone Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this rclone instance.
If you have multiple rclone servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
and --rc-pass
Post-install configuration for the rclone integration
After enabling the metrics generation, instruct Grafana Agent to scrape your rclone nodes.
rclone exposes a /metrics
endpoint. To scrape it, add the snippet provided to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/rclone
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:5572']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the rclone integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The rclone integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- rclone
Overview
Metrics
The most important metrics provided by the rclone integration, which are used on the pre-built dashboard, are as follows:
- rclone_bytes_transferred_total
- rclone_checked_files_total
- rclone_dirs_deleted_total
- rclone_errors_total
- rclone_files_deleted_total
- rclone_files_renamed_total
- rclone_files_transferred_total
- rclone_speed
- up
Changelog
# 0.0.3 - September 2023
# 0.0.2 - January 2023
* Add dashboard screenshots
# 0.0.1 - January 2022
* Initial release
Cost
By connecting your rclone instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
