RabbitMQ integration for Grafana Cloud
RabbitMQ is the most widely deployed open source message broker. It supports multiple messaging protocols, and can be deployed in distributed and federated configurations to meet high-scale, high-availability requirements.
This integration includes 5 useful alerts and 2 pre-built dashboards to help monitor and visualize RabbitMQ metrics.
Before you begin
This integration monitors a RabbitMQ Cluster using the built-in Prometheus metrics collector, shipped natively with RabbitMQ as of version 3.8.0.
To enable the Prometheus metrics collector in your Cluster, run the following command.
rabbitmq-plugins enable rabbitmq_prometheus
Install RabbitMQ integration for Grafana Cloud
- Find RabbitMQ and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send RabbitMQ metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your RabbitMQ setup.
Advanced mode
To instruct Grafana Alloy to scrape your RabbitMQ nodes, go though the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, manually copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
Advanced metrics snippets
One discovery.relabel must be created for each node composing your RabbitMQ cluster to avoid instance
label conflicts.
component:
__address__
: The address to your RabbitMQ Prometheus endpoint node.instance
label: The label defined under arule
within thediscovery.relabel
component. You must replace the label with a value that uniquely identifies this node.
Finally, reference each discovery.relabel
component within the targets
property of prometheus.scrape component.
In order to enable the Prometheus metrics collector in your Cluster, please run the following command.
Post-install configuration for the RabbitMQ integration
After enabling the metrics generation, instruct Grafana Agent to scrape your RabbitMQ nodes.
RabbitMQ exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
Note that if you want to monitor multiple nodes, their hostnames in targets
must be different.
- job_name: integrations/rabbitmq
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['rabbitmq:15692']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the RabbitMQ integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The RabbitMQ integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Erlang-Memory-Allocators
- RabbitMQ-Overview
RabbitMQ Overview
Erlang Memory Allocators
Alerts
The RabbitMQ integration includes the following useful alerts:
Metrics
The most important metrics provided by the RabbitMQ integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- erlang_vm_allocators
- erlang_vm_dist_node_state
- rabbitmq_build_info
- rabbitmq_channel_consumers
- rabbitmq_channel_get_ack_total
- rabbitmq_channel_get_empty_total
- rabbitmq_channel_get_total
- rabbitmq_channel_messages_acked_total
- rabbitmq_channel_messages_confirmed_total
- rabbitmq_channel_messages_delivered_ack_total
- rabbitmq_channel_messages_delivered_total
- rabbitmq_channel_messages_published_total
- rabbitmq_channel_messages_redelivered_total
- rabbitmq_channel_messages_unconfirmed
- rabbitmq_channel_messages_unroutable_dropped_total
- rabbitmq_channel_messages_unroutable_returned_total
- rabbitmq_channels
- rabbitmq_channels_closed_total
- rabbitmq_channels_opened_total
- rabbitmq_connections
- rabbitmq_connections_closed_total
- rabbitmq_connections_opened_total
- rabbitmq_disk_space_available_bytes
- rabbitmq_identity_info
- rabbitmq_process_max_fds
- rabbitmq_process_max_tcp_sockets
- rabbitmq_process_open_fds
- rabbitmq_process_open_tcp_sockets
- rabbitmq_process_resident_memory_bytes
- rabbitmq_queue_messages_published_total
- rabbitmq_queue_messages_ready
- rabbitmq_queue_messages_unacked
- rabbitmq_queues
- rabbitmq_queues_created_total
- rabbitmq_queues_declared_total
- rabbitmq_queues_deleted_total
- rabbitmq_resident_memory_limit_bytes
- up
Changelog
Cost
By connecting your RabbitMQ instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
