Presto integration for Grafana Cloud
Presto is an open-source distributed SQL query engine designed for running interactive analytic queries against data sources of all sizes, ranging from gigabytes to petabytes. It allows users to query data where it lives, whether it’s in Hadoop, AWS S3, Cassandra, MySQL, and many other data sources without the need for complex data migration or transformation. The integration with Grafana Cloud enables users to oversee a Presto environment using distinct dashboards. These dashboards display metrics and logs for Presto clusters, workers, coordinators, and logs.
This integration supports Presto 0.28+ running alongisde a JMX exporter 0.19.0+.
This integration includes 7 useful alerts and 4 pre-built dashboards to help monitor and visualize Presto metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the JMX Exporter for Prometheus on each instance in your cluster.
Enable the JMX Exporter
To enable the JMX exporter in Presto you need to add a couple of files within the installation directory. The first file will be called jmx.properties
. This file should be created in <presto-installation-directory>/etc/catalog/
. The following line should be added into the file:
connector.name=jmx
The second file that needs to be created is jvm.config
. The location of this file is typically found/created in <presto-installation-directory>/etc/
. The following lines should be appended onto this file. Change the jmxremote.port
on the command below for each instance you run, then save the configuration files.
-Dcom.sun.management.jmxremote
-Dcom.sun.management.jmxremote.port=<jmx.port>
-Dcom.sun.management.jmxremote.ssl=false
-Dcom.sun.management.jmxremote.authenticate=false
-javaagent:<path/to/jmx_java_agent.jar>=<exporter_port>:</path/to/jmx_pattern_config.yaml>/config.yaml
Configure the JMX Exporter metrics collection
In order to connect JMX to the Prometheus Exporter, a collector is configured in a config file. This config.yaml file can be placed anywhere and named anything. The contents of this file will be the following:
Validate the JMX Exporter
The JMX exporter will open a port and report the Prometheus metrics to the exporter port when the Presto instance has been started. To validate that the JMX Exporter is setup correctly, the Prometheus metrics should be available locally via curl:
curl http://localhost:<exporter_port>/metrics
Configure logs location.
By default, Presto does not have a location to store logs. Inside the file located at <presto-installation-directory>/etc/node.properties
, the user can configure a location for logs to be placed. The following line configures the log location to be at /var/presto/data/var/log/server.log
node.data-dir=/var/presto/data
Install Presto integration for Grafana Cloud
- Find Presto and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Presto metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Presto setup.
Advanced mode
To instruct Grafana Alloy to scrape your Presto instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
prometheus.scrape "metrics_integrations_integrations_presto" {
targets = [{
__address__ = "localhost:<your-instance-port>",
presto_cluster = "<your-presto-cluster-name>",
job_name = "integrations/presto"
To monitor your Presto instance, you must use a discovery.relabel component to discover your Presto Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Presto Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Presto instance. Make sure this label value is the same for all telemetry data collected for this instance.presto_cluster
must be the value that identifies the Presto cluster this instance belongs to.
If you have multiple Presto servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
To monitor your Presto instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Presto instance address__path__
is the Presto logs location. Presto does not have a default log location, but users can configure one within thenode.properties
file in their Presto installation directory. Instructions for this integration should lead to it being/var/presto/data/var/log/server.log
.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
linux
__address__
.instance
sets theinstance
windows
__address__
.instance
sets theinstance
connector.name=jmx
rules:
- pattern: "com.facebook.presto.execution<name=TaskManager><>(.+): (.*)"
value: $2
type: UNTYPED
attrNameSnakeCase: false
- pattern: "com.facebook.presto.execution.executor<name=TaskExecutor><>(.+): (.*)"
value: $2
type: UNTYPED
- pattern: "com.facebook.presto.failureDetector<name=HeartbeatFailureDetector><>ActiveCount: (.*)"
value: $1
type: UNTYPED
- pattern: "com.facebook.presto.metadata<name=DiscoveryNodeManager><>(.+): (.*)"
value: $2
type: UNTYPED
- pattern: "com.facebook.presto.execution<name=QueryManager><>(.+): (.*)"
value: $2
type: UNTYPED
- pattern: "com.facebook.presto.execution<name=QueryExecution><>(.+): (.*)"
value: $2
- pattern: "com.facebook.presto.memory<name=ClusterMemoryManager><>(.+): (.*)"
value: $2
type: UNTYPED
- pattern: "com.facebook.presto.memory<type=ClusterMemoryPool, name=(.*)><>(.+): (.*)"
type: UNTYPED
- pattern: "com.facebook.presto.memory<type=MemoryPool, name=(.*)><>(.+): (.*)"
type: UNTYPED
- pattern: 'java.lang<name=([^>]+), type=GarbageCollector><LastGcInfo>duration: (\d+)'
value: $2
labels:
type: UNTYPED
- pattern: 'java.lang<name=([^>]+), type=GarbageCollector><>CollectionCount: (\d+)'
value: $2
labels:
type: UNTYPED
- pattern: "java.lang<type=Memory><HeapMemoryUsage>used"
type: UNTYPED
- pattern: "java.lang<type=Memory><HeapMemoryUsage>committed"
type: UNTYPED
- pattern: "java.lang<type=Memory><NonHeapMemoryUsage>used"
type: UNTYPED
- pattern: "java.lang<type=Memory><NonHeapMemoryUsage>committed"
type: UNTYPED
Post-install configuration for the Presto integration
After enabling the metrics generation, instruct the Grafana Agent to scrape the Presto metrics that have been created by the JMX exporter. The Grafana Agent config is stored in the default location for each respective operating system. More documentation for the Grafana Agent can be found here: Grafana Agent documentation.
Enable the integration by adding the suggested snippets to your agent configuration file.
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
andinstance
label values must match for the Presto integration and logs scrape config in your agent configuration file.job
must be set tointegrations/presto
(already configured in the snippets).instance
must be set to a value that uniquely identifies your Presto instance.presto_cluster
must be the value that identifies the Presto cluster this instance belongs to.__path__
file in their Presto installation directory. Instructions for this integration should lead to the__path__
. Make sure to changetargets
in the snippet according to your host name andJMX_EXPORTER_PORT
- job_name: integrations/presto
metrics_path: /metrics
static_configs:
- targets: ["<your-instance-hostname>:<your-instance-port>"]
labels:
presto_cluster: '<your-presto-cluster-name>'
static_configs:
- targets: [localhost]
labels:
job: integrations/presto
instance: '<your-instance-hostname>:<your-instance-port>'
__path__: /var/presto/data/var/log/server.log
pipeline_stages:
- multiline:
firstline: '\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}\.\d{3}'
- regex:
expression: '\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}\.\d{3}Z\s+(?P<level>\w+)(?P<message>.+)'
- labels:
level:
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Presto integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
pipeline_stages:
- multiline:
- regex:
- labels:
level:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
labels:
global:
scrape_interval: 60s
Dashboards
The Presto integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Presto coordinator
- Presto logs overview
- Presto overview
- Presto worker
Presto overview (queries)
Presto overview (processing)
Presto coordinator (queries)
Alerts
The Presto integration includes the following useful alerts:
Metrics
The most important metrics provided by the Presto integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- jvm_gc_collection_count
- jvm_gc_duration
- jvm_heap_memory_committed
- jvm_heap_memory_used
- jvm_nonheap_memory_committed
- jvm_nonheap_memory_used
- presto_ClusterMemoryPool_general_BlockedNodes
- presto_ClusterMemoryPool_general_FreeDistributedBytes
- presto_ClusterMemoryPool_reserved_FreeDistributedBytes
- presto_HeartbeatDetector_ActiveCount
- presto_MemoryPool_general_FreeBytes
- presto_MemoryPool_reserved_FreeBytes
- presto_QueryExecution_Executor_QueuedTaskCount
- presto_QueryManager_AbandonedQueries_OneMinute_Count
- presto_QueryManager_AbandonedQueries_TotalCount
- presto_QueryManager_CanceledQueries_OneMinute_Count
- presto_QueryManager_CanceledQueries_TotalCount
- presto_QueryManager_CompletedQueries_OneMinute_Count
- presto_QueryManager_CompletedQueries_OneMinute_Rate
- presto_QueryManager_ConsumedCpuTimeSecs_OneMinute_Count
- presto_QueryManager_CpuInputByteRate_OneMinute_Total
- presto_QueryManager_ExecutionTime_OneMinute_P50
- presto_QueryManager_ExecutionTime_OneMinute_P75
- presto_QueryManager_ExecutionTime_OneMinute_P95
- presto_QueryManager_ExecutionTime_OneMinute_P99
- presto_QueryManager_FailedQueries_OneMinute_Count
- presto_QueryManager_FailedQueries_TotalCount
- presto_QueryManager_InsufficientResourcesFailures_OneMinute_Rate
- presto_QueryManager_InsufficientResourcesFailures_TotalCount
- presto_QueryManager_InternalFailures_OneMinute_Count
- presto_QueryManager_InternalFailures_OneMinute_Rate
- presto_QueryManager_QueuedQueries
- presto_QueryManager_RunningQueries
- presto_QueryManager_StartedQueries_OneMinute_Count
- presto_QueryManager_StartedQueries_OneMinute_Rate
- presto_QueryManager_UserErrorFailures_OneMinute_Count
- presto_QueryManager_UserErrorFailures_OneMinute_Rate
- presto_TaskExecutor_ProcessorExecutor_CompletedTaskCount
- presto_TaskExecutor_ProcessorExecutor_CorePoolSize
- presto_TaskExecutor_ProcessorExecutor_PoolSize
- presto_TaskExecutor_ProcessorExecutor_QueuedTaskCount
- presto_TaskManager_FailedTasks_TotalCount
- presto_TaskManager_InputDataSize_OneMinute_Rate
- presto_TaskManager_OutputDataSize_OneMinute_Rate
- presto_TaskManager_OutputPositions_OneMinute_Rate
- presto_TaskManager_TaskNotificationExecutor_PoolSize
- presto_metadata_DiscoveryNodeManager_ActiveCoordinatorCount
- presto_metadata_DiscoveryNodeManager_ActiveNodeCount
- presto_metadata_DiscoveryNodeManager_ActiveResourceManagerCount
- presto_metadata_DiscoveryNodeManager_InactiveNodeCount
- up
Changelog
# 1.0.1 - November 2024
- Update status panel check queries
# 1.0.0 - November 2023
- Initial release
Cost
By connecting your Presto instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
