PgBouncer integration for Grafana Cloud
PgBouncer is a lightweight connection pooler for PostgreSQL databases. It reduces the processing time and resources required by managing a pool of connections to the database server, allowing applications to share a limited number of connections more efficiently.
This integration includes 4 useful alerts and 3 pre-built dashboards to help monitor and visualize PgBouncer metrics and logs.
Before you begin
PgBouncer
For the exporter to work with PgBouncer, the pgbouncer.ini
config file needs to have the additional line ignore_startup_parameters = extra_float_digits
appended to it. Once this additional line is added, the PgBouncer service must be restarted to take effect.
PgBouncer Prometheus exporter
This integration supports metrics and logs from a PgBouncer instance. It is configured to work with the PgBouncer Prometheus Exporter, which must be installed and configured separately from Grafana Alloy.
The exporter must be built before running using make build
. The exporter itself can then be run using ./pgbouncer_exporter
. The exporter can be tested by checking the default metrics endpoint of http://localhost:9127/metrics
PgBouncer logs
PgBouncer does not send logs to a file by default, the user must enable this by adding an additional setting in the pgbouncer.ini
file. An example configuration may look like this: logfile = /var/log/postgresql/pgbouncer.log
The path to the log file that is customized in pgbouncer.ini
must be the same as the path to the logs that is set in the agent config.
Install PgBouncer integration for Grafana Cloud
- Find PgBouncer and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send PgBouncer metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your PgBouncer setup.
Simple mode
These snippets are configured to scrape a single PgBouncer instance running locally with default ports.
Logs snippets
darwin
linux
windows
Advanced mode
To instruct Grafana Alloy to scrape your PgBouncer instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
prometheus.scrape "metrics_integrations_integrations_pgbouncer" {
targets = [{
__address__ = "constants.hostname:9127",
pgbouncer_cluster = "<your-pgbouncer-cluster-name>",
job_name = "integrations/pgbouncer"
To monitor your PgBouncer instance, you must use a discovery.relabel component to discover your PgBouncer Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your PgBouncer Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this PgBouncer instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple PgBouncer servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
To monitor your PgBouncer instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The PgBouncer instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
linux
__address__
sets theinstance
windows
__address__
sets theinstance
PgBouncer
This integration supports metrics and logs from a PgBouncer instance. It is configured to work with the PgBouncer Prometheus Exporter, which must be installed and configured separately from the Grafana Agent.
PgBouncer logs
Post-install configuration for the PgBouncer integration
Enable the integration by adding the provided snippets to your agent configuration file.
For the best dashboard experience and in order to see metrics and logs correlated ensure the following:
job
andinstance
label values must match forpgbouncer
(integrations) andlogs
in the Agent configuration file.job
label must be set tointegrations/pgbouncer
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your PgBouncer instance. It is placed automatically by the config snippets.
- job_name: integrations/pgbouncer
metrics_path: /metrics
static_configs:
- targets: [<your-instance-name>:9127]
labels:
pgbouncer_cluster: <your-pgbouncer-cluster-name>
static_configs:
- targets: [localhost]
labels:
job: integrations/pgbouncer
__path__: <path-to-user-set-pgbouncer-log>/pgbouncer.log
instance: <your-instance-name>:9127
pipeline_stages:
- multiline:
firstline: '\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2}\.\d{3}'
- regex:
expression: '\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2}\.\d{3} \w+ \[\d+\] (?P<level>LOG|ERROR|WARNING|INFO|DEBUG) .*'
- labels:
level:
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the PgBouncer integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
pipeline_stages:
- multiline:
- regex:
- labels:
level:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
labels:
global:
scrape_interval: 60s
Dashboards
The PgBouncer integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- PgBouncer cluster overview
- PgBouncer logs
- PgBouncer overview
PgBouncer overview
PgBouncer overview (transaction)
Alerts
The PgBouncer integration includes the following useful alerts:
Metrics
The most important metrics provided by the PgBouncer integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- pgbouncer_config_max_client_connections
- pgbouncer_config_max_user_connections
- pgbouncer_databases_current_connections
- pgbouncer_databases_max_connections
- pgbouncer_pools_client_active_connections
- pgbouncer_pools_client_maxwait_seconds
- pgbouncer_pools_client_waiting_connections
- pgbouncer_pools_server_active_connections
- pgbouncer_pools_server_idle_connections
- pgbouncer_pools_server_login_connections
- pgbouncer_pools_server_testing_connections
- pgbouncer_pools_server_used_connections
- pgbouncer_stats_queries_duration_seconds_total
- pgbouncer_stats_queries_pooled_total
- pgbouncer_stats_received_bytes_total
- pgbouncer_stats_sent_bytes_total
- pgbouncer_stats_server_in_transaction_seconds_total
- pgbouncer_stats_sql_transactions_pooled_total
- up
Changelog
# 1.0.1 - November 2024
- Update status panel check queries
# 1.0.0 - March 2024
- Initial release
Cost
By connecting your PgBouncer instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
