OpenSearch integration for Grafana Cloud
OpenSearch is an open-source project and a fork of Elasticsearch that provides a fully-featured and compatible alternative. It uses the same core technologies as Elasticsearch, including the Lucene search engine, and offers similar features such as distributed search, indexing, and analytics. This integration for Grafana Cloud allows users to monitor an OpenSearch clustered deployment with 3 separate dashboards for visualizing metric details at the cluster, node, and index levels.
This integration supports OpenSearch version 2.5.0+
This integration supports Prometheus exporter plugin for OpenSearch version 2.5.0.0+
This integration includes 12 useful alerts and 3 pre-built dashboards to help monitor and visualize OpenSearch metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the Prometheus Exporter Plugin for OpenSearch.
Set up Prometheus Exporter Plugin for OpenSearch
To ensure compatibility, it is recommended that you refer to the Prometheus exporter plugins compatibility matrix and download the appropriate version based on your OpenSearch version.
You can find where to install the OpenSearch Prometheus exporter plugin by running:
sudo find / -name opensearch-plugin
This should give a location like /usr/share/opensearch/bin/opensearch-plugin
which you can then change directory into with cd /usr/share/opensearch
The Prometheus Exporter for OpenSearch version 2.5.0 can be installed via:
./bin/opensearch-plugin install https://github.com/aiven/prometheus-exporter-plugin-for-opensearch/releases/download/2.5.0.0/prometheus-exporter-2.5.0.0.zip
For more information on how to configure the Prometheus exporter plugin on each node, please refer to the Plugin Configuration documentation for further configuration details.
To validate the plugin is working correctly, Prometheus metrics should be available locally via curl:
curl http://localhost:9200/_prometheus/metrics
If you are unable to collect Prometheus metrics, then the OpenSearch configuration needs to be updated. This can be achieved by editing /etc/opensearch/opensearch.yml
config.
To get running quickly, add plugins.security.disabled: true
to the bottom of the file. Once this is done, OpenSearch can be restarted with sudo systemctl restart opensearch
. Validate that Prometheus metrics can be collected via curl.
Install OpenSearch integration for Grafana Cloud
- Find OpenSearch and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send OpenSearch metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your OpenSearch setup.
Advanced mode
To instruct Grafana Alloy to scrape your OpenSearch instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Note on the exporter plugin
The Prometheus exporter plugin provides the label
cluster
on the metrics, which represents the name given to the OpenSearch cluster. The mixin is looking foropensearch_cluster
and the configuration snippets will include rules for creating theopensearch_cluster
label and dropping thecluster
label.
Advanced metrics snippets
To monitor your OpenSearch instance, you must use a discovery.relabel component to discover your OpenSearch Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your OpenSearch Prometheus metrics endpoint.node
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this OpenSearch instance. Make sure this label value is the same for all telemetry data collected for this instance.opensearch_cluster
label: The name of your OpenSearch cluster. This value should be set by the configuration usinglabelmap
andlabeldrop
instructions. The value originates from thecluster.name
setting in the OpenSearch configuration.
If you have multiple OpenSearch servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
linux
local.file_match "logs_integrations_integrations_opensearch" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/opensearch/opensearch.log",
job = "integrations/opensearch",
opensearch_cluster = "<your-cluster-name>",
node = constants.hostname,
loki.source.file "logs_integrations_integrations_opensearch" {
targets = local.file_match.logs_integrations_integrations_opensearch.targets
forward_to = [loki.write.grafana_cloud_loki.receiver]
To monitor your OpenSearch instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The OpenSearch instance address__path__
: The path to the log file.node
sets theinstance
loki.source.file sends logs to Loki.
On Linux, you will also need to add the alloy
user to the opensearch
group to get logs. Run the following command to configure the user as required:
sudo usermod -a -G opensearch alloy
config.
Post-install configuration for the OpenSearch integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your OpenSearch cluster. The Grafana Agent config is stored in /etc/grafana-agent.yaml
Enable the integration by adding the suggested snippets to your agent configuration file.
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
andnode
label values must match for the OpenSearch integration and logs scrape config in your agent configuration file.job
must be set tointegrations/opensearch
(already configured in the snippets).node
label must be set to a value that uniquely identifies your OpenSearch node which is the same as an instance name on a single node.__path__
is the error log location, which isvar/log/opensearch/opensearch.log
by default (already configured in the snippets).
Make sure to change targets
in the snippet according to your environment. The default port for OpenSearch targets is 9200
On Linux, you will also need to add the grafana-agent
sudo usermod -a -G opensearch grafana-agent
- job_name: integrations/opensearch
metrics_path: /_prometheus/metrics
relabel_configs:
- replacement: '<your-instance-name>'
target_label: node
static_configs:
- targets: ['<your-host-name>:9200']
static_configs:
- targets:
- localhost
labels:
job: integrations/opensearch
node: '<your-instance-name>'
__path__: /var/log/opensearch/opensearch.log
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the OpenSearch integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
- targets:
- localhost
labels:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
target_label: node
static_configs:
global:
scrape_interval: 60s
Dashboards
The OpenSearch integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- OpenSearch cluster overview
- OpenSearch node overview
- OpenSearch search and index overview
OpenSearch Cluster Overview Dashboard 1
OpenSearch Node Overview Dashboard 1
OpenSearch Search and Index Overview Dashboard 1
Alerts
The OpenSearch integration includes the following useful alerts:
Metrics
The most important metrics provided by the OpenSearch integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- opensearch_circuitbreaker_tripped_count
- opensearch_cluster_datanodes_number
- opensearch_cluster_nodes_number
- opensearch_cluster_pending_tasks_number
- opensearch_cluster_shards_active_percent
- opensearch_cluster_shards_number
- opensearch_cluster_status
- opensearch_cluster_task_max_waiting_time_seconds
- opensearch_fs_io_total_read_bytes
- opensearch_fs_io_total_write_bytes
- opensearch_fs_path_free_bytes
- opensearch_fs_path_total_bytes
- opensearch_index_fielddata_evictions_count
- opensearch_index_flush_total_count
- opensearch_index_flush_total_time_seconds
- opensearch_index_indexing_delete_current_number
- opensearch_index_indexing_index_count
- opensearch_index_indexing_index_current_number
- opensearch_index_indexing_index_failed_count
- opensearch_index_indexing_index_time_seconds
- opensearch_index_merges_current_size_bytes
- opensearch_index_merges_total_docs_count
- opensearch_index_merges_total_stopped_time_seconds
- opensearch_index_merges_total_throttled_time_seconds
- opensearch_index_merges_total_time_seconds
- opensearch_index_querycache_evictions_count
- opensearch_index_querycache_hit_count
- opensearch_index_querycache_memory_size_bytes
- opensearch_index_querycache_miss_number
- opensearch_index_refresh_total_count
- opensearch_index_refresh_total_time_seconds
- opensearch_index_requestcache_evictions_count
- opensearch_index_requestcache_hit_count
- opensearch_index_requestcache_memory_size_bytes
- opensearch_index_requestcache_miss_count
- opensearch_index_search_fetch_count
- opensearch_index_search_fetch_current_number
- opensearch_index_search_fetch_time_seconds
- opensearch_index_search_query_count
- opensearch_index_search_query_current_number
- opensearch_index_search_query_time_seconds
- opensearch_index_search_scroll_count
- opensearch_index_search_scroll_current_number
- opensearch_index_search_scroll_time_seconds
- opensearch_index_segments_memory_bytes
- opensearch_index_segments_number
- opensearch_index_shards_number
- opensearch_index_store_size_bytes
- opensearch_index_translog_operations_number
- opensearch_indices_indexing_index_count
- opensearch_indices_store_size_bytes
- opensearch_ingest_total_count
- opensearch_ingest_total_failed_count
- opensearch_ingest_total_time_seconds
- opensearch_jvm_bufferpool_number
- opensearch_jvm_bufferpool_total_capacity_bytes
- opensearch_jvm_bufferpool_used_bytes
- opensearch_jvm_gc_collection_count
- opensearch_jvm_gc_collection_time_seconds
- opensearch_jvm_mem_heap_committed_bytes
- opensearch_jvm_mem_heap_used_bytes
- opensearch_jvm_mem_nonheap_committed_bytes
- opensearch_jvm_mem_nonheap_used_bytes
- opensearch_jvm_threads_number
- opensearch_jvm_uptime_seconds
- opensearch_node_role_bool
- opensearch_os_cpu_percent
- opensearch_os_mem_used_percent
- opensearch_os_swap_free_bytes
- opensearch_os_swap_used_bytes
- opensearch_threadpool_tasks_number
- opensearch_threadpool_threads_number
- opensearch_transport_rx_bytes_count
- opensearch_transport_server_open_number
- opensearch_transport_tx_bytes_count
- up
Changelog
# 1.0.0 - September 2024
* Update alert names
# 0.0.2 - August 2023
# 0.0.1 - May 2023
* Initial release
Cost
By connecting your OpenSearch instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
