NSQ integration for Grafana Cloud
NSQ is a realtime distributed messaging platform designed to operate at scale, handling billions of messages per day.
This integration uses NSQ statsd integration to gather metrics.
This integration includes 2 useful alerts and 2 pre-built dashboards to help monitor and visualize NSQ metrics.
Before you begin
In order for the integration to work, point nsqd
to Grafana Alloy statsd exporter with -statsd-address
, using nsqd command line flags, like this:
nsqd -statsd-address=agent.default.svc.cluster.local:9125
To enable e2e metrics with extra flags:
nsqd -e2e-processing-latency-percentile=1.0,0.99,0.95 -e2e-processing-latency-window-time=1m0s
To learn more, see end-to-end processing latency in nsq.
Install NSQ integration for Grafana Cloud
- Find NSQ and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send NSQ metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your NSQ setup.
Advanced mode
To instruct Grafana Alloy to scrape your NSQ instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.statsd component to generate metrics from a NSQ instance.
The statsd exporter component requires an external mapping configuration file. You can download the correct mapping file for this integration here.
For the full array of configuration options, refer to the prometheus.exporter.statsd component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each NSQ instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this NSQ instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
to Grafana Agent statsd exporter with -statsd-address
Post-install configuration for the NSQ integration
This integration is configured to work with the statsd_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the provided snippets to your agent configuration file.
For a full description of configuration options see how to configure the statsd_exporter_config
block in the agent documentation.
Below integrations
statsd_exporter:
enabled: true
metric_relabel_configs:
- source_labels: [exported_job]
target_label: job
replacement: 'integrations/$1'
- source_labels: [exported_instance]
target_label: instance
- regex: (exported_instance|exported_job)
action: labeldrop
mapping_config:
defaults:
match_type: glob
glob_disable_ordering: false
ttl: 1m30s
mappings:
- match: "nsq.*.topic.*.channel.*.message_count"
match_metric_type: counter
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
- match: "nsq.*.topic.*.channel.*.requeue_count"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
- match: "nsq.*.topic.*.channel.*.timeout_count"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
- match: "nsq.*.topic.*.channel.*.*"
match_metric_type: gauge
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
#nsq.<nsq_host>_<nsq_port>.topic.<topic_name>.backend_depth [gauge]
- match: "nsq.*.topic.*.message_count"
help: Total number of messages for the topic
labels:
instance: "$1"
job: "nsq"
topic: "$2"
- match: "nsq.*.topic.*.message_bytes"
help: Total number of bytes of all messages
labels:
instance: "$1"
job: "nsq"
topic: "$2"
- match: "nsq.*.topic.*.*" #depth or backend_depth
labels:
instance: "$1"
job: "nsq"
topic: "$2"
# mem
# nsq.<nsq_host>_<nsq_port>.mem.gc_runs
- match: "nsq.*.mem.gc_runs"
labels:
instance: "$1"
job: "nsq"
- match: "nsq.*.mem.*"
labels:
instance: "$1"
job: "nsq"
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the NSQ integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
- action: keep
source_labels:
- __name__
statsd_exporter:
enabled: true
target_label: job
action: labeldrop
mapping_config:
defaults:
match_type: glob
ttl: 1m30s
mappings:
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
channel: "$3"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
labels:
instance: "$1"
job: "nsq"
topic: "$2"
# mem
labels:
instance: "$1"
job: "nsq"
labels:
instance: "$1"
job: "nsq"
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The NSQ integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- NSQ Instances
- NSQ Topics
NSQ topics dashboard
NSQ instances dashboard
Alerts
The NSQ integration includes the following useful alerts:
Metrics
The most important metrics provided by the NSQ integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- nsq_mem_gc_pause_usec_100
- nsq_mem_gc_pause_usec_95
- nsq_mem_gc_pause_usec_99
- nsq_mem_heap_idle_bytes
- nsq_mem_heap_in_use_bytes
- nsq_mem_heap_objects
- nsq_mem_heap_released_bytes
- nsq_mem_next_gc_bytes
- nsq_topic_backend_depth
- nsq_topic_channel_backend_depth
- nsq_topic_channel_clients
- nsq_topic_channel_deferred_count
- nsq_topic_channel_depth
- nsq_topic_channel_e2e_processing_latency_99
- nsq_topic_channel_in_flight_count
- nsq_topic_channel_message_count
- nsq_topic_channel_requeue_count
- nsq_topic_channel_timeout_count
- nsq_topic_depth
- nsq_topic_e2e_processing_latency_99
- nsq_topic_message_bytes
- nsq_topic_message_count
- up
Changelog
# 0.0.2 - September 2023
# 0.0.1 - January 2022
* Initial release
Cost
By connecting your NSQ instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
