Nomad integration for Grafana Cloud
Nomad is a simple and flexible workload orchestrator to deploy and manage containers and non-containerized applications across on-prem and clouds at scale.
This integration includes 2 pre-built dashboards to help monitor and visualize Nomad metrics.
Before you begin
Add the telemetry stanza below in your Nomad client and server configuration files, by default it would be /etc/nomad.d/nomad.hcl:
telemetry {
disable_hostname = true
prometheus_metrics = true
publish_allocation_metrics = true
publish_node_metrics = true
Install Nomad integration for Grafana Cloud
- Find Nomad and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Nomad metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards to your Grafana Cloud instance, and you can start monitoring your Nomad setup.
Simple mode
These snippets are configured to scrape a single Nomad instance running locally with default ports.
Metrics snippets
Advanced mode
To instruct Grafana Alloy to scrape your Nomad instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
To monitor your Nomad instance, you must use a discovery.relabel component to discover your Nomad Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Nomad Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Nomad instance.
If you have multiple Nomad servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Before you begin
telemetry {
Post-install configuration for the Nomad integration
After enabling the metrics generation, you should instruct Grafana Agent to scrape each Nomad server and Nomad client that compose the Nomad cluster.
Each Nomad node exposes a /metrics
endpoint. To scrape it, add the provided snippets to your agent configuration file.
Make sure to change the hostnames according to your environment.
Instead of using static discovery, consul service discovery can be used to discover all the nodes of the Nomad cluster.
- job_name: integrations/nomad
metrics_path: /v1/metrics
params:
format: ['prometheus']
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['nomad1:4646', 'nomad2:4646', 'nomad3:4646', 'nomad-client1:4646']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Nomad integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
params:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Nomad integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Nomad cluster
- Nomad jobs
Nomad overview
Nomad jobs
Metrics
The most important metrics provided by the Nomad integration, which are used on the pre-built dashboards, are as follows:
- nomad_client_allocated_cpu
- nomad_client_allocated_disk
- nomad_client_allocated_memory
- nomad_client_allocs_cpu_total_percent
- nomad_client_allocs_cpu_total_ticks
- nomad_client_allocs_memory_cache
- nomad_client_allocs_memory_rss
- nomad_client_host_cpu_idle
- nomad_client_host_disk_available
- nomad_client_host_disk_inodes_percent
- nomad_client_host_disk_size
- nomad_client_host_memory_available
- nomad_client_host_memory_free
- nomad_client_host_memory_total
- nomad_client_host_memory_used
- nomad_client_unallocated_cpu
- nomad_client_unallocated_disk
- nomad_client_unallocated_memory
- nomad_client_uptime
- up
Changelog
Cost
By connecting your Nomad instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
