Node.js integration for Grafana Cloud
Node.js is a JavaScript runtime environment that allows execution of JavaScript code outside a web browser.
This integration includes 1 useful alert and 1 pre-built dashboard to help monitor and visualize Node.js metrics.
Before you begin
This integration monitors a Node.js app that exposes metrics through prom-client.
In order for the integration to work, the prom-client
should be installed and the default metrics should be enabled. Afterwards the metrics can be exposed under /metrics
endpoint.
import express from 'express';
import { collectDefaultMetrics, register } from 'prom-client';
collectDefaultMetrics();
const app = express();
app.get('/metrics', async (_req, res) => {
try {
res.set('Content-Type', register.contentType);
res.end(await register.metrics());
} catch (err) {
res.status(500).end(err);
app.listen(4001, '0.0.0.0');
Install Node.js integration for Grafana Cloud
- Find Node.js and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Node.js metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alert to your Grafana Cloud instance, and you can start monitoring your Node.js setup.
Simple mode
These snippets are configured to scrape a single Node.js instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_nodejs" {
targets = [{
__address__ = "localhost:4001",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_nodejs" {
targets = discovery.relabel.metrics_integrations_integrations_nodejs.output
job_name = "integrations/nodejs"
Advanced mode
To instruct Grafana Alloy to scrape your Node.js instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Node.js instance, you must use a discovery.relabel component to discover your Node.js Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Node.js Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Node.js instance.
If you have multiple Node.js servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
endpoint.
try {
} catch (err) {
Post-install configuration for the Node.js integration
After enabling the metrics generation, you must manually add the snippet provided to configure Grafana Agent to scrape your Node.js application.
The prom-client lib exposes a /metrics
endpoint. To scrape it, add the provided snippet to your Grafana Agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/nodejs
static_configs:
- targets: ['localhost:4001']
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Node.js integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
relabel_configs:
global:
scrape_interval: 60s
Dashboards
The Node.js integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Node.js
Node.js application overview dashboard
Alerts
The Node.js integration includes the following useful alerts:
Metrics
The most important metrics provided by the Node.js integration, which are used on the pre-built dashboard and Prometheus alert, are as follows:
- nodejs_active_handles_total
- nodejs_active_requests_total
- nodejs_eventloop_lag_p50_seconds
- nodejs_eventloop_lag_p99_seconds
- nodejs_eventloop_lag_seconds
- nodejs_external_memory_bytes
- nodejs_gc_duration_seconds_count
- nodejs_gc_duration_seconds_sum
- nodejs_heap_size_total_bytes
- nodejs_heap_size_used_bytes
- nodejs_heap_space_size_used_bytes
- nodejs_version_info
- process_cpu_seconds_total
- process_cpu_system_seconds_total
- process_cpu_user_seconds_total
- process_resident_memory_bytes
- process_start_time_seconds
- up
Changelog
Cost
By connecting your Node.js instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
