Node.js integration for Grafana Cloud
Node.js is a JavaScript runtime environment that allows execution of JavaScript code outside a web browser.
This integration includes 1 useful alert and 1 pre-built dashboard to help monitor and visualize Node.js metrics.
Before you begin
This integration monitors a Node.js app that exposes metrics through prom-client.
In order for the integration to work, the prom-client should be installed and the default metrics should be enabled. Afterwards the metrics can be exposed under /metrics endpoint.
import express from 'express';
import { collectDefaultMetrics, register } from 'prom-client';
collectDefaultMetrics();
const app = express();
app.get('/metrics', async (_req, res) => {
try {
res.set('Content-Type', register.contentType);
res.end(await register.metrics());
} catch (err) {
res.status(500).end(err);
app.listen(4001, '0.0.0.0');Install Node.js integration for Grafana Cloud
- Find Node.js and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Node.js metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alert to your Grafana Cloud instance, and you can start monitoring your Node.js setup.
Simple mode
These snippets are configured to scrape a single Node.js instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_nodejs" {
targets = [{
__address__ = "localhost:4001",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_nodejs" {
targets = discovery.relabel.metrics_integrations_integrations_nodejs.output
job_name = "integrations/nodejs"
}Advanced mode
To instruct Grafana Alloy to scrape your Node.js instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
}To monitor your Node.js instance, you must use a discovery.relabel component to discover your Node.js Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
__address__: The address to your Node.js Prometheus metrics endpoint.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Node.js instance.
If you have multiple Node.js servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Dashboards
The Node.js integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Node.js
Node.js application overview dashboard
Alerts
The Node.js integration includes the following useful alerts:
| Alert | Description |
| NodejsDown | Critical: Node.js not up. |
Metrics
The most important metrics provided by the Node.js integration, which are used on the pre-built dashboard and Prometheus alert, are as follows:
- nodejs_active_handles_total
- nodejs_active_requests_total
- nodejs_eventloop_lag_p50_seconds
- nodejs_eventloop_lag_p99_seconds
- nodejs_eventloop_lag_seconds
- nodejs_external_memory_bytes
- nodejs_gc_duration_seconds_count
- nodejs_gc_duration_seconds_sum
- nodejs_heap_size_total_bytes
- nodejs_heap_size_used_bytes
- nodejs_heap_space_size_used_bytes
- nodejs_version_info
- process_cpu_seconds_total
- process_cpu_system_seconds_total
- process_cpu_user_seconds_total
- process_resident_memory_bytes
- process_start_time_seconds
- up
Changelog
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.7 - November 2023
* Replaced Angular dashboard panels with React panels
# 0.0.6 - July 2023
# 0.0.5 - December 2022
* Update mixin to latest
- Add missing job selector to query
# 0.0.4 - October 2022
* Update mixin to latest version:
- fix NodejsDown alert definition
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
- Update queries to use $__rate_interval
# 0.0.1 - December 2020
* Initial releaseCost
By connecting your Node.js instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
Was this page helpful?
