MongoDB integration for Grafana Cloud
MongoDB is a general purpose, document-based, distributed database built for modern application developers and for the cloud era.
This integration includes 10 useful alerts and 3 pre-built dashboards to help monitor and visualize MongoDB metrics.
Before you begin
We strongly recommend that you configure a separate user for Grafana Alloy and give it only the strictly mandatory security privileges necessary for monitoring your node.
Install MongoDB integration for Grafana Cloud
- Find MongoDB and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send MongoDB metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your MongoDB setup.
Advanced mode
To instruct Grafana Alloy to scrape your MongoDB nodes, go though the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, manually copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
Add a pair of prometheus.exporter.mongodb and discovery.relabel to your Grafana Alloy configuration file for each MongoDB node you monitor, to avoid instance
label conflicts.
Configure the following property within the prometheus.exporter.mongodb
component:
mongodb_uri
: The URI to connect to your MongoDB node.
Refer to prometheus.exporter.mongod in Grafana Alloy reference documentation for a complete description of the configuration options.
Configure the following properties within the discovery.relabel
component:
<your-instance-name>
: Theinstance
label for all metrics from this MongoDB node.<your-cluster-name>
: Themongodb_cluster
label to group your Kafka nodes within a cluster. Set the same value for all nodes within your cluster.<your-service-name>
: The label used to group your nodes by type, for example, “Mongos”, “ConfigServer”, “Shard”. This will be used to filter by node type on your dashboards.
Finally, reference each discovery.relabel
component within the targets
property of the prometheus.scrape component.
Before you begin
This integration relies on a running MongoDB instance, with a configured user and password.
We strongly recommend that you configure a separate user for the Agent, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
Post-install configuration for the MongoDB integration
This integration is configured to work with the mongodb_exporter
, which is embedded in Grafana Agent.
Enable the integration by manually adding the provided snippet to your agent configuration file.
You must configure two custom labels for this integration:
service_name
, which is how you identify this node in your cluster (example: mongodb).mongodb_cluster
, which is the name of your mongodb cluster, and must be set the same value for all nodes composing the cluster (example: mongodb-cluster).
The config snippet already places the necessary relabel_configs
, just replace the values according to your environment and needs.
Make sure that you change the mongodb_uri
according to your environment.
For a full description of configuration options see how to configure the mongodb_exporter_config
block in the agent documentation.
Below integrations
mongodb_exporter:
enabled: true
mongodb_uri: 'mongodb://username:password@<hostname>:27017' # replace with your connection string
relabel_configs:
- target_label: service_name
replacement: 'mongodb'
- target_label: mongodb_cluster
replacement: 'your-cluster-name'
- target_label: instance
replacement: '<your-instance-name>'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the MongoDB integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
mongodb_exporter:
enabled: true
relabel_configs:
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The MongoDB integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- MongoDB Cluster
- MongoDB Instance
- MongoDB ReplicaSet
Cluster Overview
Instance Overview
ReplicaSet Overview
Alerts
The MongoDB integration includes the following useful alerts:
Metrics
The most important metrics provided by the MongoDB integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- mongodb_asserts_total
- mongodb_connections
- mongodb_extra_info_page_faults_total
- mongodb_instance_uptime_seconds
- mongodb_memory
- mongodb_mongod_asserts_total
- mongodb_mongod_connections
- mongodb_mongod_cursors
- mongodb_mongod_extra_info_page_faults_total
- mongodb_mongod_global_lock_current_queue
- mongodb_mongod_metrics_cursor_open
- mongodb_mongod_metrics_cursor_timed_out_total
- mongodb_mongod_metrics_document_total
- mongodb_mongod_metrics_get_last_error_wtime_num_total
- mongodb_mongod_metrics_get_last_error_wtime_total_milliseconds
- mongodb_mongod_metrics_get_last_error_wtimeouts_total
- mongodb_mongod_metrics_query_executor_total
- mongodb_mongod_metrics_record_moves_total
- mongodb_mongod_metrics_repl_apply_batches_total_milliseconds
- mongodb_mongod_metrics_repl_apply_ops_total
- mongodb_mongod_metrics_repl_buffer_count
- mongodb_mongod_metrics_repl_network_getmores_total_milliseconds
- mongodb_mongod_metrics_repl_preload_docs_num_total
- mongodb_mongod_metrics_repl_preload_docs_total_milliseconds
- mongodb_mongod_metrics_repl_preload_indexes_num_total
- mongodb_mongod_metrics_repl_preload_indexes_total_milliseconds
- mongodb_mongod_metrics_ttl_deleted_documents_total
- mongodb_mongod_op_counters_repl_total
- mongodb_mongod_op_counters_total
- mongodb_mongod_op_latencies_latency_total
- mongodb_mongod_op_latencies_ops_total
- mongodb_mongod_replset_member_election_date
- mongodb_mongod_replset_member_health
- mongodb_mongod_replset_member_last_heartbeat
- mongodb_mongod_replset_member_optime_date
- mongodb_mongod_replset_member_ping_ms
- mongodb_mongod_replset_member_replication_lag
- mongodb_mongod_replset_my_name
- mongodb_mongod_replset_my_state
- mongodb_mongod_replset_number_of_members
- mongodb_mongod_replset_oplog_head_timestamp
- mongodb_mongod_replset_oplog_tail_timestamp
- mongodb_mongos_asserts_total
- mongodb_mongos_connections
- mongodb_mongos_cursors
- mongodb_mongos_db_collections_total
- mongodb_mongos_db_data_size_bytes
- mongodb_mongos_db_index_size_bytes
- mongodb_mongos_db_indexes_total
- mongodb_mongos_extra_info_page_faults_total
- mongodb_mongos_metrics_cursor_open
- mongodb_mongos_metrics_get_last_error_wtime_num_total
- mongodb_mongos_metrics_get_last_error_wtime_total_milliseconds
- mongodb_mongos_metrics_get_last_error_wtimeouts_total
- mongodb_mongos_metrics_ttl_deleted_documents_total
- mongodb_mongos_op_counters_repl_total
- mongodb_mongos_op_counters_total
- mongodb_mongos_sharding_balancer_enabled
- mongodb_mongos_sharding_changelog_10min_total
- mongodb_mongos_sharding_chunks_is_balanced
- mongodb_mongos_sharding_chunks_total
- mongodb_mongos_sharding_collections_total
- mongodb_mongos_sharding_databases_total
- mongodb_mongos_sharding_shard_chunks_total
- mongodb_mongos_sharding_shards_draining_total
- mongodb_mongos_sharding_shards_total
- mongodb_op_counters_repl_total
- mongodb_op_counters_total
- mongodb_rs_members_pingMs
- mongodb_up
- mongodb_version_info
- up
Changelog
Cost
By connecting your MongoDB instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
