MinIO integration for Grafana Cloud
MinIO is a Kubernetes-native high-performance object storage server which is designed for large-scale private cloud infrastructure and compatible with Amazon S3.
This integration includes 2 useful alerts and 1 pre-built dashboard to help monitor and visualize MinIO metrics.
Before you begin
By default, the agent configuration expects the MINIO_PROMETHEUS_AUTH_TYPE
to be set to ‘public’.
If you choose not to set this flag you will need to generate a bearer_token
with mc admin prometheus generate <alias>
command to generate the scrape config compatible with Grafana Alloy. To learn more, see monitoring minio docs.
Install MinIO integration for Grafana Cloud
- Find MinIO and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send MinIO metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your MinIO setup.
Simple mode
These snippets are configured to scrape a single MinIO instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_minio" {
targets = [{
__address__ = "localhost:9000",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_minio" {
targets = discovery.relabel.metrics_integrations_integrations_minio.output
job_name = "integrations/minio"
metrics_path = "/minio/prometheus/metrics"
Advanced mode
To instruct Grafana Alloy to scrape your MinIO instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your MinIO instance, you must use a discovery.relabel component to discover your MinIO Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your MinIO Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this MinIO instance.
If you have multiple MinIO servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Before you begin
command to generate the scrape config compatible with Grafana agent. To learn more, see monitoring minio docs.
Post-install configuration for the MinIO integration
This integration uses MinIO metrics exposed at /minio/prometheus/metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: 'integrations/minio'
metrics_path: /minio/prometheus/metrics
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:9000']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the MinIO integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The MinIO integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- MinIO distributed cluster metrics
MinIO distributed metrics overview
Alerts
The MinIO integration includes the following useful alerts:
Metrics
The most important metrics provided by the MinIO integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- bucket_objects_count
- bucket_objects_histogram
- bucket_usage_size
- disk_storage_available
- disk_storage_total
- disk_storage_used
- internode_rx_bytes_total
- internode_tx_bytes_total
- minio_disks_offline
- minio_disks_total
- minio_version_info
- s3_errors_total
- s3_requests_total
- s3_ttfb_seconds_bucket
- s3_ttfb_seconds_count
- s3_ttfb_seconds_sum
- up
Changelog
Cost
By connecting your MinIO instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
