Self-hosted Grafana Mimir integration for Grafana Cloud
Grafana Mimir is an open source software project that provides a scalable long-term storage for Prometheus. Grafana Enterprise Metrics (or GEM) is the enterprise version of Grafana Mimir. You can install both of these products via the Grafana Mimir Helm chart.
This integration comes with dashboards, recording and alerting rules to help monitor the health of your Mimir or GEM cluster as well as understand per-tenant usage and behavior.
Note: an updated version of this integration is available under the Kubernetes App, which makes use of the Grafana Agent Operator, a more automated and easily maintained solution.
This integration includes 80 useful alerts and 26 pre-built dashboards to help monitor and visualize Self-hosted Grafana Mimir metrics and logs.
Before you begin
This integration is primarily targeted on monitoring a Mimir or GEM cluster that has been installed via the Helm chart, but it is also possible to use this integration if Mimir has been deployed another way.
The integration relies on metrics from kube-state-metrics, cAdvisor, and kubelet. Make sure that you have installed and enabled them in your Kubernetes cluster before you begin. Otherwise, some of the dashboards in the
integration will display No data
. Some of the dashboards contain panels related to disk usage. These panels rely on node_exporter metrics. To include them, see Additional resources metrics.
If you are using Helm chart version 3.0.0 or higher, you can skip setting up a Grafana Alloy instance, since it is included within the chart. All you will need to do is configure the chart to use the credentials and URLs of your Grafana Cloud Metrics and Logs instances. Please follow the instructions on Collect metrics and logs from the Helm chart. For information about how to create a Grafana Cloud API key, see Create a Grafana Cloud API key.
If you are not using the Helm chart, or are using an older version, follow the instructions on the next step.
Install Self-hosted Grafana Mimir integration for Grafana Cloud
- Find Self-hosted Grafana Mimir and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Self-hosted Grafana Mimir metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Self-hosted Grafana Mimir setup.
Simple mode
These snippets are configured to scrape a single Self-hosted Grafana Mimir instance running locally with default ports.
Metrics snippets
Logs snippets
linux
Advanced mode
To instruct Grafana Alloy to scrape your Self-hosted Grafana Mimir instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
To monitor your Self-hosted Grafana Mimir instance, you must use a discovery.relabel component to discover your Self-hosted Grafana Mimir Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Self-hosted Grafana Mimir Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Self-hosted Grafana Mimir instance. Make sure this label value is the same for all telemetry data collected for this instance.cluster
: Thecluster
label to group your Self-hosted Grafana Mimir instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Self-hosted Grafana Mimir servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
linux
To monitor your Self-hosted Grafana Mimir instance logs, you will use a combination of the following components:
- local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Self-hosted Grafana Mimir instance address__path__
: The path to the log file.instance
sets theinstance
: Thecluster
- loki.process defines how to process logs before sending it to Loki.
- discovery.relabel defines any relabeling needed before sending logs to Loki.
- loki.source.file sends logs to Loki.
If you are using Helm chart version 3.0.0 or higher, you can skip setting up a Grafana Agent instance, since it is included within the chart. All you will need to do is configure the chart to use the credentials and URLs of your Grafana Cloud Metrics and Logs instances. Please follow the instructions on Collect metrics and logs from the Helm chart. For information about how to create a Grafana Cloud API key, see Create a Grafana Cloud API key.
Post-install configuration for the Self-hosted Grafana Mimir integration
Please follow the instructions on Collect metrics and logs without the Helm chart if you are using a Helm chart version older than v3.0.0, or deployed Mimir without the Helm chart. The provided snippets are based on the ones present in this documentation, and might need updating.
- job_name: integrations/grafana-mimir/kube-state-metrics
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels: [__meta_kubernetes_pod_label_app_kubernetes_io_name]
action: keep
regex: kube-state-metrics
- action: replace # Replace the cluster label if it isn't present already
regex: ""
replacement: k8s-cluster
separator: ""
source_labels:
- cluster
target_label: cluster
metric_relabel_configs:
- regex: '(.*mimir-)?alertmanager.*|(.*mimir-)?alertmanager-im.*|(.*mimir-)?(query-scheduler|ruler-query-scheduler|ruler|store-gateway|compactor|alertmanager|overrides-exporter|mimir-backend).*|(.*mimir-)?compactor.*|(.*mimir-)?distributor.*|(.*mimir-)?(gateway|cortex-gw|cortex-gw-internal).*|(.*mimir-)?ingester.*|(.*mimir-)?mimir-backend.*|(.*mimir-)?mimir-read.*|(.*mimir-)?mimir-write.*|(.*mimir-)?overrides-exporter.*|(.*mimir-)?querier.*|(.*mimir-)?query-frontend.*|(.*mimir-)?query-scheduler.*|(.*mimir-)?(query-frontend|querier|ruler-query-frontend|ruler-querier|mimir-read).*|(.*mimir-)?(ruler-query-frontend|ruler-query-scheduler|ruler-querier).*|(.*mimir-)?ruler.*|(.*mimir-)?ruler-querier.*|(.*mimir-)?ruler-query-frontend.*|(.*mimir-)?ruler-query-scheduler.*|(.*mimir-)?store-gateway.*|(.*mimir-)?(distributor|ingester|mimir-write).*'
action: keep
separator: ''
source_labels: [ deployment, statefulset, pod ]
- job_name: integrations/grafana-mimir/kubelet
bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
- role: node
relabel_configs:
- replacement: kubernetes.default.svc.cluster.local:443
target_label: __address__
- regex: (.+)
replacement: /api/v1/nodes/${1}/proxy/metrics
source_labels:
- __meta_kubernetes_node_name
target_label: __metrics_path__
regex: ""
separator: ""
source_labels:
- cluster
- regex: kubelet_volume_stats.*
action: keep
source_labels: [ __name__ ]
scheme: https
tls_config:
ca_file: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt
insecure_skip_verify: false
server_name: kubernetes
- job_name: integrations/grafana-mimir/cadvisor
- role: node
relabel_configs:
- regex: (.+)
replacement: /api/v1/nodes/${1}/proxy/metrics/cadvisor
source_labels:
regex: ""
separator: ""
source_labels:
- cluster
action: keep
source_labels: [ pod ]
scheme: https
tls_config:
- job_name: integrations/grafana-mimir/metrics
- role: pod
relabel_configs:
# The mimir-distributed Helm chart names all ports which expose a /metrics endpoint with the 'metrics' suffix, so we keep only those targets.
- regex: .*metrics
action: keep
source_labels:
- __meta_kubernetes_pod_container_port_name
# Keep only targets which are a part of the expected Helm chart
- action: keep
regex: mimir-distributed-.*
source_labels:
- __meta_kubernetes_pod_label_helm_sh_chart
# The following labels are required to ensure the pre-built dashboards are fully functional later.
regex: ""
separator: ""
source_labels:
- cluster
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
source_labels:
- __meta_kubernetes_pod_name
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- action: replace
separator: ""
source_labels:
- __meta_kubernetes_pod_label_name
- __meta_kubernetes_pod_label_app_kubernetes_io_component
target_label: __tmp_component_name
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: instance
- job_name: integrations/grafana-mimir-logs
- role: pod
pipeline_stages:
- cri: {}
relabel_configs:
- action: keep
source_labels:
- source_labels:
target_label: __host__
- action: replace
replacement: $1
separator: /
source_labels:
target_label: job
regex: ''
separator: ''
source_labels:
- cluster
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
- action: replace # Necessary for slow queries dashboard
source_labels:
target_label: name
- action: replace # Not actually necessary, here for consistency with metrics
source_labels:
- replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Self-hosted Grafana Mimir integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
- role: pod
pipeline_stages:
- cri: {}
relabel_configs:
- action: keep
source_labels:
- source_labels:
- action: replace
replacement: $1
separator: /
source_labels:
target_label: job
regex: ''
separator: ''
source_labels:
- cluster
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
source_labels:
target_label: name
source_labels:
separator: /
source_labels:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
- role: pod
relabel_configs:
action: keep
regex: ""
separator: ""
source_labels:
- cluster
action: keep
separator: ''
- role: node
relabel_configs:
- regex: (.+)
source_labels:
regex: ""
separator: ""
source_labels:
- cluster
action: keep
scheme: https
tls_config:
- role: node
relabel_configs:
- regex: (.+)
source_labels:
regex: ""
separator: ""
source_labels:
- cluster
action: keep
scheme: https
tls_config:
- role: pod
relabel_configs:
- regex: .*metrics
action: keep
source_labels:
- action: keep
source_labels:
regex: ""
separator: ""
source_labels:
- cluster
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- action: replace
separator: ""
source_labels:
- action: replace
source_labels:
global:
scrape_interval: 60s
Dashboards
The Self-hosted Grafana Mimir integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Mimir / Alertmanager
- Mimir / Alertmanager resources
- Mimir / Compactor
- Mimir / Compactor resources
- Mimir / Config
- Mimir / Object Store
- Mimir / Overrides
- Mimir / Overview
- Mimir / Overview networking
- Mimir / Overview resources
- Mimir / Queries
- Mimir / Reads
- Mimir / Reads networking
- Mimir / Reads resources
- Mimir / Remote ruler reads
- Mimir / Remote ruler reads networking
- Mimir / Remote ruler reads resources
- Mimir / Rollout progress
- Mimir / Ruler
- Mimir / Scaling
- Mimir / Slow queries
- Mimir / Tenants
- Mimir / Top tenants
- Mimir / Writes
- Mimir / Writes networking
- Mimir / Writes resources
Tenants
Overview
Alerts
The Self-hosted Grafana Mimir integration includes the following useful alerts:
mimir_alerts
mimir_instance_limits_alerts
mimir-rollout-alerts
mimir-provisioning
ruler_alerts
gossip_alerts
etcd_alerts
alertmanager_alerts
mimir_blocks_alerts
mimir_compactor_alerts
mimir_autoscaling
mimir_ingest_storage_alerts
mimir_continuous_test
Metrics
The most important metrics provided by the Self-hosted Grafana Mimir integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- cluster_job:cortex_alertmanager_alerts_invalid_total:rate5m
- cluster_job:cortex_alertmanager_alerts_received_total:rate5m
- cluster_job:cortex_alertmanager_partial_state_merges_failed_total:rate5m
- cluster_job:cortex_alertmanager_partial_state_merges_total:rate5m
- cluster_job:cortex_alertmanager_state_replication_failed_total:rate5m
- cluster_job:cortex_alertmanager_state_replication_total:rate5m
- cluster_job:cortex_ingester_queried_exemplars_bucket:sum_rate
- cluster_job:cortex_ingester_queried_exemplars_count:sum_rate
- cluster_job:cortex_ingester_queried_exemplars_sum:sum_rate
- cluster_job:cortex_ingester_queried_samples_bucket:sum_rate
- cluster_job:cortex_ingester_queried_samples_count:sum_rate
- cluster_job:cortex_ingester_queried_samples_sum:sum_rate
- cluster_job:cortex_ingester_queried_series_bucket:sum_rate
- cluster_job:cortex_ingester_queried_series_count:sum_rate
- cluster_job:cortex_ingester_queried_series_sum:sum_rate
- cluster_job_integration:cortex_alertmanager_notifications_failed_total:rate5m
- cluster_job_integration:cortex_alertmanager_notifications_total:rate5m
- cluster_job_pod:cortex_alertmanager_alerts:sum
- cluster_job_pod:cortex_alertmanager_silences:sum
- cluster_job_route:cortex_querier_request_duration_seconds_bucket:sum_rate
- cluster_job_route:cortex_querier_request_duration_seconds_count:sum_rate
- cluster_job_route:cortex_querier_request_duration_seconds_sum:sum_rate
- cluster_job_route:cortex_request_duration_seconds_bucket:sum_rate
- cluster_job_route:cortex_request_duration_seconds_count:sum_rate
- cluster_job_route:cortex_request_duration_seconds_sum:sum_rate
- cluster_namespace_deployment:actual_replicas:count
- cluster_namespace_deployment_reason:required_replicas:count
- cluster_namespace_job:cortex_distributor_exemplars_in:rate5m
- cluster_namespace_job:cortex_distributor_received_exemplars:rate5m
- cluster_namespace_job:cortex_distributor_received_samples:rate5m
- cluster_namespace_job:cortex_ingester_ingested_exemplars:rate5m
- cluster_namespace_job:cortex_ingester_tsdb_exemplar_exemplars_appended:rate5m
- cluster_namespace_job_route:cortex_request_duration_seconds:99quantile
- cluster_namespace_pod:cortex_ingester_ingested_samples_total:rate4m
- container_cpu_usage_seconds_total
- container_fs_writes_bytes_total
- container_memory_rss
- container_memory_usage_bytes
- container_memory_working_set_bytes
- container_network_receive_bytes_total
- container_network_transmit_bytes_total
- container_spec_cpu_period
- container_spec_cpu_quota
- container_spec_memory_limit_bytes
- cortex_alertmanager_alerts
- cortex_alertmanager_alerts_invalid_total
- cortex_alertmanager_alerts_received_total
- cortex_alertmanager_dispatcher_aggregation_groups
- cortex_alertmanager_notification_latency_seconds_bucket
- cortex_alertmanager_notification_latency_seconds_count
- cortex_alertmanager_notification_latency_seconds_sum
- cortex_alertmanager_notifications_failed_total
- cortex_alertmanager_notifications_total
- cortex_alertmanager_partial_state_merges_failed_total
- cortex_alertmanager_partial_state_merges_total
- cortex_alertmanager_ring_check_errors_total
- cortex_alertmanager_silences
- cortex_alertmanager_state_fetch_replica_state_failed_total
- cortex_alertmanager_state_fetch_replica_state_total
- cortex_alertmanager_state_initial_sync_completed_total
- cortex_alertmanager_state_initial_sync_duration_seconds_bucket
- cortex_alertmanager_state_initial_sync_duration_seconds_count
- cortex_alertmanager_state_initial_sync_duration_seconds_sum
- cortex_alertmanager_state_persist_failed_total
- cortex_alertmanager_state_persist_total
- cortex_alertmanager_state_replication_failed_total
- cortex_alertmanager_state_replication_total
- cortex_alertmanager_sync_configs_failed_total
- cortex_alertmanager_sync_configs_total
- cortex_alertmanager_tenants_discovered
- cortex_alertmanager_tenants_owned
- cortex_bucket_blocks_count
- cortex_bucket_index_estimated_compaction_jobs
- cortex_bucket_index_estimated_compaction_jobs_errors_total
- cortex_bucket_index_last_successful_update_timestamp_seconds
- cortex_bucket_index_load_duration_seconds_bucket
- cortex_bucket_index_load_duration_seconds_count
- cortex_bucket_index_load_duration_seconds_sum
- cortex_bucket_index_load_failures_total
- cortex_bucket_index_loaded
- cortex_bucket_index_loads_total
- cortex_bucket_store_block_drop_failures_total
- cortex_bucket_store_block_drops_total
- cortex_bucket_store_block_load_failures_total
- cortex_bucket_store_block_loads_total
- cortex_bucket_store_blocks_loaded
- cortex_bucket_store_indexheader_lazy_load_duration_seconds_bucket
- cortex_bucket_store_indexheader_lazy_load_duration_seconds_count
- cortex_bucket_store_indexheader_lazy_load_duration_seconds_sum
- cortex_bucket_store_indexheader_lazy_load_total
- cortex_bucket_store_indexheader_lazy_unload_total
- cortex_bucket_store_series_batch_preloading_load_duration_seconds_sum
- cortex_bucket_store_series_batch_preloading_wait_duration_seconds_sum
- cortex_bucket_store_series_blocks_queried_sum
- cortex_bucket_store_series_data_size_fetched_bytes_sum
- cortex_bucket_store_series_data_size_touched_bytes_sum
- cortex_bucket_store_series_hash_cache_hits_total
- cortex_bucket_store_series_hash_cache_requests_total
- cortex_bucket_store_series_request_stage_duration_seconds_bucket
- cortex_bucket_store_series_request_stage_duration_seconds_count
- cortex_bucket_store_series_request_stage_duration_seconds_sum
- cortex_bucket_stores_blocks_last_successful_sync_timestamp_seconds
- cortex_bucket_stores_gate_duration_seconds_bucket
- cortex_bucket_stores_gate_duration_seconds_count
- cortex_bucket_stores_gate_duration_seconds_sum
- cortex_bucket_stores_tenants_synced
- cortex_build_info
- cortex_cache_memory_hits_total
- cortex_cache_memory_requests_total
- cortex_compactor_block_cleanup_failures_total
- cortex_compactor_block_cleanup_last_successful_run_timestamp_seconds
- cortex_compactor_blocks_cleaned_total
- cortex_compactor_blocks_marked_for_deletion_total
- cortex_compactor_blocks_marked_for_no_compaction_total
- cortex_compactor_group_compaction_runs_started_total
- cortex_compactor_last_successful_run_timestamp_seconds
- cortex_compactor_meta_sync_duration_seconds_bucket
- cortex_compactor_meta_sync_duration_seconds_count
- cortex_compactor_meta_sync_duration_seconds_sum
- cortex_compactor_meta_sync_failures_total
- cortex_compactor_meta_syncs_total
- cortex_compactor_runs_completed_total
- cortex_compactor_runs_failed_total
- cortex_compactor_runs_started_total
- cortex_compactor_tenants_discovered
- cortex_compactor_tenants_processing_failed
- cortex_compactor_tenants_processing_succeeded
- cortex_compactor_tenants_skipped
- cortex_config_hash
- cortex_discarded_exemplars_total
- cortex_discarded_requests_total
- cortex_discarded_samples_total
- cortex_distributor_deduped_samples_total
- cortex_distributor_exemplars_in_total
- cortex_distributor_inflight_push_requests
- cortex_distributor_instance_limits
- cortex_distributor_instance_rejected_requests_total
- cortex_distributor_latest_seen_sample_timestamp_seconds
- cortex_distributor_non_ha_samples_received_total
- cortex_distributor_received_exemplars_total
- cortex_distributor_received_requests_total
- cortex_distributor_received_samples_total
- cortex_distributor_replication_factor
- cortex_distributor_requests_in_total
- cortex_distributor_samples_in_total
- cortex_frontend_query_range_duration_seconds_count
- cortex_frontend_query_result_cache_attempted_total
- cortex_frontend_query_result_cache_hits_total
- cortex_frontend_query_result_cache_requests_total
- cortex_frontend_query_result_cache_skipped_total
- cortex_frontend_query_sharding_rewrites_attempted_total
- cortex_frontend_query_sharding_rewrites_succeeded_total
- cortex_frontend_sharded_queries_per_query_bucket
- cortex_frontend_sharded_queries_per_query_count
- cortex_frontend_sharded_queries_per_query_sum
- cortex_frontend_split_queries_total
- cortex_inflight_requests
- cortex_ingest_storage_reader_buffered_fetch_records_total
- cortex_ingest_storage_reader_fetch_errors_total
- cortex_ingest_storage_reader_fetches_total
- cortex_ingest_storage_reader_offset_commit_failures_total
- cortex_ingest_storage_reader_offset_commit_requests_total
- cortex_ingest_storage_reader_read_errors_total
- cortex_ingest_storage_reader_receive_delay_seconds_count
- cortex_ingest_storage_reader_receive_delay_seconds_sum
- cortex_ingest_storage_reader_records_failed_total
- cortex_ingest_storage_reader_records_total
- cortex_ingest_storage_strong_consistency_failures_total
- cortex_ingester_active_native_histogram_buckets
- cortex_ingester_active_native_histogram_buckets_custom_tracker
- cortex_ingester_active_native_histogram_series
- cortex_ingester_active_native_histogram_series_custom_tracker
- cortex_ingester_active_series
- cortex_ingester_active_series_custom_tracker
- cortex_ingester_client_request_duration_seconds_bucket
- cortex_ingester_client_request_duration_seconds_count
- cortex_ingester_client_request_duration_seconds_sum
- cortex_ingester_ingested_exemplars_total
- cortex_ingester_ingested_samples_total
- cortex_ingester_instance_limits
- cortex_ingester_instance_rejected_requests_total
- cortex_ingester_local_limits
- cortex_ingester_memory_series
- cortex_ingester_memory_series_created_total
- cortex_ingester_memory_series_removed_total
- cortex_ingester_memory_users
- cortex_ingester_oldest_unshipped_block_timestamp_seconds
- cortex_ingester_owned_series
- cortex_ingester_queried_exemplars_bucket
- cortex_ingester_queried_exemplars_count
- cortex_ingester_queried_exemplars_sum
- cortex_ingester_queried_samples_bucket
- cortex_ingester_queried_samples_count
- cortex_ingester_queried_samples_sum
- cortex_ingester_queried_series_bucket
- cortex_ingester_queried_series_count
- cortex_ingester_queried_series_sum
- cortex_ingester_shipper_last_successful_upload_timestamp_seconds
- cortex_ingester_shipper_upload_failures_total
- cortex_ingester_shipper_uploads_total
- cortex_ingester_tsdb_checkpoint_creations_failed_total
- cortex_ingester_tsdb_checkpoint_creations_total
- cortex_ingester_tsdb_checkpoint_deletions_failed_total
- cortex_ingester_tsdb_compaction_duration_seconds_bucket
- cortex_ingester_tsdb_compaction_duration_seconds_count
- cortex_ingester_tsdb_compaction_duration_seconds_sum
- cortex_ingester_tsdb_compactions_failed_total
- cortex_ingester_tsdb_compactions_total
- cortex_ingester_tsdb_exemplar_exemplars_appended_total
- cortex_ingester_tsdb_exemplar_exemplars_in_storage
- cortex_ingester_tsdb_exemplar_last_exemplars_timestamp_seconds
- cortex_ingester_tsdb_exemplar_series_with_exemplars_in_storage
- cortex_ingester_tsdb_head_max_timestamp_seconds
- cortex_ingester_tsdb_head_truncations_failed_total
- cortex_ingester_tsdb_mmap_chunk_corruptions_total
- cortex_ingester_tsdb_storage_blocks_bytes
- cortex_ingester_tsdb_symbol_table_size_bytes
- cortex_ingester_tsdb_wal_corruptions_total
- cortex_ingester_tsdb_wal_truncate_duration_seconds_count
- cortex_ingester_tsdb_wal_truncate_duration_seconds_sum
- cortex_ingester_tsdb_wal_truncations_failed_total
- cortex_ingester_tsdb_wal_truncations_total
- cortex_ingester_tsdb_wal_writes_failed_total
- cortex_kv_request_duration_seconds_bucket
- cortex_kv_request_duration_seconds_count
- cortex_kv_request_duration_seconds_sum
- cortex_limits_defaults
- cortex_limits_overrides
- cortex_prometheus_notifications_dropped_total
- cortex_prometheus_notifications_errors_total
- cortex_prometheus_notifications_queue_capacity
- cortex_prometheus_notifications_queue_length
- cortex_prometheus_notifications_sent_total
- cortex_prometheus_rule_evaluation_duration_seconds_count
- cortex_prometheus_rule_evaluation_duration_seconds_sum
- cortex_prometheus_rule_evaluation_failures_total
- cortex_prometheus_rule_evaluations_total
- cortex_prometheus_rule_group_duration_seconds_count
- cortex_prometheus_rule_group_duration_seconds_sum
- cortex_prometheus_rule_group_iterations_missed_total
- cortex_prometheus_rule_group_iterations_total
- cortex_prometheus_rule_group_rules
- cortex_querier_blocks_consistency_checks_failed_total
- cortex_querier_blocks_consistency_checks_total
- cortex_querier_queries_rejected_total
- cortex_querier_request_duration_seconds_bucket
- cortex_querier_request_duration_seconds_count
- cortex_querier_request_duration_seconds_sum
- cortex_querier_storegateway_instances_hit_per_query_bucket
- cortex_querier_storegateway_instances_hit_per_query_count
- cortex_querier_storegateway_instances_hit_per_query_sum
- cortex_querier_storegateway_refetches_per_query_bucket
- cortex_querier_storegateway_refetches_per_query_count
- cortex_querier_storegateway_refetches_per_query_sum
- cortex_query_frontend_queries_total
- cortex_query_frontend_queue_duration_seconds_bucket
- cortex_query_frontend_queue_duration_seconds_count
- cortex_query_frontend_queue_duration_seconds_sum
- cortex_query_frontend_queue_length
- cortex_query_frontend_retries_bucket
- cortex_query_frontend_retries_count
- cortex_query_frontend_retries_sum
- cortex_query_scheduler_queue_duration_seconds_bucket
- cortex_query_scheduler_queue_duration_seconds_count
- cortex_query_scheduler_queue_duration_seconds_sum
- cortex_query_scheduler_queue_length
- cortex_request_duration_seconds
- cortex_request_duration_seconds_bucket
- cortex_request_duration_seconds_count
- cortex_request_duration_seconds_sum
- cortex_ring_members
- cortex_ruler_managers_total
- cortex_ruler_queries_failed_total
- cortex_ruler_queries_total
- cortex_ruler_ring_check_errors_total
- cortex_ruler_write_requests_failed_total
- cortex_ruler_write_requests_total
- cortex_runtime_config_hash
- cortex_runtime_config_last_reload_successful
- cortex_tcp_connections
- cortex_tcp_connections_limit
- go_memstats_heap_inuse_bytes
- keda_scaler_errors
- keda_scaler_metrics_value
- kube_deployment_spec_replicas
- kube_deployment_status_replicas_unavailable
- kube_deployment_status_replicas_updated
- kube_horizontalpodautoscaler_info
- kube_horizontalpodautoscaler_spec_max_replicas
- kube_horizontalpodautoscaler_spec_min_replicas
- kube_horizontalpodautoscaler_spec_target_metric
- kube_horizontalpodautoscaler_status_condition
- kube_horizontalpodautoscaler_status_current_replicas
- kube_pod_container_info
- kube_pod_container_resource_requests
- kube_pod_container_resource_requests_cpu_cores
- kube_pod_container_resource_requests_memory_bytes
- kube_pod_container_status_restarts_total
- kube_statefulset_replicas
- kube_statefulset_status_current_revision
- kube_statefulset_status_replicas_current
- kube_statefulset_status_replicas_ready
- kube_statefulset_status_replicas_updated
- kube_statefulset_status_update_revision
- kubelet_volume_stats_capacity_bytes
- kubelet_volume_stats_used_bytes
- memberlist_client_cluster_members_count
- memcached_limit_bytes
- mimir_continuous_test_queries_failed_total
- mimir_continuous_test_query_result_checks_failed_total
- mimir_continuous_test_writes_failed_total
- node_disk_read_bytes_total
- node_disk_written_bytes_total
- process_memory_map_areas
- process_memory_map_areas_limit
- prometheus_tsdb_compaction_duration_seconds_bucket
- prometheus_tsdb_compaction_duration_seconds_count
- prometheus_tsdb_compaction_duration_seconds_sum
- prometheus_tsdb_compactions_total
- rollout_operator_last_successful_group_reconcile_timestamp_seconds
- thanos_cache_hits_total
- thanos_cache_memcached_hits_total
- thanos_cache_memcached_requests_total
- thanos_cache_operation_duration_seconds_bucket
- thanos_cache_operation_duration_seconds_count
- thanos_cache_operation_duration_seconds_sum
- thanos_cache_operation_failures_total
- thanos_cache_operations_total
- thanos_cache_requests_total
- thanos_memcached_operation_duration_seconds_bucket
- thanos_memcached_operation_duration_seconds_count
- thanos_memcached_operation_duration_seconds_sum
- thanos_memcached_operation_failures_total
- thanos_memcached_operations_total
- thanos_objstore_bucket_last_successful_upload_time
- thanos_objstore_bucket_operation_duration_seconds_bucket
- thanos_objstore_bucket_operation_duration_seconds_count
- thanos_objstore_bucket_operation_duration_seconds_sum
- thanos_objstore_bucket_operation_failures_total
- thanos_objstore_bucket_operations_total
- thanos_store_index_cache_hits_total
- thanos_store_index_cache_requests_total
- up
Changelog
Cost
By connecting your Self-hosted Grafana Mimir instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
