Microsoft IIS integration for Grafana Cloud
Microsoft IIS is a web server that can host and manage web apps on Windows servers. This integration for Grafana Cloud allows users to collect metrics and access logs for monitoring a Microsoft IIS instance.
This integration supports Microsoft IIS 10.0 onwards.
This integration includes 5 useful alerts and 2 pre-built dashboards to help monitor and visualize Microsoft IIS metrics and logs.
Before you begin
In order for the integration to properly work, you must configure Microsoft IIS with the following:
Performance Counters need to be enabled
- Start Server Manager
- Navigate to the Local Server tab
- Scroll down to the Performance section
- Right click the server and select
Start Performance Counters
You will also need to have a site running on your IIS instance to see some of the metrics.
Install Microsoft IIS integration for Grafana Cloud
- Find Microsoft IIS and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Microsoft IIS metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Microsoft IIS setup.
Simple mode
These snippets are configured to scrape a single Microsoft IIS instance running locally with default ports.
Integrations snippets
Advanced mode
To instruct Grafana Alloy to scrape your Microsoft IIS instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.windows component to generate metrics from a Microsoft IIS instance.
For the full array of configuration options, refer to the prometheus.exporter.windows component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Microsoft IIS instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Microsoft IIS instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Advanced logs snippets
windows
To monitor your Microsoft IIS instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Microsoft IIS instance address__path__
: The path to the log file.instance
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Microsoft IIS instance. Make sure this label value is the same for all telemetry data collected for this instance.site
label must be set to the website name that corresponds to the log path label__path__
, which will contain a correspondingsiteID
. ThesiteID
needs to bet set to a matching ID of thesite
label in the__path__
. For example, a site name might beDefault Website
and its site ID might be1
. This would result insite: Default Website
and__path__: /inetpub/logs/LogFiles/W3SVC1/u_ex*.log
. For each site, a new static config must be appended to the list understatic_configs
in order to filter logs by their sitelabels
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
Before you begin
Post-install configuration for the Microsoft IIS integration
Make sure to change targets
in the logs snippet according to your environment.
You must configure custom labels for this integration: If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
andinstance
label values must match for the windows_exporter integration and logs scrape config in your agent configuration file.job
must be set tointegrations/iis
instance
label must be set to a value that uniquely identifies your Microsoft IIS instance. Please replace the default hostname value according to your environment - it should be set manually.site
. ThesiteID
Below integrations
windows_exporter:
enabled: true
instance: '<your-instance-name>'
enabled_collectors: "iis"
scrape_interval: 60s
relabel_configs:
- target_label: job
replacement: 'integrations/iis'
- job_name: integrations/iis
static_configs:
# In order to monitor site logs insert another
# static_config like the sample below
- targets:
- localhost
labels:
job: integrations/iis
site: '<your-site1-name>'
__path__: /inetpub/logs/LogFiles/W3SVC<site1-id>/u_ex*.log
pipeline_stages:
- match:
# Drop lines that are comments (start with #)
selector: '{job="integrations/iis"} |~ "^#"'
action: drop
drop_counter_reason: iis_comment_line
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Microsoft IIS integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
windows_exporter:
enabled: true
relabel_configs:
- target_label: job
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
- targets:
- localhost
labels:
pipeline_stages:
- match:
action: drop
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
Dashboards
The Microsoft IIS integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Microsoft IIS applications
- Microsoft IIS overview
Microsoft IIS overview (Traffic)
Alerts
The Microsoft IIS integration includes the following useful alerts:
Metrics
The most important metrics provided by the Microsoft IIS integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- up
- windows_iis_blocked_async_io_requests_total
- windows_iis_connection_attempts_all_instances_total
- windows_iis_current_application_pool_state
- windows_iis_current_connections
- windows_iis_current_worker_processes
- windows_iis_files_received_total
- windows_iis_files_sent_total
- windows_iis_locked_errors_total
- windows_iis_not_found_errors_total
- windows_iis_received_bytes_total
- windows_iis_rejected_async_io_requests_total
- windows_iis_requests_total
- windows_iis_sent_bytes_total
- windows_iis_server_file_cache_hits_total
- windows_iis_server_file_cache_queries_total
- windows_iis_server_metadata_cache_hits_total
- windows_iis_server_metadata_cache_queries_total
- windows_iis_server_output_cache_hits_total
- windows_iis_server_output_cache_queries_total
- windows_iis_server_uri_cache_hits_total
- windows_iis_server_uri_cache_queries_total
- windows_iis_total_worker_process_failures
- windows_iis_total_worker_process_ping_failures
- windows_iis_total_worker_process_shutdown_failures
- windows_iis_total_worker_process_startup_failures
- windows_iis_worker_file_cache_hits_total
- windows_iis_worker_file_cache_queries_total
- windows_iis_worker_max_threads
- windows_iis_worker_metadata_cache_hits_total
- windows_iis_worker_metadata_cache_queries_total
- windows_iis_worker_output_cache_hits_total
- windows_iis_worker_output_queries_total
- windows_iis_worker_request_errors_total
- windows_iis_worker_requests_total
- windows_iis_worker_threads
- windows_iis_worker_uri_cache_hits_total
- windows_iis_worker_uri_cache_queries_total
- windows_iis_worker_websocket_connection_accepted_total
- windows_iis_worker_websocket_connection_attempts_total
Changelog
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - April 2023
* Initial release
Cost
By connecting your Microsoft IIS instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
