Memcached integration for Grafana Cloud
Memcached is a distributed, in-memory key-value store used to speed up dynamic database-driven websites by caching information in memory.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Memcached metrics.
Before you begin
This integration relies on Grafana Alloy installed along Memcached node. See the following sections for details.
Install Memcached integration for Grafana Cloud
- Find Memcached and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Memcached metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Memcached setup.
Simple mode
These snippets are configured to scrape a single Memcached instance running locally with default ports.
Integrations snippets
Advanced mode
To instruct Grafana Alloy to scrape your Memcached instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.memcached component to generate metrics from a Memcached instance.
For the full array of configuration options, refer to the prometheus.exporter.memcached component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Memcached instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Memcached instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Before you begin
This integration relies on Grafana Agent installed along Memcached node. See the following sections for details.
Post-install configuration for the Memcached integration
This integration is configured to work with the memcached_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding provided snippet to your agent configuration file.
Make sure to change the memcached_address
to the address of the memcached server you want to monitor.
For a full description of configuration options see how to configure the memcached_exporter_config
block in the agent documentation.
Below integrations
memcached_exporter:
enabled: true
memcached_address: localhost:11211
instance: '<your-instance-name>'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Memcached integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
memcached_exporter:
enabled: true
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The Memcached integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Memcached Overview
Memcached overview
Alerts
The Memcached integration includes the following useful alerts:
Metrics
The most important metrics provided by the Memcached integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- memcached_commands_total
- memcached_connections_total
- memcached_current_bytes
- memcached_current_connections
- memcached_current_items
- memcached_items_evicted_total
- memcached_items_total
- memcached_max_connections
- memcached_process_system_cpu_seconds_total
- memcached_process_user_cpu_seconds_total
- memcached_read_bytes_total
- memcached_slab_items_outofmemory_total
- memcached_up
- memcached_uptime_seconds
- memcached_version
- memcached_written_bytes_total
- up
Changelog
Cost
By connecting your Memcached instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
