JVM integration for Grafana Cloud
A Java Virtual Machine (JVM) provides a runtime environment that converts Java bytecode into machine language, allowing computers to run Java programs. This integration enables the agent to send metrics to Grafana Cloud from JVM apps instrumented with Prometheus JVM client, Micrometer library (Springboot), or with OpenTelemetry.
This integration includes 2 useful alerts and 1 pre-built dashboard to help monitor and visualize JVM metrics.
Before you begin
To instrument your JVM application with Prometheus client, please follow the official instrumentation guide client_java.
Install JVM integration for Grafana Cloud
- Find JVM and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send JVM metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your JVM setup.
Simple mode
These snippets are configured to scrape a single JVM instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_jvm" {
targets = [{
__address__ = "localhost:1234",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_jvm" {
targets = discovery.relabel.metrics_integrations_integrations_jvm.output
job_name = "integrations/jvm"
Advanced mode
To instruct Grafana Alloy to scrape your JVM instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your JVM instance, you must use a discovery.relabel component to discover your JVM Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your JVM Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this JVM instance.
If you have multiple JVM servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Before you begin
Post-install configuration for the JVM integration
After instrumenting your application, you should instruct Grafana Agent to scrape your JMV process instance.
By default, the client_java lib exposes metrics at a /metrics
endpoint. To scrape it, add the snippet provided to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/jvm
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:1234']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the JVM integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The JVM integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- JVM overview
JVM overview
Alerts
The JVM integration includes the following useful alerts:
Metrics
The most important metrics provided by the JVM integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- java_lang_classloading_loadedclasscount
- java_lang_memory_heapmemoryusage_committed
- java_lang_memory_heapmemoryusage_max
- java_lang_memory_heapmemoryusage_used
- java_lang_memory_nonheapmemoryusage_committed
- java_lang_memory_nonheapmemoryusage_max
- java_lang_memory_nonheapmemoryusage_used
- java_lang_operatingsystem_cpuload
- java_lang_operatingsystem_processcputime
- java_lang_operatingsystem_systemloadaverage
- java_lang_runtime_starttime
- java_lang_runtime_uptime
- java_lang_threading_daemonthreadcount
- java_lang_threading_peakthreadcount
- java_lang_threading_threadcount
- jvm_buffer_memory_used_bytes
- jvm_buffer_pool_capacity_bytes
- jvm_buffer_pool_used_bytes
- jvm_buffer_total_capacity_bytes
- jvm_classes_loaded
- jvm_classes_loaded_classes
- jvm_gc_collection_seconds_count
- jvm_gc_collection_seconds_sum
- jvm_gc_memory_allocated_bytes_total
- jvm_gc_memory_promoted_bytes_total
- jvm_gc_pause_seconds_count
- jvm_gc_pause_seconds_max
- jvm_gc_pause_seconds_sum
- jvm_memory_bytes_committed
- jvm_memory_bytes_max
- jvm_memory_bytes_used
- jvm_memory_committed_bytes
- jvm_memory_max_bytes
- jvm_memory_pool_allocated_bytes_total
- jvm_memory_pool_bytes_committed
- jvm_memory_pool_bytes_max
- jvm_memory_pool_bytes_used
- jvm_memory_pool_committed_bytes
- jvm_memory_pool_max_bytes
- jvm_memory_pool_used_bytes
- jvm_memory_used_bytes
- jvm_threads_current
- jvm_threads_daemon
- jvm_threads_daemon_threads
- jvm_threads_deadlocked
- jvm_threads_live_threads
- jvm_threads_peak
- jvm_threads_peak_threads
- jvm_threads_state
- jvm_threads_states_threads
- process_cpu_seconds_total
- process_cpu_usage
- process_files_max
- process_files_max_files
- process_files_open
- process_files_open_files
- process_max_fds
- process_open_fds
- process_resident_memory_bytes
- process_runtime_jvm_buffer_limit
- process_runtime_jvm_buffer_limit_bytes
- process_runtime_jvm_buffer_usage
- process_runtime_jvm_buffer_usage_bytes
- process_runtime_jvm_classes_loaded
- process_runtime_jvm_classes_loaded_total
- process_runtime_jvm_cpu_utilization
- process_runtime_jvm_cpu_utilization_ratio
- process_runtime_jvm_gc_duration_bucket
- process_runtime_jvm_gc_duration_count
- process_runtime_jvm_gc_duration_seconds_bucket
- process_runtime_jvm_gc_duration_seconds_count
- process_runtime_jvm_memory_allocation_count
- process_runtime_jvm_memory_committed
- process_runtime_jvm_memory_committed_bytes
- process_runtime_jvm_memory_limit
- process_runtime_jvm_memory_limit_bytes
- process_runtime_jvm_memory_usage
- process_runtime_jvm_memory_usage_bytes
- process_runtime_jvm_system_cpu_load_1m
- process_runtime_jvm_system_cpu_utilization
- process_runtime_jvm_system_cpu_utilization_ratio
- process_runtime_jvm_threads_count
- process_start_time
- process_start_time_seconds
- process_uptime
- process_uptime_seconds
- runtime_uptime_milliseconds_total
- system_cpu_count
- system_cpu_usage
- system_load_average_1m
- up
Changelog
Cost
By connecting your JVM instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
