Jira integration for Grafana Cloud
Jira is a tool for planning, tracking, and releasing software. A Jira instance can be hosted by Jira on its own cloud or you can host it on AWS, Azure, or an on-premise server. This integration enables the agent to send metrics from a Jira instance you host to Grafana Cloud along with a useful pre-built dashboard for visualization.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Jira metrics.
Before you begin
In order for the integration to work, the Prometheus Exporter for Jira
must be installed and enabled on the Jira instance.
This can be installed through the Atlassian Marketplace. If you are running a Jira Server instance, you can use the free exporter, Jira Prometheus Exporter. If you are running on the Data Center version of Jira, you have to use the PRO version Jira Prometheus Exporter PRO. Click the installation tab to view instructions on how to install these exporters to your Jira instance.
Install Jira integration for Grafana Cloud
- Find Jira and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Jira metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Jira setup.
Simple mode
These snippets are configured to scrape a single Jira instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_jira" {
targets = [{
__address__ = "localhost:8080",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_jira" {
targets = discovery.relabel.metrics_integrations_integrations_jira.output
job_name = "integrations/jira"
metrics_path = "/plugins/servlet/prometheus/metrics"
Advanced mode
To instruct Grafana Alloy to scrape your Jira instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Jira instance, you must use a discovery.relabel component to discover your Jira Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Jira Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Jira instance.
If you have multiple Jira servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Before you begin
Post-install configuration for the Jira integration
After enabling the metrics generation, instruct Grafana Agent to scrape your JIRA nodes.
Jira exposes a /plugins/servlet/prometheus/metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: "integrations/jira"
metrics_path: "/plugins/servlet/prometheus/metrics"
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8080']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Jira integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Jira integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Jira
Alerts
The Jira integration includes the following useful alerts:
Metrics
The most important metrics provided by the Jira integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- jira_active_users_gauge
- jira_all_users_gauge
- jira_allowed_users_gauge
- jira_license_expiry_days_gauge
- jira_mail_queue_error_gauge
- jira_mail_queue_gauge
- jira_request_duration_on_path_count
- jira_request_duration_on_path_sum
- jira_total_attachment_size_gauge
- jira_total_attachments_gauge
- jira_total_groups_gauge
- jira_total_issues_gauge
- jira_total_projects_gauge
- jira_total_sessions_gauge
- jvm_memory_bytes_used
- process_cpu_seconds_total
- up
Changelog
# 0.0.4 - September 2023
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
* Update mixin to latest version:
- Update the datasource template variable label to 'Data Source'
- Update all rate queries to use `$__rate_interval` so they respect the default resolution
# 0.0.1 - June 2021
* Initial release
Cost
By connecting your Jira instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
