Jenkins integration for Grafana Cloud
Jenkins is a free and open source automation server. It helps automate the parts of software development related to building, testing, and deploying, facilitating continuous integration and continuous delivery. It is a server-based system that runs in servlet containers such as Apache Tomcat.
This integration includes 1 pre-built dashboard to help monitor and visualize Jenkins metrics.
Before you begin
In order for the integration to work, the Prometheus plugin must be installed in your Jenkins instance.
Install Jenkins integration for Grafana Cloud
- Find Jenkins and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Jenkins metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Jenkins setup.
Simple mode
These snippets are configured to scrape a Jenkins server running locally with default ports.
Metrics snippets
discovery.relabel "jenkins_metrics" {
targets = [{
__address__ = "localhost:8080",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "jenkins_metrics" {
targets = discovery.relabel.jenkins_metrics.output
job_name = "integrations/jenkins"
metrics_path = "/prometheus"
Advanced mode
To instruct Grafana Alloy to scrape your Jenkins nodes, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor a Jenkins instance, you must use a discovery.relabel component to discover your Jenkins Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within the discovery.relabel
component:
__address__
: change this fromlocalhost:8080
to the host and port of the remote Jenkins Prometheus metrics endpoint.constants.hostname
: the snippets set theinstance
label to your Grafana Alloy server hostname using theconstants.hostname
variable. If you are running Grafana Alloy outside of your Jenkins server host, change the variable to a value that uniquely identifies it.
If you have multiple Jenkins servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the Jenkins integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Jenkins nodes.
Jenkins exposes a /prometheus
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/jenkins
metrics_path: /prometheus
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8080']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Jenkins integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Jenkins integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Jenkins
Jenkins overview dashboard
Metrics
The most important metrics provided by the Jenkins integration, which are used on the pre-built dashboard, are as follows:
- http_requests
- http_responseCodes_badRequest_total
- http_responseCodes_created_total
- http_responseCodes_forbidden_total
- http_responseCodes_noContent_total
- http_responseCodes_notFound_total
- http_responseCodes_notModified_total
- http_responseCodes_ok_total
- http_responseCodes_other_total
- http_responseCodes_serverError_total
- http_responseCodes_serviceUnavailable_total
- jenkins_executor_count_value
- jenkins_node_count_value
- jenkins_node_online_value
- jenkins_plugins_active
- jenkins_plugins_failed
- jenkins_plugins_inactive
- jenkins_plugins_withUpdate
- jenkins_queue_blocked_value
- jenkins_queue_buildable_value
- jenkins_queue_pending_value
- jenkins_queue_stuck_value
- jenkins_runs_failure_total
- jenkins_runs_success_total
- up
Changelog
Cost
By connecting your Jenkins instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
