Jenkins integration for Grafana Cloud
Jenkins is a free and open source automation server. It helps automate the parts of software development related to building, testing, and deploying, facilitating continuous integration and continuous delivery. It is a server-based system that runs in servlet containers such as Apache Tomcat.
This integration includes 1 pre-built dashboard to help monitor and visualize Jenkins metrics.
Before you begin
In order for the integration to work, the Prometheus plugin must be installed in your Jenkins instance.
Install Jenkins integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Jenkins and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Jenkins metrics to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Jenkins setup.
Simple mode
These snippets are configured to scrape a Jenkins server running locally with default ports.
Metrics snippets
alloy
discovery.relabel "jenkins_metrics" {
  targets = [{
    __address__ = "localhost:8080",
  rule {
    target_label = "instance"
prometheus.scrape "jenkins_metrics" {
  targets      = discovery.relabel.jenkins_metrics.output
  forward_to   = [prometheus.remote_write.metrics_service.receiver]
  job_name     = "integrations/jenkins"
  metrics_path = "/prometheus"
Advanced mode
To instruct Grafana Alloy to scrape your Jenkins nodes, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
alloy
  targets = [{
  rule {
To monitor a Jenkins instance, you must use a discovery.relabel component to discover your Jenkins Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within the discovery.relabel component:
  • __address__: change this from localhost:8080 to the host and port of the remote Jenkins Prometheus metrics endpoint.
  • constants.hostname: the snippets set the instance label to your Grafana Alloy server hostname using the constants.hostname variable. If you are running Grafana Alloy outside of your Jenkins server host, change the variable to a value that uniquely identifies it.
If you have multiple Jenkins servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Dashboards
The Jenkins integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Jenkins
Jenkins overview dashboard
Metrics
The most important metrics provided by the Jenkins integration, which are used on the pre-built dashboard, are as follows:
  • http_requests
  • http_responseCodes_badRequest_total
  • http_responseCodes_created_total
  • http_responseCodes_forbidden_total
  • http_responseCodes_noContent_total
  • http_responseCodes_notFound_total
  • http_responseCodes_notModified_total
  • http_responseCodes_ok_total
  • http_responseCodes_other_total
  • http_responseCodes_serverError_total
  • http_responseCodes_serviceUnavailable_total
  • jenkins_executor_count_value
  • jenkins_node_count_value
  • jenkins_node_online_value
  • jenkins_plugins_active
  • jenkins_plugins_failed
  • jenkins_plugins_inactive
  • jenkins_plugins_withUpdate
  • jenkins_queue_blocked_value
  • jenkins_queue_buildable_value
  • jenkins_queue_pending_value
  • jenkins_queue_stuck_value
  • jenkins_runs_failure_total
  • jenkins_runs_success_total
  • up
Changelog
md
# 1.0.0 - September 2024
* Update dashboard to remove deprecated angular panels
* Added Asserts support
# 0.0.4 - September 2023
# 0.0.3 - April 2023
* Update mixin to latest version:
  - Update panel descriptions
# 0.0.2 - May 2022
  - metrics_path uses `/prometheus` rather than `/api/prometheus`
  - scrape targets `localhost:8080` rather than `jenkins:8080`
# 0.0.1 - July 2021
* Initial release
Cost
By connecting your Jenkins instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
