IBM MQ integration for Grafana Cloud
IBM MQ is a message queue software that can be deployed across a range of different environments. MQ sends and receives messages via message queues to support the exchange of information between applications, systems, and services.
This integration includes useful visualizations for cluster, queue manager, queue, and topic metrics. Metrics such as the number of messages sent and received by queue managers and queues, the number of different queue operations, disk usage, CPU usage, active connections, average queue time, and expired messages.
This integration supports IBM MQ 9.1+
This integration includes 4 useful alerts and 4 pre-built dashboards to help monitor and visualize IBM MQ metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the MQ Prometheus exporter for each queue manager in the cluster.
Set up Prometheus exporter
Each instance of the exporter can be run by running the following setup script.
This file specifies multiple arguments for monitoring your IBM MQ cluster and its objects. Modify this file to ensure that the supplied arguments match your IBM MQ environment.
Key arguments that must be checked include:
- ibmmq.queueManager=
<qmgr>
- ibmmq.monitoredChannels=
<channels>
- ibmmq.monitoredTopics=
<topics>
- ibmmq.monitoredSubscriptions=
<subscriptions>
- ibmmq.monitoredQueues=
<queues>
<qmgr>, <queues>, <channels>, <topics>, <subscriptions>
must be replaced with the regular expression that will match the respective object of your instance of the exporter is monitoring.
* ex: Channel Name: LONDON.NEWYORK
—-> <channels>
: LONDON.*
Windows
See here for additional help on building to run on Windows.
The exporter uses port 9157
by default to expose metrics, however if multiple queue managers are going to be monitored by Grafana Alloy on the same machine, you must change the default port. This can be done using the ibmmq.httpListenPort
flag when running the exporter.
For more information on how to configure the exporter for each queue manager, please refer to the documentation for details.
Once deployed, Grafana Alloy should be able to reach the exporter’s exposed metrics endpoint.
Install IBM MQ integration for Grafana Cloud
- Find IBM MQ and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send IBM MQ metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your IBM MQ setup.
Advanced mode
To instruct Grafana Alloy to scrape your IBM MQ instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_ibm_mq" {
targets = concat(
__address__ = "<exporter-hostname-1>:<exporter-port-1>",
__address__ = "<exporter-hostname-2>:<exporter-port-2>",
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "mq_cluster"
replacement = "<your-cluster-name>"
prometheus.scrape "metrics_integrations_integrations_ibm_mq" {
targets = discovery.relabel.metrics_integrations_integrations_ibm_mq.output
job_name = "integrations/ibm-mq"
To monitor your IBM MQ instance, you must use a discovery.relabel component to discover your IBM MQ Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your IBM MQ Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this IBM MQ instance. Make sure this label value is the same for all telemetry data collected for this instance.mq_cluster
: Themq_cluster
label to group your IBM MQ instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple IBM MQ servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
linux
To monitor your IBM MQ instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The IBM MQ instance address__path__
: The path to the log file.instance
sets theinstance
: Themq_cluster
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
windows
__address__
sets theinstance
: Themq_cluster
<qmgr>
<channels>
<topics>
<subscriptions>
<queues>
—-> <channels>
: LONDON.*
Windows
by default to expose metrics, however if multiple queue managers are going to be monitored by the Grafana Agent on the same machine, you must change the default port. This can be done using the ibmmq.httpListenPort
Once deployed, the Grafana Agent should be able to reach the exporter’s exposed metrics endpoint.
Post-install configuration for the IBM MQ integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your IBM MQ nodes.
Make sure to change targets
in the snippet according to your environment.
You must configure a custom label for this integration:
mq_cluster
, the value that identifies your IBM MQ cluster
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
job
must be set tointegrations/ibm-mq
.mq_cluster
should be set to the name of the cluster that includes all of the queue managers the Grafana Agent is monitoring.job
andmq_cluster
values must match between the metrics scrape and logs scrape configs in your configuration file.
- job_name: integrations/ibm-mq
metrics_path: "/metrics"
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- replacement: '<your-cluster-name>'
target_label: mq_cluster
static_configs:
- targets:
- '<exporter-hostname-1>:<exporter-port-1>'
- '<exporter-hostname-2>:<exporter-port-2>'
static_configs:
- targets: [localhost]
labels:
job: integrations/ibm-mq
instance: '<your-instance-name>'
mq_cluster: '<your-cluster-name>'
__path__: /var/mqm/errors/*.LOG
pipeline_stages:
- match:
selector: '{job="integrations/ibm-mq",instance="<your-instance-name>"}'
stages:
- regex:
source: filename
expression: "/var/mqm/qmgrs/(?P<qmgr>.*?)/errors/.*\\.LOG"
- labels:
qmgr:
- multiline:
firstline: '^\s*\d{2}\/\d{2}\/\d{2}\s+\d{2}:\d{2}:\d{2}\s*-'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the IBM MQ integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The IBM MQ integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- IBM MQ cluster overview
- IBM MQ queue manager overview
- IBM MQ queue overview
- IBM MQ topics overview
IBM MQ queue manager overview (performance)
Alerts
The IBM MQ integration includes the following useful alerts:
Metrics
The most important metrics provided by the IBM MQ integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- ibmmq_channel_xmitq_time_long
- ibmmq_channel_xmitq_time_short
- ibmmq_cluster_suspend
- ibmmq_qmgr_active_listeners
- ibmmq_qmgr_commit_count
- ibmmq_qmgr_connection_count
- ibmmq_qmgr_expired_message_count
- ibmmq_qmgr_log_in_use_bytes
- ibmmq_qmgr_log_write_latency_seconds
- ibmmq_qmgr_published_to_subscribers_bytes
- ibmmq_qmgr_published_to_subscribers_message_count
- ibmmq_qmgr_queue_manager_file_system_free_space_percentage
- ibmmq_qmgr_queue_manager_file_system_in_use_bytes
- ibmmq_qmgr_ram_total_bytes
- ibmmq_qmgr_ram_total_estimate_for_queue_manager_bytes
- ibmmq_qmgr_status
- ibmmq_qmgr_system_cpu_time_percentage
- ibmmq_qmgr_uptime
- ibmmq_qmgr_user_cpu_time_estimate_for_queue_manager_percentage
- ibmmq_qmgr_user_cpu_time_percentage
- ibmmq_queue_average_queue_time_seconds
- ibmmq_queue_depth
- ibmmq_queue_expired_messages
- ibmmq_queue_mqclose_count
- ibmmq_queue_mqget_bytes
- ibmmq_queue_mqget_count
- ibmmq_queue_mqinq_count
- ibmmq_queue_mqopen_count
- ibmmq_queue_mqput_bytes
- ibmmq_queue_mqput_mqput1_count
- ibmmq_queue_mqset_count
- ibmmq_queue_oldest_message_age
- ibmmq_subscription_messsages_received
- ibmmq_subscription_time_since_message_published
- ibmmq_topic_messages_received
- ibmmq_topic_publisher_count
- ibmmq_topic_subscriber_count
- ibmmq_topic_time_since_msg_received
- up
Changelog
# 1.0.0 - February 2024
* Updated versioning to 1.x
* Added Grafana Agent Operator configuration snippet to support IBM MQ in kubernetes cluster
* Added cluster selector to dashboard for kubernetes support
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial release
Cost
By connecting your IBM MQ instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
