IBM DB2 integration for Grafana Cloud
IBM DB2 is a relational database management system designed to store, manage, and retrieve data efficiently. This integration for Grafana Cloud allows users to collect metrics and logs for monitoring an IBM DB2 database.
Metrics include active connections, row operations, bufferpool hit ratio, tablespace usage, average lock wait time, deadlocks, and active locks.
This integration supports IBM DB2 9.7 and onwards.
This integration includes 3 useful alerts and 1 pre-built dashboard to help monitor and visualize IBM DB2 metrics and logs.
Before you begin
In order for the integration to properly work, you must set up the IBM DB2 Prometheus Exporter to export metrics from IBM DB2.
Activating IBM DB2 database
For DB2 to accurately report metric values, the database being monitored must be “explicitly activated”. Doing so will make it so that certain metric values are correctly incremented and not periodically reset. However, it does result in a performance impact on the environment DB2 is running in. The size of this impact will depend on the system, but will result in the most accurate data reported by DB2 and, subsequently, this exporter. To explicitly activate a database, connect to DB2 and run the command activate database <dbname>
and disconnect. Now DB2 will correctly increment and store metrics.
db2
activate database sample
quit
To deactivate a database, connect to db2 and run the command deactivate database <dbname>
and disconnect. Doing so will reset the metrics reported by DB2. The database must be reactivated in order for metrics to be properly incremented, stored, and reported by DB2.
Note: Whether or not the database is activated only affects DB2’s ability to report metrics, it does not affect DB2’s behavior as a database.
Set up IBM DB2 Exporter
The exporter can be run by following this guide.
Note: The exporter uses a driver that is not compatible with ARM64 architectures. Therefore the exporter cannot be used on an ARM64 machine.
The exporter serves metrics for only one database, so to monitor multiple databases multiple exporters will need to be set up. By default, the exporter serves metrics at port 9953
but can be configured to use a different port. Use the flag --web.listen-address=;<port>
when running the exporter to serve metrics at a different port. This can be done so that Grafana Alloy can report metrics for multiple databases by scraping from multiple exporters.
Once deployed, Grafana Alloy will be able to scrape the IBM DB2 Exporter.
Install IBM DB2 integration for Grafana Cloud
- Find IBM DB2 and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send IBM DB2 metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your IBM DB2 setup.
Simple mode
These snippets are configured to scrape a single IBM DB2 instance running locally with default ports.
Metrics snippets
prometheus.scrape "metrics_integrations_integrations_ibm_db2" {
targets = [{
__address__ = "localhost:9953",
instance = constants.hostname,
job_name = "integrations/ibm-db2"
Logs snippets
linux
Advanced mode
To instruct Grafana Alloy to scrape your IBM DB2 instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
To monitor your IBM DB2 instance, you must use a discovery.relabel component to discover your IBM DB2 Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your IBM DB2 Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this IBM DB2 instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple IBM DB2 servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
linux
To monitor your IBM DB2 instance logs, you will use a combination of the following components:
- local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The IBM DB2 instance address__path__
: The path to the log file.instance
sets theinstance
Logs are found where the DB2 instance is located, inside the sqllib
directory. For a single member environment, logs will be available at /path/to/inst/sqllib/db2dump/db2diag.log
. For multi-member environments logs are located at /path/to/inst/sqllib/db2dump/DIAG*/db2diag.log
. You can edit the __path__
label for logs to match your environment.
- loki.process defines how to process logs before sending it to Loki.
- loki.source.file sends logs to Loki.
db2
quit
Post-install configuration for the IBM DB2 integration
After enabling the metrics generation, instruct the Grafana Agent to scrape your IBM DB2 database.
If multiple databases are being monitored by the Grafana Agent, and subsequently, multiple exporters are running, then be sure to add additional targets to the metrics scrape config.
If you want to show logs and metrics signals correlated in your dashboards as a single pane of glass, ensure the following:
instance
label values for metrics and logs should be set to thehostname:port
passed to the exporter which is used to connect to IBM DB2 and monitor the specified database.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/ibm-db2
metrics_path: /metrics
static_configs:
- targets:
- localhost:9953
labels:
instance: '<your-instance-name>'
static_configs:
- targets: [localhost]
labels:
__path__: /home/*/sqllib/db2dump/{DIAG*,db2diag.log}/db2diag.log
job: integrations/ibm-db2
pipeline_stages:
- multiline:
firstline: '\d+-\d+-\d+-\d+.\d+.\d+.\d+\+\d+\s[A-Z0-9]+\s+LEVEL:\s[a-zA-Z]+'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the IBM DB2 integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
pipeline_stages:
- multiline:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
- targets:
- localhost:9953
labels:
global:
scrape_interval: 60s
Dashboards
The IBM DB2 integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- IBM DB2 overview
IBM DB2 overview (metrics)
IBM DB2 overview (logs)
Alerts
The IBM DB2 integration includes the following useful alerts:
Metrics
The most important metrics provided by the IBM DB2 integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- ibm_db2_application_active
- ibm_db2_bufferpool_hit_ratio
- ibm_db2_deadlock_total
- ibm_db2_lock_usage
- ibm_db2_lock_wait_time
- ibm_db2_log_operations_total
- ibm_db2_log_usage
- ibm_db2_row_total
- ibm_db2_tablespace_usage
- ibm_db2_up
- up
Changelog
Cost
By connecting your IBM DB2 instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
