Home Assistant integration for Grafana Cloud
Home Assistant is an open-source software platform designed for home automation, which enables users to control and monitor various devices and services in their home through a single, user-friendly interface. Home Assistant can run on a variety of devices, including Raspberry Pi, and can integrate with other popular home automation platforms like Amazon Alexa and Google Assistant. This integration connects your Home Assistant instance to Grafana cloud to visualize metrics through a pre-built dashboard.
This integration includes 1 pre-built dashboard to help monitor and visualize Home Assistant metrics.
Before you begin
In order for the integration to work, you must configure the in-built Prometheus exporter for Home Assistant.
At minimum you’ll need to add the prometheus:
directive to your configuration.yaml
file:
# Example configuration.yaml entry
prometheus:
You will also need to create a long-lived access token which will be used to authenticate the agent with Home Assistant.
Install Home Assistant integration for Grafana Cloud
- Find Home Assistant and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Home Assistant metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Home Assistant setup.
Advanced mode
To instruct Grafana Alloy to scrape your Home Assistant instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
To monitor your Home Assistant instance, you must use a discovery.relabel component to discover your Home Assistant Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Home Assistant Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Home Assistant instance.
If you have multiple Home Assistant servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
file:
prometheus:
Post-install configuration for the Home Assistant integration
After enabling the metrics generation, you should instruct Grafana Agent to scrape your Haas nodes.
Haas exposes a /api/prometheus
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
and bearer_token
in the snippet according to your environment.
- job_name: integrations/hass
metrics_path: /api/prometheus
bearer_token: '<your long lived HASS API token>'
scheme: https
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8123']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Home Assistant integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
scheme: https
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Home Assistant integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Home Assistant
Metrics
The most important metrics provided by the Home Assistant integration, which are used on the pre-built dashboard, are as follows:
- .*battery_level
- .*battery_level_percent
- .*battery_percent
- .*binary_sensor_state
- .*climate_action
- .*current_temperature_c
- .*entity_available
- .*humidifier_target_humidity_percent
- .*humidity_percent
- .*input_boolean_state
- .*last_updated_time_seconds
- .*light_state
- .*lock_state
- .*sensor_unit_.+
- .*switch_state
- .*temperature_c
Changelog
# 0.0.4 - September 2023
# 0.0.3 - January 2023
* Update mixin to latest version:
- Addressed lint warnings from mixtool
# 0.0.2 - January 2022
* Added `homeassistant` as default metrics prefix
# 0.0.1 - June 2021
* Initial release
Cost
By connecting your Home Assistant instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
