HAProxy integration for Grafana Cloud
HAProxy is a free, very fast and reliable solution offering high availability, load balancing, and proxying for TCP and HTTP-based applications. It is particularly suited for very high traffic web sites and powers quite a number of the world’s most visited ones. Over the years it has become the de-facto standard opensource load balancer, is now shipped with most mainstream Linux distributions, and is often deployed by default in cloud platforms. This integration allows you to collect metrics from the HAProxy instance and visualize them through pre-built dashboard in Grafana cloud.
This integration includes 3 useful alerts and 4 pre-built dashboards to help monitor and visualize HAProxy metrics.
Before you begin
This integration monitors an HAProxy Server app that exposes metrics through the built-in HAProxy Prometheus Exporter which can be built into the version 2.x+ binary.
A frontend configuration which is compatible with your existing HAProxy configuration is required. This configuration can be used as an example.
frontend stats
bind *:8404
option http-use-htx
http-request use-service prometheus-exporter if { path /metrics }
stats enable
stats uri /stats
stats refresh 10s
Install HAProxy integration for Grafana Cloud
- Find HAProxy and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send HAProxy metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your HAProxy setup.
Simple mode
These snippets are configured to scrape a single HAProxy instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_haproxy" {
targets = [{
__address__ = "localhost:8404",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_haproxy" {
targets = discovery.relabel.metrics_integrations_integrations_haproxy.output
job_name = "integrations/haproxy"
Advanced mode
To instruct Grafana Alloy to scrape your HAProxy instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your HAProxy instance, you must use a discovery.relabel component to discover your HAProxy Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your HAProxy Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this HAProxy instance.
If you have multiple HAProxy servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
frontend stats
bind *:8404
option http-use-htx
stats enable
stats uri /stats
stats refresh 10s
Post-install configuration for the HAProxy integration
After enabling the metrics generation, instruct Grafana Agent to scrape your HAProxy nodes.
HAProxy exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/haproxy
static_configs:
- targets: ['localhost:8404']
relabel_configs:
- action: replace
replacement: '<your-instance-name>'
target_label: instance
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the HAProxy integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
static_configs:
relabel_configs:
- action: replace
global:
scrape_interval: 60s
Dashboards
The HAProxy integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- HAProxy / Backend
- HAProxy / Frontend
- HAProxy / Overview
- HAProxy / Server
Alerts
The HAProxy integration includes the following useful alerts:
Alert | Description |
HAProxyDroppingLogs | Warning: HAProxy is dropping logs. |
HAProxyBackendCheckFlapping | Warning: HAProxy backend checks are flapping. |
HAProxyServerCheckFlapping | Warning: HAProxy server checks are flapping. |
Metrics
The most important metrics provided by the HAProxy integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- haproxy_backend_bytes_in_total
- haproxy_backend_bytes_out_total
- haproxy_backend_check_up_down_total
- haproxy_backend_connect_time_average_seconds
- haproxy_backend_connection_attempts_total
- haproxy_backend_connection_errors_total
- haproxy_backend_http_requests_total
- haproxy_backend_internal_errors_total
- haproxy_backend_max_connect_time_seconds
- haproxy_backend_max_queue_time_seconds
- haproxy_backend_max_response_time_seconds
- haproxy_backend_max_total_time_seconds
- haproxy_backend_queue_time_average_seconds
- haproxy_backend_response_errors_total
- haproxy_backend_response_time_average_seconds
- haproxy_backend_status
- haproxy_backend_total_time_average_seconds
- haproxy_frontend_bytes_in_total
- haproxy_frontend_bytes_out_total
- haproxy_frontend_connections_total
- haproxy_frontend_http_requests_total
- haproxy_frontend_internal_errors_total
- haproxy_frontend_request_errors_total
- haproxy_frontend_status
- haproxy_process_current_connections
- haproxy_process_dropped_logs_total
- haproxy_process_limit_connection_rate
- haproxy_process_limit_session_rate
- haproxy_process_limit_ssl_rate
- haproxy_process_max_connections
- haproxy_process_max_fds
- haproxy_process_max_memory_bytes
- haproxy_process_max_pipes
- haproxy_process_max_sockets
- haproxy_process_nbproc
- haproxy_process_nbthread
- haproxy_process_pool_allocated_bytes
- haproxy_process_pool_used_bytes
- haproxy_process_start_time_seconds
- haproxy_server_bytes_in_total
- haproxy_server_bytes_out_total
- haproxy_server_check_up_down_total
- haproxy_server_connect_time_average_seconds
- haproxy_server_connection_attempts_total
- haproxy_server_connection_errors_total
- haproxy_server_http_responses_total
- haproxy_server_internal_errors_total
- haproxy_server_max_connect_time_seconds
- haproxy_server_max_queue_time_seconds
- haproxy_server_max_response_time_seconds
- haproxy_server_max_total_time_seconds
- haproxy_server_queue_time_average_seconds
- haproxy_server_response_errors_total
- haproxy_server_response_time_average_seconds
- haproxy_server_status
- haproxy_server_total_time_average_seconds
- up
Changelog
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.5 - August 2023
# 0.0.4 - January 2023
* Update mixin to the latest version
- Update alert severity
- Update dashboard labels
# 0.0.3 - September 2022
* Update dashboard panels.
# 0.0.2 - October 2021
* Update mixin to latest version:
- Update the datasource template variable label to 'Data Source'
# 0.0.1 - April 2021
* Initial release
Cost
By connecting your HAProxy instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
