Grafana Agent health integration for Grafana Cloud
The Grafana agent integration lets you monitor metrics and logs of a Grafana agent instance
This integration includes 4 useful alerts and 5 pre-built dashboards to help monitor and visualize Grafana Agent health metrics and logs.
This integration relies on metrics emitted by Grafana Agent. See the following sections for details.
Install Grafana Agent health integration
- Find Grafana Agent health and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Grafana Agent health metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Grafana Agent health setup.
Post-install configuration for the Grafana Agent health integration
This integration supports metrics and logs for Grafana Agent. In order to enable logs, journal scraping needs to be enabled for Linux, and Windows event log scraping needs to enabled for Windows. Config snippets for both are available in the next section.
If you want to see your logs and metrics correlated on your dashboards, as a single pane of glass, ensure the following:
job
andinstance
label values must match foragent
integration andlogs
scrape config in your agent configuration file.job
label must be set tointegrations/agent
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your Grafana agent node. Please replace the default hostname value according to your environment - it should be set manually. Note that if you use localhost for multiple nodes, the dashboards will not be able to filter correctly by instance.
For a full description of configuration options see grafana agent integration in Grafana Agent documentation.
This integration relies on the Agent exporter, which is provided by default (with a reduced set of metrics) when you installed Grafana Agent.
Replace the existing agent
entry with the one provided here.
Below integrations
, insert the following lines, following the instructions above:
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- job_name: integrations/agent
journal:
max_age: 24h
labels:
job: integrations/agent
pipeline_stages:
- match:
selector: '{unit!="grafana-agent.service"}'
action: drop
drop_counter_reason: only_keep_grafana_agent_logs
- regex:
expression: "(level=(?P<log_level>[\\s]*debug|warn|info|error))"
- labels:
level: log_level
relabel_configs:
- source_labels: ['__journal__systemd_unit']
target_label: 'unit'
- source_labels: ['__journal__hostname']
target_label: 'instance'
Windows specific:
For Windows add the following snippet below logs.configs.scrape_configs
instead:
windows_events:
use_incoming_timestamp: true
bookmark_path: "C:\\Program Files\\Grafana Agent\\bookmarks-agent.xml"
eventlog_name: "Application"
xpath_query: "*[System[Provider[@Name='Grafana Agent']]]"
labels:
relabel_configs:
- source_labels: ['computer']
- replacement: grafana-agent.service
target_label: unit
pipeline_stages:
- json:
expressions:
message: message
- regex:
- labels:
level: log_level
- output:
source: message
The bookmark_path
in the configuration provided is set to a file inside the default Grafana Agent installation path in Windows. If you wish to configure a different bookmark path, please update it accordingly.
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Grafana Agent health integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
journal:
max_age: 24h
labels:
pipeline_stages:
- match:
action: drop
- regex:
- labels:
level: log_level
relabel_configs:
windows_events:
labels:
relabel_configs:
target_label: unit
pipeline_stages:
- json:
expressions:
message: message
- regex:
- labels:
level: log_level
- output:
source: message
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The Grafana Agent health integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Grafana Agent Logs
- Grafana Agent Operational
- Grafana Agent Overview
- Grafana Agent Remote Write
- Grafana Agent Tracing Pipeline
Grafana Agent Logs
Alerts
The Grafana Agent health integration includes the following useful alerts:
Metrics
The most important metrics provided by the Grafana Agent health integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- agent_build_info
- agent_tcp_connections
- agent_wal_samples_appended_total
- agent_wal_storage_active_series
- go_gc_duration_seconds_count
- go_goroutines
- go_memstats_heap_inuse_bytes
- process_cpu_seconds_total
- process_start_time_seconds
- prometheus_remote_storage_enqueue_retries_total
- prometheus_remote_storage_highest_timestamp_in_seconds
- prometheus_remote_storage_queue_highest_sent_timestamp_seconds
- prometheus_remote_storage_samples_dropped_total
- prometheus_remote_storage_samples_failed_total
- prometheus_remote_storage_samples_pending
- prometheus_remote_storage_samples_retried_total
- prometheus_remote_storage_samples_total
- prometheus_remote_storage_sent_batch_duration_seconds_bucket
- prometheus_remote_storage_sent_batch_duration_seconds_count
- prometheus_remote_storage_sent_batch_duration_seconds_sum
- prometheus_remote_storage_shard_capacity
- prometheus_remote_storage_shards
- prometheus_remote_storage_shards_desired
- prometheus_remote_storage_shards_max
- prometheus_remote_storage_shards_min
- prometheus_remote_storage_succeeded_samples_total
- prometheus_sd_discovered_targets
- prometheus_target_interval_length_seconds_count
- prometheus_target_interval_length_seconds_sum
- prometheus_target_scrapes_exceeded_sample_limit_total
- prometheus_target_scrapes_sample_duplicate_timestamp_total
- prometheus_target_scrapes_sample_out_of_bounds_total
- prometheus_target_scrapes_sample_out_of_order_total
- prometheus_target_sync_length_seconds_sum
- prometheus_wal_watcher_current_segment
- traces_exporter_send_failed_spans_total
- traces_exporter_sent_spans_total
- traces_receiver_accepted_spans_total
- traces_receiver_refused_spans_total
- up
Changelog
Cost
By connecting your Grafana Agent health instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
