Gitea integration for Grafana Cloud
Gitea is an open-source forge software package for hosting software development version control using Git as well as other collaborative features like bug tracking, wikis and code review.
This integration provides the dashboard with metrics exposed by Gitea, including application’s key stats as well as CPU, memory, file descriptors utilization.
This integration includes 1 pre-built dashboard to help monitor and visualize Gitea metrics.
Before you begin
In order for the integration to work, on Gitea instance you need to configure metrics section to enable /metrics endpoint:
[metrics]
ENABLED=true
In order to see issues stats grouped by repositores and labels, Gitea 1.16.0 or above is required with the following flags set:
[metrics]
ENABLED=true
ENABLED_ISSUE_BY_REPOSITORY=true
ENABLED_ISSUE_BY_LABEL=true
Install Gitea integration for Grafana Cloud
- Find Gitea and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Gitea metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Gitea setup.
Simple mode
These snippets are configured to scrape a single Gitea instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_gitea" {
targets = [{
__address__ = "localhost:3000",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_gitea" {
targets = discovery.relabel.metrics_integrations_integrations_gitea.output
job_name = "integrations/gitea"
Advanced mode
To instruct Grafana Alloy to scrape your Gitea instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Gitea instance, you must use a discovery.relabel component to discover your Gitea Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Gitea Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Gitea instance.
If you have multiple Gitea servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
[metrics]
ENABLED=true
[metrics]
ENABLED=true
Post-install configuration for the Gitea integration
After enabling the metrics generation, instruct Grafana Agent to scrape your Gitea nodes.
Gitea exposes a /metrics
endpoint. To scrape it, add the snippet above to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/gitea
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:3000']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Gitea integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Gitea integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Gitea Overview
Gitea overview
Metrics
The most important metrics provided by the Gitea integration, which are used on the pre-built dashboard, are as follows:
- gitea_issues_by_label
- gitea_issues_by_repository
- gitea_issues_closed
- gitea_issues_open
- gitea_milestones
- gitea_organizations
- gitea_releases
- gitea_repositories
- gitea_stars
- gitea_teams
- gitea_users
- process_cpu_seconds_total
- process_max_fds
- process_open_fds
- process_resident_memory_bytes
- process_start_time_seconds
- up
Changelog
# 0.0.4 - September 2023
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - January 2022
* Update mixin to latest version:
- fix dashboard templates to use `$datasource` variable
- allow multiselect for job
# 0.0.1 - December 2021
* Initial release
Cost
By connecting your Gitea instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
