dnsmasq integration for Grafana Cloud
dnsmasq is a network infrastructure provider for small networks. It provides DNS, DHCP, router advertisement, and more. This integration enables the agent to send metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize dnsmasq metrics.
Before you begin
This integration relies on a dnsmasq service running alongside Grafana Alloy. See the following sections for details.
Install dnsmasq integration for Grafana Cloud
- Find dnsmasq and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send dnsmasq metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your dnsmasq setup.
Simple mode
These snippets are configured to scrape a single dnsmasq instance running locally with default ports.
Integrations snippets
Advanced mode
To instruct Grafana Alloy to scrape your dnsmasq instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
This integrations uses the prometheus.exporter.dnsmasq component to generate metrics from a dnsmasq instance.
Set the address
argument to the address of your dnsmasq instance.
For the full array of configuration options, refer to the prometheus.exporter.dnsmasq component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each dnsmasq instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this dnsmasq instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
This integration relies on a dnsmasq service running alongside Grafana Agent. See the following sections for details.
Post-install configuration for the dnsmasq integration
This integration is configured to work with the dnsmasq_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the provided snippet to your agent configuration file.
Make sure to change the value of dnsmasq_address
to the address of the server you want to monitor in the agent config.
For a full description of configuration options see how to configure the dnsmasq_exporter_config
block in the agent documentation.
Below integrations
dnsmasq_exporter:
enabled: true
dnsmasq_address: localhost:53
instance: '<your-instance-name>'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the dnsmasq integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
dnsmasq_exporter:
enabled: true
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The dnsmasq integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- dnsmasq
Metrics
The most important metrics provided by the dnsmasq integration, which are used on the pre-built dashboard, are as follows:
- dnsmasq_cachesize
- dnsmasq_exporter_build_info
- dnsmasq_hits
- dnsmasq_insertions
- dnsmasq_leases
- dnsmasq_servers_queries
- dnsmasq_servers_queries_failed
- up
Changelog
Cost
By connecting your dnsmasq instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
