dnsmasq integration for Grafana Cloud
dnsmasq is a network infrastructure provider for small networks. It provides DNS, DHCP, router advertisement, and more. This integration enables Grafana Alloy to send metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize dnsmasq metrics.
Before you begin
This integration relies on a dnsmasq service running alongside Grafana Alloy. See the following sections for details.
Install dnsmasq integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find dnsmasq and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send dnsmasq metrics to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your dnsmasq setup.
Simple mode
These snippets are configured to scrape a single dnsmasq instance running locally with default ports.
Integrations snippets
Alloy
prometheus.exporter.dnsmasq "integrations_dnsmasq_exporter" { }
discovery.relabel "integrations_dnsmasq_exporter" {
	targets = prometheus.exporter.dnsmasq.integrations_dnsmasq_exporter.targets
	rule {
		target_label = "instance"
	rule {
		target_label = "job"
		replacement  = "integrations/dnsmasq_exporter"
prometheus.scrape "integrations_dnsmasq_exporter" {
	targets    = discovery.relabel.integrations_dnsmasq_exporter.output
	job_name   = "integrations/dnsmasq_exporter"
Advanced mode
To instruct Grafana Alloy to scrape your dnsmasq instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Alloy
	rule {
	rule {
This integrations uses the prometheus.exporter.dnsmasq component to generate metrics from a dnsmasq instance.
Set the address argument to the address of your dnsmasq instance.
For the full array of configuration options, refer to the prometheus.exporter.dnsmasq component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each dnsmasq instance to be monitored you must create a pair of these components.
Configure the following properties within each discovery.relabel component:
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this dnsmasq instance.
You can then scrape them by including each discovery.relabel under targets within the prometheus.scrape component.
Dashboards
The dnsmasq integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • dnsmasq
Metrics
The most important metrics provided by the dnsmasq integration, which are used on the pre-built dashboard, are as follows:
  • dnsmasq_cachesize
  • dnsmasq_exporter_build_info
  • dnsmasq_hits
  • dnsmasq_insertions
  • dnsmasq_leases
  • dnsmasq_servers_queries
  • dnsmasq_servers_queries_failed
  • up
Changelog
md
# 0.0.4 - September 2023
# 0.0.3 - January 2023
* Update mixin to the latest version:
  - Mixin now uses latest Grafana schema
  - Template variables have correct labels and allow multi-select
# 0.0.2 - September 2022
* Update mixin to latest version:
  - Update the datasource template variable label to 'Data Source'
# 0.0.1 - November 2020
* Initial release
Cost
By connecting your dnsmasq instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
