Couchbase integration for Grafana Cloud
Couchbase is a distributed NoSQL database which provides high availability, scalability, and performance for large sets of data. This integration for Grafana Cloud allows users to collect metrics and logs from the cluster, node, and bucket levels of a Couchbase clustered deployment.
This integration supports Couchbase 7.0+
This integration includes 4 useful alerts and 3 pre-built dashboards to help monitor and visualize Couchbase metrics and logs.
Before you begin
Couchbase exposes a Prometheus metrics endpoint that is enabled by default.
In order to access this endpoint, configure basic authentication with the credentials of a user with an admin role. For more information on roles in Couchbase, see these docs
Install Couchbase integration for Grafana Cloud
- Find Couchbase and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Couchbase metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Couchbase setup.
Advanced mode
To instruct Grafana Alloy to scrape your Couchbase instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
To monitor your Couchbase instance, you must use a discovery.relabel component to discover your Couchbase Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Couchbase Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Couchbase instance. Make sure this label value is the same for all telemetry data collected for this instance.couchbase_cluster
: Thecouchbase_cluster
label to group your Couchbase instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Couchbase servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
To monitor your Couchbase instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Couchbase instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
linux
__address__
sets theinstance
windows
__address__
sets theinstance
Post-install configuration for the Couchbase integration
You should instruct Grafana Agent to scrape your Couchbase nodes.
Couchbase exposes a /metrics
endpoint. To scrape it, add the provided config snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
,instance
, andcouchbase_cluster
label values must match for metrics and logs scrape config in your agent configuration file.job
label must be set tointegrations/couchbase
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your Couchbase node. Please replace the default hostname value according to your environment - it must be set manually.couchbase_cluster
label must be set to a value that identifies your Couchbase cluster.
- job_name: integrations/couchbase
basic_auth:
username: '<cb-cluster-username>'
password: '<cb-cluster-password>'
metrics_path: "/metrics"
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- replacement: '<your-cluster-name>'
target_label: couchbase_cluster
static_configs:
- targets: [<node-hostname>:8091]
static_configs:
- targets: [localhost]
labels:
job: integrations/couchbase
instance: '<your-instance-name>'
couchbase_cluster: '<your-cluster-name>'
__path__: /opt/couchbase/var/lib/couchbase/*.log
pipeline_stages:
- drop:
expression: '---'
- multiline:
firstline: '(\\[(ns_server|couchdb):(error|info),.*\\]|\\[\\d\\] couchbase.log.*)'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Couchbase integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
labels:
pipeline_stages:
- drop:
expression: '---'
- multiline:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
basic_auth:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Couchbase integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Couchbase bucket overview
- Couchbase cluster overview
- Couchbase node overview
Couchbase cluster overview (top nodes)
Couchbase node overview (memory)
Couchbase bucket overview (storage)
Alerts
The Couchbase integration includes the following useful alerts:
Metrics
The most important metrics provided by the Couchbase integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- backup_data_size
- cbas_direct_memory_used_bytes
- cm_http_requests_total
- couch_docs_actual_disk_size
- index_avg_scan_latency
- index_cache_hits
- index_cache_misses
- index_memory_used_total
- index_num_requests
- kv_curr_connections
- kv_curr_items
- kv_ep_num_value_ejects
- kv_mem_used_bytes
- kv_num_high_pri_requests
- kv_num_vbuckets
- kv_ops
- kv_ops_failed
- kv_vb_queue_memory_bytes
- n1ql_errors
- n1ql_invalid_requests
- n1ql_requests
- n1ql_requests_1000ms
- n1ql_requests_250ms
- n1ql_requests_5000ms
- n1ql_requests_500ms
- sys_cpu_utilization_rate
- sys_mem_actual_free
- sys_mem_actual_used
- up
- xdcr_data_replicated_bytes
- xdcr_docs_received_from_dcp_total
Changelog
# 1.0.0 - March 2024
- Added cluster selector to dashboards for kubernetes support
- Added default cluster label to agent config
- Bump version to 1.0.0
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
- Initial release
Cost
By connecting your Couchbase instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
