CockroachDB integration for Grafana Cloud
CockroachDB is a cloud-native SQL database for building global, scalable cloud services that survive disasters.
This integration includes 8 useful alerts and 4 pre-built dashboards to help monitor and visualize CockroachDB metrics.
Before you begin
CockroachDB exposes a Prometheus metrics endpoint that is enabled by default.
Install CockroachDB integration for Grafana Cloud
- Find CockroachDB and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send CockroachDB metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your CockroachDB setup.
Simple mode
These snippets are configured to scrape a single CockroachDB instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_cockroachdb" {
targets = [{
__address__ = "localhost:8080",
cluster = "cloud",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_cockroachdb" {
targets = discovery.relabel.metrics_integrations_integrations_cockroachdb.output
job_name = "integrations/cockroachdb"
metrics_path = "/_status/vars"
}Advanced mode
To instruct Grafana Alloy to scrape your CockroachDB instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
cluster = "cloud",
rule {
}To monitor your CockroachDB instance, you must use a discovery.relabel component to discover your CockroachDB Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
__address__: The address to your CockroachDB Prometheus metrics endpoint.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this CockroachDB instance.cluster: If you are running on k8s, set this to your k8s cluster name
If you have multiple CockroachDB servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
Configuration snippets for Kubernetes Helm chart
To scrape your CockroachDB instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <> in the provided snippets with your desired configuration values.
Metrics snippets
alloy-metrics:
extraConfig: |-
discovery.kubernetes "cockroachdb" {
role = "service"
selectors {
role = "service"
label = "<service label>=<service label value>"
prometheus.scrape "cockroachdb" {
targets = discovery.kubernetes.cockroachdb.output
forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
}Grafana Agent static configuration (deprecated)
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send CockroachDB metrics to your Grafana Cloud instance.
Post-install configuration for the CockroachDB integration
Instruct Grafana Agent to scrape your CockroachDB nodes.
CockroachDB exposes a /_status/vars endpoint. To scrape it, add the provided snippet to your agent configuration file.
A cluster label must be added to each scrape, as shown in the code snippet. This is used as a filter in the dashboards, so you can monitor your nodes by cluster. Make sure to give it a value according to your environment.
Make sure to change targets in the snippet according to your environment.
Below metrics.configs.scrape_configs, insert the following lines and change the URLs according to your environment:
- job_name: integrations/cockroachdb
metrics_path: /_status/vars
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8080']
labels:
cluster: cloudFull example configuration for Grafana Agent
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the CockroachDB integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
labels:
cluster: cloud
global:
scrape_interval: 60s
wal_directory: /tmp/grafana-agent-walDashboards
The CockroachDB integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Cockroach Replicas
- Cockroach Runtime
- Cockroach SQL
- Cockroach Storage
CockroachDB Replicas - 1
CockroachDB Runtime - 1
CockroachDB Storage - 1
Alerts
The CockroachDB integration includes the following useful alerts:
| Alert | Description |
| CockroachInstanceFlapping | Warning: CockroachDB instances have restarted in the last 10 minutes. |
| CockroachLivenessMismatch | Warning: CockroachDB has liveness mismatches. |
| CockroachVersionMismatch | Warning: CockroachDB cluster is running different versions. |
| CockroachStoreDiskLow | Critical: CockroachDB is at low disk capacity. |
| CockroachClusterDiskLow | Critical: CockroachDB cluster is at critically low disk capacity. |
| CockroachUnavailableRanges | Critical: CockroachDB has unavailable ranges. |
| CockroachNoLeaseRanges | Warning: CockroachDB has ranges without leases. |
| CockroachHighOpenFDCount | Warning: CockroachDB has too many open file descriptors. |
Metrics
The most important metrics provided by the CockroachDB integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- :cockroachdb_capacity_available:ratio
- build_timestamp
- capacity
- capacity_available
- capacity_reserved
- clock_offset_meannanos
- cluster:cockroachdb_capacity_available:ratio
- cockroachdb_build_timestamp
- cockroachdb_capacity
- cockroachdb_capacity_available
- cockroachdb_liveness_livenodes
- cockroachdb_ranges_unavailable
- cockroachdb_replicas_leaders_not_leaseholders
- cockroachdb_sys_fd_open
- cockroachdb_sys_fd_softlimit
- cockroachdb_sys_uptime
- keybytes
- livebytes
- liveness_livenodes
- raft_process_commandcommit_latency_bucket
- raft_process_logcommit_latency_bucket
- raft_rocksdb_block_cache_hits
- raft_rocksdb_block_cache_misses
- raft_rocksdb_num_sstables
- raft_rocksdb_read_amplification
- raftlog_behind
- raftlog_selfbehind
- raftlog_truncated
- range_adds
- range_removes
- range_snapshots_generated
- range_snapshots_normal_applied
- range_snapshots_preemptive_applied
- range_splits
- ranges
- ranges_unavailable
- ranges_underreplicated
- rebalancing_writespersecond
- replicas
- replicas_leaders
- replicas_leaders_not_leaseholders
- replicas_leaseholders
- replicas_quiescent
- replicas_reserved
- rocksdb_block_cache_hits
- rocksdb_block_cache_misses
- rocksdb_num_sstables
- rocksdb_read_amplification
- round_trip_latency_bucket
- sql_bytesin
- sql_bytesout
- sql_conns
- sql_ddl_count
- sql_delete_count
- sql_exec_latency_bucket
- sql_insert_count
- sql_select_count
- sql_txn_abort_count
- sql_txn_begin_count
- sql_txn_commit_count
- sql_txn_rollback_count
- sql_update_count
- sys_cgo_allocbytes
- sys_cgo_totalbytes
- sys_cgocalls
- sys_cpu_sys_ns
- sys_cpu_user_ns
- sys_fd_open
- sys_fd_softlimit
- sys_gc_count
- sys_gc_pause_ns
- sys_go_allocbytes
- sys_go_totalbytes
- sys_goroutines
- sys_rss
- sys_uptime
- sysbytes
- up
- valbytes
Changelog
# 1.0.0 - January 2024
* Updated dashboards to use new React based panels
* Fixed queries for histogram metrics to address panels showing "no data"
# 0.0.6 - September 2023
# 0.0.5 - May 2023
* Add summary and description to alerts to give better visibility of alerts at a glance
# 0.0.4 - February 2023
* Added Grafana Agent Operator configuration snippet to support CockroachDB in a kubernetes cluster.
# 0.0.3 - June 2022
* Add cluster label to agent config
* Rename `node` to `instance` to be consistent with other dashboards, and the prometheus scraping convention
* Add job matcher to all queries on all dashboards, with corresponding dashboard template variable
# 0.0.2 - October 2021
* Update all rate queries to use `$__rate_interval`, so they respect the default resolution
# 0.0.1 - December 2020
* Initial releaseCost
By connecting your CockroachDB instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
