Cilium Enterprise integration
Cilium Enterprise integration for Grafana Cloud
The Cilium Enterprise integration uses the Grafana Agent to collect metrics exposed by the Cilium Operator, Cilium Agent and its components, as well as Hubble. A series of dashboards have been provided, both for overviews and per-component basis. This integration includes 18 useful alerts and 20 pre-built dashboards to help monitor and visualize Cilium Enterprise metrics.
Before you begin
Please note, this integration is intended exclusively for use with Cilium Enterprise, and does not support the Cilium OSS product.
This integration monitors a Cilium Enterprise & Hubble Enterprise deployment that has metrics exporters enabled. Please ensure you have completed the following setup steps:
Once the exporters have been enabled the metrics are automatically exposed and available to be scraped by either Prometheus or a Grafana Alloy deployed to the cluster.
The following sample using Helm enables the Prometheus metrics endpoint and configures the relevant metrics for Cilium Agent, Cilium Operator, and Hubble:
helm install cilium cilium/cilium --version 1.12.2 \
  --namespace kube-system \
  --set prometheus.enabled=true \
  --set operator.prometheus.enabled=true
Sample Hubble metrics setup using helm, specifying which metrics to enable capture and export for:
  --set hubble.metrics.enabled="{dns,drop,tcp,flow,icmp,http}"
Install Cilium Enterprise integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Cilium Enterprise and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Cilium Enterprise metrics to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Cilium Enterprise setup.
Simple mode
These snippets are configured to scrape a single Cilium Enterprise instance running locally with default ports.
Metrics snippets
alloy
discovery.kubernetes "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor" {
	role = "endpoints"
discovery.kubernetes "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server" {
	role = "endpoints"
discovery.kubernetes "metrics_integrations_integrations_cilium_enterprise_cilium_agent" {
	role = "endpoints"
discovery.kubernetes "metrics_integrations_integrations_cilium_enterprise_cilium_operator" {
	role = "endpoints"
discovery.kubernetes "metrics_integrations_integrations_cilium_enterprise_hubble" {
	role = "endpoints"
discovery.kubernetes "metrics_integrations_integrations_cilium_enterprise_hubble_enterprise" {
	role = "endpoints"
discovery.relabel "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor" {
	targets = discovery.kubernetes.metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor.targets
	rule {
		source_labels = ["__meta_kubernetes_service_label_app_kubernetes_io_instance", "__meta_kubernetes_service_labelpresent_app_kubernetes_io_instance"]
		regex         = "(hubble-timescape);true"
		action        = "keep"
	rule {
		source_labels = ["__meta_kubernetes_service_label_app_kubernetes_io_name", "__meta_kubernetes_service_labelpresent_app_kubernetes_io_name"]
		regex         = "(hubble-timescape-ingestor);true"
		action        = "keep"
	rule {
		source_labels = ["__meta_kubernetes_endpoint_port_name"]
		regex         = "metrics"
		action        = "keep"
	rule {
		source_labels = ["__meta_kubernetes_endpoint_address_target_kind", "__meta_kubernetes_endpoint_address_target_name"]
		regex         = "Node;(.*)"
		target_label  = "node"
		replacement   = "${1}"
	rule {
		regex         = "Pod;(.*)"
		target_label  = "pod"
	rule {
		source_labels = ["__meta_kubernetes_namespace"]
		target_label  = "namespace"
	rule {
		source_labels = ["__meta_kubernetes_service_name"]
		target_label  = "service"
	rule {
		source_labels = ["__meta_kubernetes_pod_name"]
	rule {
		source_labels = ["__meta_kubernetes_pod_container_name"]
		target_label  = "container"
	rule {
		target_label = "endpoint"
		replacement  = "metrics"
	rule {
		source_labels = ["__address__"]
		modulus       = 1
		target_label  = "__tmp_hash"
		action        = "hashmod"
	rule {
		source_labels = ["__tmp_hash"]
		regex         = "0"
		action        = "keep"
discovery.relabel "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server" {
	targets = discovery.kubernetes.metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server.targets
	rule {
		action        = "keep"
	rule {
		regex         = "(hubble-timescape-server);true"
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
discovery.relabel "metrics_integrations_integrations_cilium_enterprise_cilium_agent" {
	targets = discovery.kubernetes.metrics_integrations_integrations_cilium_enterprise_cilium_agent.targets
	rule {
		source_labels = ["__meta_kubernetes_service_label_k8s_app", "__meta_kubernetes_service_labelpresent_k8s_app"]
		regex         = "(cilium);true"
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
		source_labels = ["__meta_kubernetes_service_label_k8s_app"]
		regex         = "(.+)"
		target_label  = "k8s_app"
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
discovery.relabel "metrics_integrations_integrations_cilium_enterprise_cilium_operator" {
	targets = discovery.kubernetes.metrics_integrations_integrations_cilium_enterprise_cilium_operator.targets
	rule {
		source_labels = ["__meta_kubernetes_service_label_io_cilium_app", "__meta_kubernetes_service_labelpresent_io_cilium_app"]
		regex         = "(operator);true"
		action        = "keep"
	rule {
		source_labels = ["__meta_kubernetes_service_label_name", "__meta_kubernetes_service_labelpresent_name"]
		regex         = "(cilium-operator);true"
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
		source_labels = ["__meta_kubernetes_service_label_io_cilium_app"]
		regex         = "(.+)"
		target_label  = "io_cilium_app"
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
discovery.relabel "metrics_integrations_integrations_cilium_enterprise_hubble" {
	targets = discovery.kubernetes.metrics_integrations_integrations_cilium_enterprise_hubble.targets
	rule {
		regex         = "(hubble);true"
		action        = "keep"
	rule {
		regex         = "hubble-metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
		replacement  = "hubble-metrics"
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
discovery.relabel "metrics_integrations_integrations_cilium_enterprise_hubble_enterprise" {
	targets = discovery.kubernetes.metrics_integrations_integrations_cilium_enterprise_hubble_enterprise.targets
	rule {
		regex         = "(hubble-enterprise);true"
		action        = "keep"
	rule {
		source_labels = ["__meta_kubernetes_service_label_app_kubernetes_io_managed_by", "__meta_kubernetes_service_labelpresent_app_kubernetes_io_managed_by"]
		regex         = "(Helm);true"
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		source_labels = ["__meta_kubernetes_service_label_helm_sh_chart", "__meta_kubernetes_service_labelpresent_helm_sh_chart"]
		regex         = "(hubble-enterprise-9999.9999.9999-dev);true"
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
		source_labels = ["__meta_kubernetes_pod_node_name"]
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
prometheus.scrape "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor" {
	targets        = discovery.relabel.metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor.output
	forward_to     = [prometheus.relabel.metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor.receiver]
	job_name       = "integrations/cilium-enterprise/hubble-timescape-ingestor"
	honor_labels   = true
	scrape_timeout = "1m0s"
prometheus.scrape "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server" {
	targets        = discovery.relabel.metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server.output
	forward_to     = [prometheus.relabel.metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server.receiver]
	job_name       = "integrations/cilium-enterprise/hubble-timescape-server"
	honor_labels   = true
prometheus.scrape "metrics_integrations_integrations_cilium_enterprise_cilium_agent" {
	targets        = discovery.relabel.metrics_integrations_integrations_cilium_enterprise_cilium_agent.output
	forward_to     = [prometheus.relabel.metrics_integrations_integrations_cilium_enterprise_cilium_agent.receiver]
	job_name       = "integrations/cilium-enterprise/cilium-agent"
	honor_labels   = true
prometheus.scrape "metrics_integrations_integrations_cilium_enterprise_cilium_operator" {
	targets        = discovery.relabel.metrics_integrations_integrations_cilium_enterprise_cilium_operator.output
	forward_to     = [prometheus.relabel.metrics_integrations_integrations_cilium_enterprise_cilium_operator.receiver]
	job_name       = "integrations/cilium-enterprise/cilium-operator"
	honor_labels   = true
prometheus.scrape "metrics_integrations_integrations_cilium_enterprise_hubble" {
	targets        = discovery.relabel.metrics_integrations_integrations_cilium_enterprise_hubble.output
	forward_to     = [prometheus.relabel.metrics_integrations_integrations_cilium_enterprise_hubble.receiver]
	job_name       = "integrations/cilium-enterprise/hubble"
	honor_labels   = true
prometheus.scrape "metrics_integrations_integrations_cilium_enterprise_hubble_enterprise" {
	targets        = discovery.relabel.metrics_integrations_integrations_cilium_enterprise_hubble_enterprise.output
	forward_to     = [prometheus.relabel.metrics_integrations_integrations_cilium_enterprise_hubble_enterprise.receiver]
	job_name       = "integrations/cilium-enterprise/hubble-enterprise"
	honor_labels   = true
prometheus.relabel "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_ingestor" {
	rule {
		source_labels = ["__name__"]
		regex         = "cilium_agent_api_process_time_seconds_count|cilium_agent_api_process_time_seconds_sum|cilium_api_limiter_processed_requests_total|cilium_bpf_map_ops_total|cilium_bpf_map_pressure|cilium_controllers_runs_duration_seconds_count|cilium_controllers_runs_duration_seconds_sum|cilium_controllers_runs_total|cilium_datapath_conntrack_gc_duration_seconds_count|cilium_datapath_conntrack_gc_duration_seconds_sum|cilium_datapath_conntrack_gc_entries|cilium_datapath_conntrack_gc_key_fallbacks_total|cilium_datapath_conntrack_gc_runs_total|cilium_drop_bytes_total|cilium_drop_count_total|cilium_endpoint_regeneration_time_stats_seconds_count|cilium_endpoint_regeneration_time_stats_seconds_sum|cilium_endpoint_regenerations_total|cilium_endpoint_state|cilium_errors_warnings_total|cilium_forward_bytes_total|cilium_forward_count_total|cilium_identity|cilium_ip_addresses|cilium_k8s_client_api_calls_total|cilium_k8s_client_api_latency_time_seconds_count|cilium_k8s_client_api_latency_time_seconds_sum|cilium_kubernetes_events_received_total|cilium_kubernetes_events_total|cilium_nodes_all_events_received_total|cilium_nodes_all_num|cilium_operator_ces_queueing_delay_seconds_bucket|cilium_operator_ces_sync_errors_total|cilium_operator_ec2_api_duration_seconds_bucket|cilium_operator_identity_gc_entries|cilium_operator_identity_gc_runs|cilium_operator_ipam_allocation_ops|cilium_operator_ipam_deficit_resolver_duration_seconds_bucket|cilium_operator_ipam_interface_creation_ops|cilium_operator_ipam_ips|cilium_operator_ipam_k8s_sync_queued_total|cilium_operator_ipam_nodes|cilium_operator_ipam_resync_queued_total|cilium_operator_ipam_resync_total|cilium_operator_number_of_ceps_per_ces_sum|cilium_operator_process_cpu_seconds_total|cilium_operator_process_open_fds|cilium_operator_process_resident_memory_bytes|cilium_operator_process_virtual_memory_bytes|cilium_policy|cilium_policy_endpoint_enforcement_status|cilium_policy_l7_denied_total|cilium_policy_l7_forwarded_total|cilium_policy_l7_received_total|cilium_proxy_redirects|cilium_proxy_upstream_reply_seconds_count|cilium_proxy_upstream_reply_seconds_sum|cilium_services_events_total|cilium_triggers_policy_update_call_duration_seconds_count|cilium_triggers_policy_update_call_duration_seconds_sum|cilium_unreachable_nodes|cilium_version|hubble_dns_queries_total|hubble_dns_response_types_total|hubble_dns_responses_total|hubble_drop_total|hubble_flows_processed_total|hubble_http_request_duration_seconds_bucket|hubble_http_requests_total|hubble_http_responses_total|hubble_icmp_total|hubble_port_distribution_total|hubble_tcp_flags_total|isovalent_external_dns_proxy_policy_l7_total|isovalent_external_dns_proxy_processing_duration_seconds|isovalent_external_dns_proxy_update_errors_total|isovalent_external_dns_proxy_update_queue_size|timescape_clickhouse_queries_duration_seconds_bucket|timescape_clickhouse_queries_results_count|timescape_clickhouse_queries_results_sum|timescape_ingestor_flows_ingested_total|timescape_ingestor_ingest_duration_seconds_bucket|timescape_ingestor_ingest_running|timescape_ingestor_ingestfilter_batch_duration_seconds_bucket|timescape_ingestor_ingestfilter_filtered_errors_total|timescape_ingestor_ingestfilter_filtered_skipped_total|timescape_ingestor_ingestfilter_filtered_total|timescape_ingestor_ingestlog_getinfo_queries"
		action        = "keep"
prometheus.relabel "metrics_integrations_integrations_cilium_enterprise_hubble_timescape_server" {
	rule {
		action        = "keep"
prometheus.relabel "metrics_integrations_integrations_cilium_enterprise_cilium_agent" {
	rule {
		action        = "keep"
prometheus.relabel "metrics_integrations_integrations_cilium_enterprise_cilium_operator" {
	rule {
		action        = "keep"
prometheus.relabel "metrics_integrations_integrations_cilium_enterprise_hubble" {
	rule {
		action        = "keep"
prometheus.relabel "metrics_integrations_integrations_cilium_enterprise_hubble_enterprise" {
	rule {
		action        = "keep"
Advanced mode
To instruct Grafana Alloy to scrape your Cilium Enterprise instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
alloy
	role = "endpoints"
	role = "endpoints"
	role = "endpoints"
	role = "endpoints"
	role = "endpoints"
	role = "endpoints"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
		regex         = "(.+)"
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
		regex         = "(.+)"
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		regex         = "metrics"
		action        = "keep"
	rule {
		regex         = "Node;(.*)"
	rule {
		regex         = "Pod;(.*)"
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
	rule {
		modulus       = 1
		action        = "hashmod"
	rule {
		regex         = "0"
		action        = "keep"
	honor_labels   = true
	honor_labels   = true
	honor_labels   = true
	honor_labels   = true
	honor_labels   = true
	honor_labels   = true
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
	rule {
		action        = "keep"
To monitor your Cilium Enterprise instance, you must use a discovery.relabel component to discover your Cilium Enterprise Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
  • __address__: The address to your Cilium Enterprise Prometheus metrics endpoint.
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Cilium Enterprise instance.
If you have multiple Cilium Enterprise servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Dashboards
The Cilium Enterprise integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Cilium / Agent Overview
  • Cilium / Components / API
  • Cilium / Components / Agent
  • Cilium / Components / BPF
  • Cilium / Components / Conntrack
  • Cilium / Components / Datapath
  • Cilium / Components / External HA FQDN Proxy
  • Cilium / Components / FQDN Proxy
  • Cilium / Components / Identities
  • Cilium / Components / Kubernetes
  • Cilium / Components / L3 Policy
  • Cilium / Components / L7 Proxy
  • Cilium / Components / Network
  • Cilium / Components / Nodes
  • Cilium / Components / Policy
  • Cilium / Components / Resource Utilization
  • Cilium / Operator
  • Cilium / Overview
  • Hubble / Overview
  • Hubble / Timescape
Cilium Overview
Cilium Overview
Cilium Overview (2)
Cilium Overview (2)
Cilium Agent Overview
Alerts
The Cilium Enterprise integration includes the following useful alerts:
Cilium Endpoints
AlertDescription
CiliumAgentEndpointFailuresWarning: Cilium Agent endpoints in the invalid state.
CiliumAgentEndpointUpdateFailureWarning: API calls to Cilium Agent API to create or update Endpoints are failing.
CiliumAgentContainerNetworkInterfaceApiErrorEndpointCreateInfo: Cilium Endpoint API endpoint rate limiter is reporting errors while doing endpoint create.
CiliumAgentApiEndpointErrorsWarning: API calls to Cilium Endpoints API are failing due to server errors.
Cilium IPAM
AlertDescription
CiliumOperatorExhaustedIpamIpsCritical: Cilium Operator has exhausted its IPAM IPs.
CiliumOperatorLowAvailableIpamIpsWarning: Cilium Operator has used up over 90% of its available IPs.
CiliumOperatorEniIpamErrorsCritical: Cilium Operator has high error rate while trying to create/attach ENIs for IPAM.
Cilium Maps
AlertDescription
CiliumAgentMapOperationFailuresWarning: Cilium Agent is experiencing errors updating BPF maps on Agent Pod.
CiliumAgentBpfMapPressureWarning: Map on Cilium Agent Pod is currently experiencing high map pressure.
Cilium NAT
AlertDescription
CiliumAgentNatTableFullCritical: Cilium Agent Pod is dropping packets due to “No mapping for NAT masquerade” errors.
Cilium API
AlertDescription
CiliumAgentApiHighErrorRateInfo: Cilium Agent API on Pod is experiencing a high error rate.
Cilium Conntrack
AlertDescription
CiliumAgentConntrackTableFullCritical: Ciliums conntrack map is failing on new insertions on Agent Pod.
CiliumAgentConnTrackFailedGarbageCollectorRunsWarning: Cilium Agent Conntrack GC runs are failing on Agent Pod.
Cilium Drops
AlertDescription
CiliumAgentHighDeniedRateInfo: Cilium Agent is experiencing a high drop rate due to policy rule denies.
Cilium Policy
AlertDescription
CiliumAgentPolicyMapPressureWarning: Cilium Agent is experiencing high BPF map pressure.
Cilium Identity
AlertDescription
CiliumNodeLocalHighIdentityAllocationWarning: Cilium is using a very high percent (over 80%) of its maximum per-node identity limit (65535).
RunningOutOfCiliumClusterIdentitiesWarning: Cilium is using a very high percent of its maximum cluster identity limit (65280).
Cilium Nodes
AlertDescription
CiliumUnreachableNodesInfo: Cilium Agent is reporting unreachable Nodes in the cluster.
Metrics
The most important metrics provided by the Cilium Enterprise integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
  • cilium_agent_api_process_time_seconds_count
  • cilium_agent_api_process_time_seconds_sum
  • cilium_api_limiter_processed_requests_total
  • cilium_bpf_map_ops_total
  • cilium_bpf_map_pressure
  • cilium_controllers_runs_duration_seconds_count
  • cilium_controllers_runs_duration_seconds_sum
  • cilium_controllers_runs_total
  • cilium_datapath_conntrack_gc_duration_seconds_count
  • cilium_datapath_conntrack_gc_duration_seconds_sum
  • cilium_datapath_conntrack_gc_entries
  • cilium_datapath_conntrack_gc_key_fallbacks_total
  • cilium_datapath_conntrack_gc_runs_total
  • cilium_drop_bytes_total
  • cilium_drop_count_total
  • cilium_endpoint_regeneration_time_stats_seconds_count
  • cilium_endpoint_regeneration_time_stats_seconds_sum
  • cilium_endpoint_regenerations_total
  • cilium_endpoint_state
  • cilium_errors_warnings_total
  • cilium_forward_bytes_total
  • cilium_forward_count_total
  • cilium_identity
  • cilium_ip_addresses
  • cilium_k8s_client_api_calls_total
  • cilium_k8s_client_api_latency_time_seconds_count
  • cilium_k8s_client_api_latency_time_seconds_sum
  • cilium_kubernetes_events_received_total
  • cilium_kubernetes_events_total
  • cilium_nodes_all_events_received_total
  • cilium_nodes_all_num
  • cilium_operator_ces_queueing_delay_seconds_bucket
  • cilium_operator_ces_sync_errors_total
  • cilium_operator_ec2_api_duration_seconds_bucket
  • cilium_operator_identity_gc_entries
  • cilium_operator_identity_gc_runs
  • cilium_operator_ipam_allocation_ops
  • cilium_operator_ipam_deficit_resolver_duration_seconds_bucket
  • cilium_operator_ipam_interface_creation_ops
  • cilium_operator_ipam_ips
  • cilium_operator_ipam_k8s_sync_queued_total
  • cilium_operator_ipam_nodes
  • cilium_operator_ipam_resync_queued_total
  • cilium_operator_ipam_resync_total
  • cilium_operator_number_of_ceps_per_ces_sum
  • cilium_operator_process_cpu_seconds_total
  • cilium_operator_process_open_fds
  • cilium_operator_process_resident_memory_bytes
  • cilium_operator_process_virtual_memory_bytes
  • cilium_policy
  • cilium_policy_endpoint_enforcement_status
  • cilium_policy_l7_denied_total
  • cilium_policy_l7_forwarded_total
  • cilium_policy_l7_received_total
  • cilium_proxy_redirects
  • cilium_proxy_upstream_reply_seconds_count
  • cilium_proxy_upstream_reply_seconds_sum
  • cilium_services_events_total
  • cilium_triggers_policy_update_call_duration_seconds_count
  • cilium_triggers_policy_update_call_duration_seconds_sum
  • cilium_unreachable_nodes
  • cilium_version
  • hubble_dns_queries_total
  • hubble_dns_response_types_total
  • hubble_dns_responses_total
  • hubble_drop_total
  • hubble_flows_processed_total
  • hubble_http_request_duration_seconds_bucket
  • hubble_http_requests_total
  • hubble_http_responses_total
  • hubble_icmp_total
  • hubble_port_distribution_total
  • hubble_tcp_flags_total
  • isovalent_external_dns_proxy_policy_l7_total
  • isovalent_external_dns_proxy_processing_duration_seconds
  • isovalent_external_dns_proxy_update_errors_total
  • isovalent_external_dns_proxy_update_queue_size
  • timescape_clickhouse_queries_duration_seconds_bucket
  • timescape_clickhouse_queries_results_count
  • timescape_clickhouse_queries_results_sum
  • timescape_ingestor_flows_ingested_total
  • timescape_ingestor_ingest_duration_seconds_bucket
  • timescape_ingestor_ingest_running
  • timescape_ingestor_ingestfilter_batch_duration_seconds_bucket
  • timescape_ingestor_ingestfilter_filtered_errors_total
  • timescape_ingestor_ingestfilter_filtered_skipped_total
  • timescape_ingestor_ingestfilter_filtered_total
  • timescape_ingestor_ingestlog_getinfo_queries
  • up
Changelog
md
# 1.0.0 - June 2024
* Update Mixin to latest version
  - Removed pod filter from alert rules
  - Added thresholds for alerts using rate()
  - Added aggregation label support
# 0.0.4 - November 2023
* Replaced Angular dashboard panels with React panels
# 0.0.3 - July 2023
* Added support for using the integration in the Grafana Cloud Kubernetes App
* Update all scrape intervals to be 60s
* Fix job name to correct value in static agent config
# 0.0.2 - January 2023
* Update mixin to latest version:
  - Add new alert `CiliumOperatorEniIpamErrors` to alert on errors related to allocating new IPAM addresses and situations where nodes are experiencing IPAM exhaustion
  - Fix alert conditions to trigger correctly
# 0.0.1 - October 2022
* Initial release
Cost
By connecting your Cilium Enterprise instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
